Spearker cables..fact or fiction?
suprafantx wrote: »I have both cat5 and cat6 cables. I just found out that cat5 has solid wires and cat6 has stranded wires. Which one will make better speaker cable?
Try it and find out."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Neither.Political Correctness'.........defined
President of Club Polk -
Hey Sea...
Are you going to post in any 'other' thread on this site. Or is it just a ObsessiveCableCompulsive D.? With your knowledge 'you' should be all over this site, no?
Slowly emerging from the 90's
Fronts: Polk LSi15's
Center: Polk CS350ls
Pre: Sony STRDA555ES
Amp: Rotel RMB-1075
Sub: Velodyne SPL-1000
TV: 46" Sharp Aquos LCD
Dust magnet: Sony PS3 -
I took me like 90 minutes to terminate only one side. Sliding 24 gauge wires is pain in the a$$.Living room
Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
Player: Oppo 95.
Amps: Bryston 4B SST, B&K Ref 200.7 S2.
Pres: B&K Ref 50 S2, Paraound P5.
Subs: Dual Rythmik F15HP subs.
Man Cave
Speakers: Martin Logan Vistas.
Player: OPPO 105.
Preamp: B&K Ref 50 S2.
Amp: B&K Ref 125.2 S2
Sub: Rythmik F12.
Sub management: SMS-1.
Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
Room treatment: GIK Room Kit #1. -
I personally would use neither Cat5 or Cat6 as speaker wire, but here is a few pics anyways.
Cat5
Cat6
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
here is another picture where CAT 5 was used successfully...
the lower end was substantial and held the 'bass' and the high end was tight as a knot. -
CAT5 can also be stranded. There are solid core and stranded versions of each.
The difference you might ask? Stranded core is meant for patch cables (either populating the rack or wall to computer/Ethernet device). Solid core is intended for infrastructure runs.
Stranded will hold up much better to constant bending. If you bend a metal coat hanger enough it breaks. If you bend a stranded cable of the same gauge, much different. -
Do any of you Cat5 guru's even know what the rated characteristics are with Cat5 wire before you have altered it's capabilities?
Come on Cat5 guru's. You can answer that one simple question, right?
Those with degrees should be able to tell me over what kind of length and degree of bend, along with the amount of bending limits acceptable before you are now out of tolerable range of specifications for the electrical performance as well.
I gotta run to Polk HQ and see some folks but I'll be back to check out the educated answers. That should give all of you Cat5 guru's plenty of time. It would be nice if you could link where you find your answers, unless you learn something you don't want to reveal. :eek:~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
CAT5e is rated for 350Mhz, bend radius is 4 times the diameter of the cable.
Runs are limited out at 328ft but with most modern transceivers you can get 380ft.
No more than 1/2 inch of untwisted pair for termination due to NXT. Been doing plenty of POE with CAT5 as of late. Can't wait the for the next standard: 32Watts baby! -
Somebody PLEASE print this up in poster size! I'll pay you for it.
That's a keeper. -
That's a keeper.
I gotcha 8.5x11 buddy, but that is all I can do. Download it and bring it to kinky's. Edit pick up 10 copies;) Great stocking stuffer for some Polkies;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »I think this is the one that I want in poster size.
I want one of those too. The only thing is I am dissapointed that my name didn't make it on there:(Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yes...I was disappointed that I wasn't included too. Perhaps we can get a modified version?:pThe nirvana inducer-
Well I would say something smart, but according to the newbs lately I can't:(Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I have the picture of the cat.:p It is heavy.
:p:p Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
Hey curt, SHUT UP!!! This here's about spearker wires... keap yer Emohtuva comments in the Emohtuva thred.:mad:
mdaudioguy wrote: »Hey curt, SHUT UP!!! This here's about spearker wires... keap yer Emohtuva comments in the Emohtuva thred.:mad:
lmao
I'm still trying to figure out what a spearker cable is.
Bump, back to the top we go!:)
EDIT: never mind. No more 'cable' posts for me...
EDIT: ditto!
+1
That is what I want to know also. While waiting for the answer, I am making one and check it out myself. Anyway, it was fun for me to experience making speaker cable.
Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
suprafantx wrote: »+1
What, this post not enough? -
Bottom line is some people have had good luck and others no luck and yet more bad luck with Cat 5. I don't have the time or want to put forth the effort to build a pair to find out. I'm perfectly happy with the synergy provided by my MIT's.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
My experienment is fust for fun. I don't care if it is good or bad at the end. I do not use cat 5 cable. I am using cat 6 shielded cable because I talked to a friend and he explained to me that a good cable is not only base on the quality of the cooper or silver wires, the shield also is an important part of quality cable.
The reasons I picked cat 6 shielded cable:
1) It is better than cat 5.
2) It is shielded.
3) Very easy to customize the size of the speaker wires ( add on latter if I want to):pLiving room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
