Spearker cables..fact or fiction?
1…1213151718…71
  • BlueFox
    BlueFox Posts: 15,250
    edited March 2009
    One point that is being overlooked in the Cat5 discussion is that Cat5 cable is designed to allow a specific amount of signal degradation, distortion, attenuation, etc. This distortion is perfectly acceptable in the transmission of digital data.
    Let me try to explain what is occurring when digital data is transmitted. Leaving aside encoding methods, the transmitting device will generate a digital signal to be sent on the wire. For example, let’s say 10101010101010 is being transmitted. The transmitter will turn on, and the signal will go to +5v, and stay at that level for some period. Then the transmitter will turn off, and the signal will drop to 0v for some period. This will repeat until the data has been transmitted.
    If you look at the transmitted signal with an Oscope the transmitted signal will appear to be a well formed square wave. However, the signal received at the other end of the Cat5 cable will not look at all like a well formed square wave. It will be greatly distorted. Rather than switching between 5v and 0v, it might now reach 2v. Rather than being a square wave, it will look like a distorted sine wave.
    And this is perfectly fine as long as the distortion is within the Cat5 design specifications. Because of this specification, the receiving equipment is able to reconstruct the original data from the received distorted data. In data transmission, both the transmitter and receiver are active components.
    This is the point that is being overlooked in trying to use Cat5 cable as speaker cable. Cat5 distorts the signal, but the distortion is defined to be within certain parameters, which allows the receiver to reconstruct the original data from the received distorted data.
    However, in the audio world, only the amplifier is active, and the speaker is passive. This means the speaker will play whatever signal is fed into it. The resulting sound will depend on the amount of distortion the cable has introduced into the original signal. In my mind, this is how different speaker cables can sound different. Some might introduce minimal distortion. The signal at the speaker is almost the same as the signal leaving the amp. Other cables might introduce more distortion, but the distortion is of a nature that the sound appears “better” to the listener. Still others will just suck in how they sound.
    It appears to me that there is probably a particular cable type that will work optimally with every system, and that cable can only be found by trial and error experimentation. It all depends on the electronics, speakers, and cable length.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited March 2009
    Every System is a combination of its unique components with the listener as a primary one.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    Active 24db LR slopes. I have been studying digital XO's that use a PC and sound card for testing purposes. I have a decent sound card with sockets for the OpAmps and 8+8- rails so I can change them out when I want. I just put some BB/TI OPA2134's in there for now. All I am driving is some small planners with the PC. Post some links later of your work. I love DIY.
    Ben
    Ben
  • seafire
    seafire Posts: 459
    edited March 2009
    ben62670 wrote: »
    Ben
    I ran self modded jobs Originally from the Alpine car audio range they are pra h400 digital proccessors that one of my friends(electronic engineer) upgraded for me in terms of s/n ratio channel seperation etc.They were pretty good out the box 100 db sn.They are three way crossovers with variable slopes 6-24 dbs featuring 3 pairs of burr brown 18 bit dacs (one per channel).Sounded amazing but somehow to clinical if you know what I mean.Interesting part was time alignment and phase shift correction in the end they helped me dial in some of my best passive x overs;) .
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited March 2009
    This thread makes me want to eat a live koala baby. With a spork.
  • seafire
    seafire Posts: 459
    edited March 2009
    BlueFox wrote: »
    Ok interesting read but we found virtually no distortion on the 3 m lengths we tested with a occilo .I think this becomes prominent on long cable lengths sorry edit: but then again we did not find any on most short lengths of cable only with extremely thin cable and hi volume output sorry edit again I tend to agree with the last part of your statement...wow eventually some good clean debate :):):)
  • ben62670
    edited March 2009
    Had one the other night. Then I ate it.
    Ben
    heiney9 Posts: 25,711
    edited March 2009
    seafire wrote: »
    And we're just supposed to take your word for it...............because your Seabiscuit!!!!
