Equipment Racks
1246718
    Clipdat Posts: 13,100
    Trying to put together my VTI rack right now, and one of the points doesn't line up with it's recession below. It's "off" and not aligned properly. Not sure how to get around this.
  • kharp1
    kharp1 Posts: 3,453
    IS the post cross threaded possibly, causing it to be slightly canted> IDK, just spit balling.
    Nope. All of the points have screwed in fine so far with no cross threading or seizing issues.
    It's just the physical alignment of that corner's shaft I think. If I grab it super hard and pull it aligns, and then when I let go it goes back to misaligned. It's like the metal frame itself and/or the welds are slightly off.
    kharp1 wrote: »
  • machone
    machone Posts: 1,561
    It should align itself once the rack is loaded with equipment . I had one like that with my VTI.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Tony M Posts: 11,676
    Looks like that's one of the 12" legs. Right?
    edited February 2018
    I used my feeble nerd arms to use brute force and bend it, and now it's aligning better. Yay.
    machone wrote: »
    Edit: Tony, it was one of the 7" sections.
    Tony M wrote: »
  • TNTsTunes
    TNTsTunes Posts: 751
    Clipdat wrote: »
    Does the top side line up correctly?
    You could stick a pipe that just fits in it and try some manual persuasion. That should work.
    It just needs a bit of caressing.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    SCompRacer Posts: 9,121
    VTI has suggested to folks whack the leg with a rubber mallet. Experience with hammer wielding to achieve a desired result will help assure a positive outcome. One could dent the leg though.
    TNT's above suggestion sounds good. The caps come off easily, just be careful of the finish.
    Or like machone said, load it.
    Yeah, I see now in the instruction manual that they mention a rubber mallet may be necessary due to things getting knocked out of alignment during "shipping and handling".
    AKA, if your rack was made at the factory on a Monday vs. a Friday. :)
    F1nut Posts: 51,894
    They've had issues like that going back years and years and why I'll never recommend a VTI rack or stands. You'd think by now they would have fixed their quality control problems.
    I figured at this price point that the quality would be better than this.
    I had a few more alignment issues with another frame piece. The end caps did not seem to be hammered down all the way, they are simply not installed evenly. I couldn't get them to budge, but I might try putting a towel over them tomorrow and giving some light taps with a hammer to see if I can fully seat them.
    Additionally, two of the end caps that you screw the spikes into had little raised lips on the surface where the spike meets the cap - the metal wasn't completely flat like the others. As a result, the spike's alignment when fully screwed in is skewed and not straight/90 degrees.
    This isn't "oh it might have gotten misaligned during shipping", but rather straight up poor quality control.
  • marvda1
    marvda1 Posts: 4,954
    when you put equipment with weight on the shelf it will align.
    Puritan PSM156
    The section that I posted about earlier is the only one that required brute force to try to bend and fix the alignment, which I was able to do.
    The others are aligned as it stands currently, it's just visually disappointing to see the silver caps not installed correctly and two of the spikes coming down at something other than a 90 degree angle. That's what I meant about poor quality control.
    It's just not built to as exacting standards of fit and finish that I would expect for the price. Shrug.
    marvda1 wrote: »
  • halo
    halo Posts: 5,618
    Sadly, you never know what you're going to get these days. The rack I had from VTI had no issues whatsoever. Sorry about the trouble you're experiencing with it.
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
  • kharp1
    kharp1 Posts: 3,453
    Clipdat wrote: »
    marvda1 wrote: »
    Though these are nice looking racks, and, appear to be decent solid racks, they are, by far, on the lower end of the price spectrum when it comes to audio racks. If you can get it lined up after putting some weight on it, and are happy with the overall look and stability, I'd forget all about that little detail and be thankful that you got a nice looking, fairly stable rack at that price point. I'm still balking at spending somewhere in the $2K-$3k range for what is still a "fairly priced" rack. I'm seeing stuff in the $10k and up range.
