New MIT cables, adjustable articulation!
    xcapri79 wrote: »
    heiney9 wrote: »
    Theory is a necessity for understanding and serves as the basis for design and testing.
    One has to have an idea about what one is doing, no?
    Of coarse they do, if your building widgets, but audio isn't a widget and sound has too many variables to make it one.
    Theory is relative in audio, it's the testing part that becomes pretentious because there is no basis for continuity, no baseline when it comes to hearing, no preference to meet all requirements.
    That's the difference X, you want it to be one size fits all with charts and tests, doesn't work that way in subjective matters.
  • agfrost
    agfrost Posts: 2,497
    Haven't had to use this one in a while. Not going to visit this cesspool of a thread often enough to make sure it gets posted right after its "inspiration", so you all can guess...
    Jay
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2016
    xcapri79 wrote: »
    Who hears at 80 kHz, 166.25 kHz, and 338.75 kHz?
    I don't think even your super hearing goes that high. I doubt Tonyb's does either. lol
    xcapri79 wrote: »
    What is the relevancy of a 338.75 kHz test to audio?
    Due to the concept of subharmonics, frequencies above the range of human hearing can affect what is heard. For example, a fundamental tone at 100,000 Hz will have subharmonics (undertones) at 1/2, 1/3, 1/4, 1/5, 1/6, etc. of the fundamental or 50,000 Hz, 33,333 Hz, 25,000 Hz, 20,000 Hz, 16,667 Hz, and so on.
    The first CD players sounded harsh because they used filters that cut off everything above 44.1 KHz. These "brick wall" filters introduced subharmonic noise into the audible frequency spectrum which caused harsh sound. The industry then moved to 8X oversampling filters (352.8 kHz), which moved the undertones of highest energy far outside the audio range.
    xcapri79 wrote: »
    xcapri79 wrote: »
    Care to explain, "This is a very important result. It means that an ideal audio cable would have a power factor of 0?"
    There is the Zero Power Factor (Potier) Method for calculating alternator performance characteristics:
    http://www.learnelectrical.net/2015/06/zero-power-factor-zpf-method-potier-triangle-method-to-determine-voltage-regulation-alternator.html
    Then there is the zero power factor concept with regard to cables and transmission lines:
    "The power factor is by definition a dimensionless number between −1 and 1. When power factor is equal to 0, the energy flow is entirely reactive and stored energy in the load returns to the source on each cycle. When the power factor is 1, all the energy supplied by the source is consumed by the load. Power factors are usually stated as "leading" or "lagging" to show the sign of the phase angle. Capacitive loads are leading (current leads voltage), and inductive loads are lagging (current lags voltage).
    If a purely resistive load is connected to a power supply, current and voltage will change polarity in step, the power factor will be unity (1), and the electrical energy flows in a single direction across the network in each cycle. Inductive loads such as transformers and motors (any type of wound coil) consume reactive power with current waveform lagging the voltage. Capacitive loads such as capacitor banks or buried cable generate reactive power with current phase leading the voltage. Both types of loads will absorb energy during part of the AC cycle, which is stored in the device's magnetic or electric field, only to return this energy back to the source during the rest of the cycle.
    A negative power factor (0 to -1) can result from returning power to the source, such as in the case of a building fitted with solar panels when their power is not being fully utilised within the building and the surplus is fed back into the supply."
    Reference: https://en.wikipedia.org/wiki/Power_factor
    The theory expressed on MIT's website with regard to cable zero power factor is in agreement with the theory I cited above, and is in agreement with cable noise theory regarding the abatement of spurious noise due to cable dielectric absorption.
    xcapri79 wrote: »
    Agreed. Come back and discuss once you have attained a better understanding of zero power factor theory, a concept which you obviously were unaware of. Since you have a BS degree in electrical engineering, I assume gaining an understanding of the concept will be trivial for you.
    xcapri79 wrote: »
    Agreed again. I would also add "one should practice what they preach" to that.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Can't we all just get along and buy wireless speakers?
    I'm beginning to hate MIT and Emotiva. :#
  • DarqueKnight
    The ideal power factor for real power transfer (i.e. power to do work like making a speaker produce sound) is 1 (one) not 0 (zero).
    You are assuming a speaker is purely a resistive load, it's not. I'm surprised as an electrical engineer that you don't know that.
    X only presents partial theory that appears to agree with his agenda...just like the Roger Russell and Audioholics websites.
    F1nut Posts: 52,406
    Let's put some perspective on the matter. The provided link lists the world's most expensive gear. There are different categories, this one is for speakers.
    http://www.higherfi.com/spkrlist/speakerlist.php
    So, is a pair of million dollar speakers that much better than a thousand dollar pair to justify the price? I don't know, but I'd sure like to hear them.
