Candy store for OPPO owners?
1235711
  • honestaquarian
    honestaquarian Posts: 3,021
    Before👆🏾
    After👆🏼
  • honestaquarian
    That plus the fact that the before pics were taken this afternoon during daylight hours
  • honestaquarian
    The last two above you can see an obvious shift in the color blue.
    nooshinjohn Posts: 24,219
    Man... I don’t know. Are you certain everything went back together properly?
    The Gear... Carver "Statement" Mono-blocks, Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 380d DSDIn retirement...TriangleArt Reference SE with Walker Precision Motor Drive, Yamaha CD-S2100 SACD Player.“Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell“If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • honestaquarian
    Gow away ya bug me😝
  • honestaquarian
    Before👆🏼
    After👆🏼
  • honestaquarian
    Overall the picture is definitely sharper to my eye. Again the camera may not be able to pick up the difference.
    The bass is much better and the dialog is clearer. This is having only been on for less than an hour.
  • honestaquarian
    edited April 2020
    Before👆🏾
    After👆🏼
  • honestaquarian
    Again the before and after pics were taken-before in the afternoon with daylight coming in through the shades and curtains. Now it is nighttime.
    How does it compare to your Pioneer LDP?
  • honestaquarian
    Before👆🏼
    After👆🏾
  • honestaquarian
    Less noise there
  • BlueFox
    BlueFox Posts: 15,251
    The before and after pictures are pretty good. Looks like the upgrade is worthwhile. Now you need to watch a ton of new movies and enjoy it.
  • honestaquarian
    I’m hearing bass notes that I didn’t hear before
    pitdogg2 Posts: 22,416
    edited April 2020
    two things
    1. Thank god there was no soldering :D
    2. Will the old cover not fit over the new power supply? that is what that cover was for correct?
  • honestaquarian
    Before👆🏾
    After👆🏼
  • honestaquarian
    two things
    @pitdogg2
    Yes it was. Again watch the video a few pages back. They say you can either put it back in place or not and leave it up to you. As you can see in the video they are using a different transformer than the one they use now.
  • BlueFox
    My apologies if I missed this, but did you upgrade the power cord. Your before/after pictures remind me of what happened when I upgraded to a Shunyata power cord on my Oppo 203. If not then a better power cord should really elevate your setup.
    F1nut Posts: 48,170
    Before👆🏼
    After👆🏼
    Some of the after pics look a bit better, but this one definitely looks worse.
  • honestaquarian
    edited April 2020
    I upgraded the power cord even before I got this unit. I just moved it to this one when I replaced the Oppo 103 with this one.
  • honestaquarian
    Before👆🏾
    After👆🏼
  • honestaquarian
    Before👆🏼
    After👆🏾
  • honestaquarian
    Before👆🏼
    After👆🏾
    I can see a difference between what I am seeing with the naked eye and after I take the pic. These pics do not do justice to what is on the screen. Hence the reason why you cannot see too much of a difference here.
  • honestaquarian
    Before👆🏼
    After👆🏾
    F1nut Posts: 48,170
    The last one, the after shows the blue much better.
  • honestaquarian
    Last one
    I really only took this one because I think the guy is effing hot!(*yeah I said it! I gotta read yous guys going on about womens all of the time😝😝😉)
    Before👆🏼
    After👆🏼
    Now on to the music🎶 🎼
    I think the Lightman is effing hot!(*yeah I said it!)
    Fixed! ;)
  • honestaquarian
    Fixed! ;)
    John
    Ima gowna fargon take ju feet and fargon feed den to ju ju fargon aisehole ju!!
  • honestaquarian
    Put this on repeat and burn her in overnight. I guess about a week of constant play ought to do it.
  • mantis
    mantis Posts: 16,671
    I got that disc somewhere. I haven't seen that in a long time. Wow memories
    Dan