    I should be used to it by now. It seems like with every major purchase I make there's something not quite right. I have bad luck I guess.
    halo wrote: »
    I would expect this quality out of the sub $100 Monoprice rack listed earlier in this thread, not a $400+ VTI.
    The caps not being assembled correctly and the spikes coming out at a wonky angle are more than a "little detail", imo. The fact is, it doesn't look like the product photo shown on their website.
    I get that made in China stuff can vary wildly in quality, but I don't think you'd be happy either if you just had purchased this, despite it being on the cheaper side of audio racks.
    kharp1 wrote: »
    It's pretty difficult to illustrate the issues in photos, but here are some anyway:
    All of the other metal shelf units are "acceptable", but this one should not have passed QC, imo. I'm tempted to just order another shelf.
    Viking64 Posts: 7,596
    kharp1 wrote: »
    Those are typically much higher maintenance.
    In a word: Yes.
    Plus, sometimes the "spikes" come out at a wonky angle.
  • kharp1
    kharp1 Posts: 3,453
    @Clipdat It looks like the end caps aren't seated properly. As if they went in slightly c@ck eyed and aren't seated flush thereby throwing off the projection of the spikes, or, the receiving cup. Might try taking the spike out and lightly tapping with a mallet, or dead blow, to see if they seat properly. Should use a piece of sacrificial wood covered in tape to keep from marring the surface.
    Yeah, I'd be a little ticked, but, would make a decision to try and fix, or, return it. No hill too high...
  • soundfreak1
    soundfreak1 Posts: 3,414
    In this price level that is inexcusable and totally unacceptable! I'd be raising hell.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Joey_V
    Joey_V Posts: 8,603
    My VTI is not anything like that one... everything looks good and aligned. I bought mine 10y ago.
    Sorry buddy, do they send you new endcaps or replace the stands in question?
  • Drew, I'm sorry to hear you have problems with the racks. I'll get with VTI today and see what they will do about this. I have never had any problem with alignment like this in the past with VTI racks. Sending you a PM about this.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    Having owned a couple of VTI racks, the end caps on the older racks were much thicker than the new ones.
  • delkal
    delkal Posts: 764
    kharp1 wrote: »
    I agree that the caps are not fully seated. But I think the bigger problem is the legs are not aligned. I would try and remove all of the endcaps and bend the legs till they are aligned with each other. Then place one on top of the other to check the fit and make sure the legs match up perfectly, it looks like yours are 1/8 - 1/4 inch off.
    And be careful bending! When everything lines up seat the endcaps fully with the mallet and wood.
  • dr1978
    dr1978 Posts: 424
    If you put your ear next to it can you hear a slight hum?
    Sorry, couldn't resist! Hope VTI takes care of you on this.
    Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
  • soundfreak1
    I wouldn't "bend" anything! (Loss of warranty). Send back for replacement or refund! Shouldn't have to bend it to make it right! Just very poor quality control. It can happen to any company (even though it shouldn't) what they do will speak volumes as to the company.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • delkal
    delkal Posts: 764
    I hope everything works out or you get a refund......... Its not good spending a lot of money on "cheap". But if you decide to spend a lot less for "cheap" check out this Sanus rack. Its only $120 shipped, can hold 200 lbs, and gets good reviews on Amazon. I know it is bare bones and not even close to most of the racks mentioned but it doesn't look too bad (at least to me). I just ordered one last night (before I looked at this thread). If anyone wants an update I will let you know when it gets here.
    https://newegg.com/Product/Product.aspx?Item=9SIA1CZ1G98946
  • Mike Reeter
    Mike Reeter Posts: 4,315
    delkal wrote: »
    I like the Simplicity of these racks, I tried to mimick their look in my Racks
  • kharp1
    kharp1 Posts: 3,453
    Read the earlier post where the manual/instructions suggest using a mallet.
