just 6 more of those and it might be enough to cover my CD, SACD collection
I really should put some effort into looking into a boltz system for them.
Yep. I have most of my CD's in the basement, but the one's in the office were just stacking up!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
nooshinjohn wrote: »
You first -
joecoulson wrote: »nooshinjohn wrote: »
You first
One step ahead of you...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I have a ton of CDs myself that I need to get rid of. The ones on the left are classical, and rock is on the right. Plus I have a big box of CDs in the garage. I guess this is another retirement project.
Three 20 amp circuits. -
That's what I'm talkin about!
Look at all the colors.
I like!
Organized too.
I can't wait to get back to my "pyramid tower"of relaxation Cds.Most people just listen to music and watch movies. I EXPERIENCE them.
Nice CD collection there, Bud!
Added a marine amp to the pontoon. It sounds so much better. Great upgrade.
What lake do you live on/near? Just asking, cause I'm coming over!
I used to live on Silver Lake!
Kitties are getting bigger and haven't clawed at the S55 grills in the bedroom system, so I figured it was time to go back to floorstanders. Found a pair of absolutely pristine LSI 15s for a nice price. If they leave these alone the 705s will be getting moved back in post haste. Try to ignore the kitty barricades.
I must say, at one time or another, I've owned 7s, 9s, and now 15s. The 9s, which I had on a pair of Sanus Ulimate stands prior to swapping in the 15s, were a better speaker. Listening 2 channel, no sub, the 15s have bloated flabby bass and lean way too much toward the bottom end. Anybody got a pair of Db840s they want to sell?
Hi, Dave. The 9's were my favorite in that lineup as well.
Tri Vista dac is about burned in at this point I would guess. Very happy with the results
https://youtu.be/TBMOgRv0oBU
Can you post a summary of what was done to it? What improved?
Thanks,
Harry
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
Quite a bit..
Wbt next Gen analog out and digital in and upgraded wiring
Mundorf and audio note power supply caps
Sparks dual board discrete op amps
Discrete voltage regulators
Changed most signal path resistors
Changed most signal path caps with audio note
Changed some diodes
Tube coupling caps, clarity cap mr
Output coupling caps, clarity csa
Not to be cliche, but this was a fairly substantial improvement. Micro detailing, staging, bass accuracy and impact.... I'm a frugal person and the money spent was worth it for sure. I run a passive line controller so my end result is pretty much up to my source.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It's DeoxIT® Day.....so many cables and connections!
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Trey will either bring his down here, or I will bring mine up there sometime soon to compare the differences between a stock Tri-Vista and his modified. He is trying to talk me into getting mine done as well.
Bought these bricks...^^^
Rocking my Polk Camden Square in the garage while re-finishing an oak desk for the Mrs!
You've got a lot of various odd tools, dowel rod and glue on that top.
Looks like a few projects going on at the same time.
Hehe. It was originally a roll-top. Filled the holes used to attach the roll-top with dowels instead of putty.
This thing needs a subwoofer!
I’m getting dizzy just looking at it...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »I’m getting dizzy just looking at it...
I wonder if there's a secret message in Morse code contained in the short and long "arcs" on that thing?
It says "SDA's are forever"The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I just swapped in my pair of Monarchy Audio SM 70 mkII's to drive the Nola Boxer 2's. I figured it was time to give my First Watt F5 a little break.See my profile for list of gear.
Thanks to @dorokusai I now have acquired & deployed a new, high performance, super-cool bias adjustment tool.
Just don't slip...
It’s sometimes just simple shite. 😀CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Received and installing the crossover upgrades for the LSi9s. This is the Fortress mod from our very own @VR3 Trey. They look amazing, its a shame they'll never be seen again after this evening
. Treys customer service is great and the crossovers were very well packaged as well, I must say. Pics don't do these things justice when they are in your hands!
I'm trying to upload photos but I am experiencing technical difficulties at the moment. Trust me I took about a dozen of them.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