    You see X, that's the difference between my open mind and your closed one.
  • [Deleted User]
    edited May 2016
    Nothing like a good cables don't matter or
    CD vs. vinyl vs. media player debate.
    The real suckers are those that buy those expensive power cables.
    It's their money but whewww. When I was a kid I wouldn't listen
    to TV commercials for fear of being brainwashed. I won't try
    anything other than stock cables from the manufacturer for the
    same reason.
    F1nut Posts: 52,406
    Nothing personal, but that's a foolish way to think.
  • polrbehr
    polrbehr Posts: 2,877
    same reason.
    Please don't tell us you wore tinfoil hats too ;)
    Sorry man, just bustin' them a little, but subliminal advertising is multi-media, sight and sound, so turning the volume down only halved your exposure. Google the word
    tachistoscope...
  • [Deleted User]
    "Sorry man, just bustin' them a little, but subliminal advertising is multi-media, sight and sound, so turning the volume down only halved your exposure. Google the word
    tachistoscope..."
    I did frequent the drive-in theater...
  • [Deleted User]
    Imagine having your wife help you pick out a pair of these speakers
    (even the color) and then going over to your friends house and
    HIS wife helped him pick out the exact same ones, even the color.
  • polrbehr
    edited May 2016
    I'm sure you did.
    Because they wanted you to.
    I heard that theaters were the original testing ground for those types of ads,
    but who knows? I think it's nonsense myself.
    Gotta run, for some reason I feel like having a Pepsi???
    mhardy6647 Posts: 35,562
    I have nothing to add to this thread, but I was just thinking -- I, also, have adjustable articulation. Beer works quite well -- three or four, and I would start slurrin' pretty good.
  • lightman1
    lightman1 Posts: 10,803
    Yeah! Who doesn't like fried flounder??!!
    Deeeeeelish!
    gudnoyez Posts: 8,223
    agfrost wrote: »
    Ok let me see a picture of what appears to be dew on the grass, some one shhh' ing and a bag. I have been up all night trying to think this out can't seem to figure wait a minute it just came to me. Ha ha ha, I bet this is directed towards a certain non believing individual this is to funny.
  • mrbiron
    mrbiron Posts: 5,721
    I thought it meant
    Dew+finger+brown paper bags.......
    You know, if you hadn't posted the above, I wouldn't have invested the incremental effort to decode the three images (which are sort of like a rebus, but without any letters, just pictures, come to think of it).
    Three images -> three syllables to evoke two syllable word (sometimes writ as two words).
    https://youtu.be/K_b3oPslctA
    nbrowser wrote: »
    [.... but the sum is worth more than the parts individually imho. There's my contribution to this argument.
    ....and a solid opinion that is. :)
  • vmaxer
    vmaxer Posts: 5,124
    I didn't get it till now, funny.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • halo71
    halo71 Posts: 4,645
    Pfffttt....then people would be arguing over the purity of the air in the room. And how it relates to the best sound. We'd be seeing $100k air purifiers from MIT.
    --Gary--
    msg Posts: 10,650
    this forum needs an official KennethSwauger appreciation day. some of the stuff you guys come up with to juuust barely skirt the rules has me dyin' laughing. and I'm sure Ken coming close to cursing.
    F1nut Posts: 52,406
    edited May 2016
    I'm offended. Don't ask why, I just am.
    EndersShadow Posts: 17,762
    edited May 2016
    https://youtu.be/fHMoDt3nSHs?t=3m36s
    F1nut Posts: 52,406
    You can ask, but I ain't saying
    edited May 2016
    I think Mit took their cue about "adjustable articulation" from Viagra. You can adjust....so to speak....by taking half a pill, a whole pill, 50 mg's or 100 mg's. Take 2 100 mg pills and you can handle the whole Dallas Cowboy cheerleader squad......you may not be alive afterwards though.
  • mrbiron
    tonyb wrote: »
    Challenge accepted!
  • madmax
    madmax Posts: 12,434
    I'm glad I don't have any of this emotiva stuff, I'd hate to think I had something that even MITs couldn't help the sound of.
    Vinyl, the final frontier...
    madmax wrote: »
    Lmao !!
    Even your new dac would have a problem. :p
  • DarqueKnight
    I'm holding my breath waiting for X to come back and finish his tutorial on power factor. :)
  • Stew
    Stew Posts: 645
    tonyb wrote: »
    ... or just a pinch so you don't p on your boots.
    SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
    1000VA Dreadnought
    Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
    Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
    RTiA3, Onkyo TX-SR605