  • seafire
    seafire Posts: 459
    edited March 2009
    heiney9 wrote: »
    Hmm well its not that hard to setup youself if you have access to a scope try it you may like it;)
  • AudioGenics
    edited March 2009
    seafire... your post has been "Mega" (actually Kilo) Viewed ! Over 5K
    edited March 2009
    Just read my sig..............thats what I truly believe. Not that measurements aren't a tool to be used, but in the end it's mostly subjective. I'm off to listen to music and enjoy the system I have so carefully put together for my own enjoyment....no one else's.
    edited March 2009
    Hey buddy this isn't his thread.............he didn't enter until a couple pages ago (give or take)
  • seafire
    seafire Posts: 459
    edited March 2009
    heiney9 wrote: »
    Good enjoy I will be too a little later though:mad:
  • seafire
    seafire Posts: 459
    edited March 2009
    well Joseph H9 is correct I just hope it evolves into something nice and usefull for us all to share
  • AudioGenics
    edited March 2009
    heiney9 wrote: »
    You are So Correct... where is the originator - bobt -
  • scottnbnj
    scottnbnj Posts: 709
    edited March 2009
    seafire wrote: »
    Not at all upset just hoped to get some clarification on why and some debate on my views trust me I'm not upset just dishing back what's been flung at me;)
    i don't know. some believe i have a special gift for detecting when someone's upset, but if you say you weren't...
    anyway, it's nice that you seem a bit more at peace now with the fact that others can hear differences in cables too. now, if you can just get past your anxiety over others chosing for themselves which different sound they like best you'll be on a solid path toward full recovery.
  • seafire
    seafire Posts: 459
    edited March 2009
    scottnbnj wrote: »
    Ok not to go down this road again but really scroll back through the posts..I never said there is NO difference I merely said that In my opinion the differences are over rated once you reach a certain quality in your speaker cables other things would give much more instant return than speaker cables starting off with the general quality of ones gear;)At peace was always more happy yes- as like others I come here to share and learn other opinions :)
  • ben62670
    edited March 2009
    Ben
  • tcrossma
    tcrossma Posts: 1,301
    edited March 2009
    seafire wrote: »
    I tend to agree with you on this. But let's be honest, that is really not what you started off saying, or at least that's not how it came across to me. I use cables to "fine tune" my system. No one is saying that expensive cables are going to fix a crappy system. Not only that, but many have stated that you do not have to spend a lot of money to get a good cable -- but you tend to gloss over those posts and only concern yourself with the other more controversial posts.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • megasat16
    megasat16 Posts: 3,521
    edited March 2009
    I failed to see the relationship (numerically) between Mega and 5K viewers. :o
    Perhaps, you meant it's Kilo Viewed? :)
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • inspiredsports
    inspiredsports Posts: 5,502
    edited March 2009
    seafire wrote: »
    Peace bro. Now we've got it. You love Cat 5. It works for you.
    Kimber, MIT, others at the top, and lots of mid-stuff works better for many more.
    No matter what the price, we like our stuff better than Cat 5.
    'Nuf said.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited March 2009
    Kex wrote: »
    I'm worried about you Dude. I'm wondering if you use a similar argumentative know-it-all approach when dating, 'coz I bet that ain't workin' out too good (Imagined scenario: No! Don't put all your clothes back on and leave! I'm telling you that it has been scientifically proven that size doesn't matter!). Maybe that might also explain all this pent up stress your are exhibiting in your posts (all those pent up spermatazoids can't be a good thing - maybe they eventually back up all the way to one's brain).
    Anyhooo ... best of luck Farty! Sorry to be rude, but you did barge in here with a lot of loud noises and I'm just bored, like Ben, even if it is not raining here.
    P.S. Oops! Sorry for the intrusion: it looks like the thread was actually about to get serious!
    Kex
    I don't know you but you are cool :D This had me laughing and I honestly think you are 100% right on target.
    Just another thought since I can't keep out of this, this guy is not legit and he makes it obvious. Probably banned from here before, of course under a different name, and is just looking to have fun and contribute nothing.
  • seafire
    seafire Posts: 459
    edited March 2009
    NJPOLKER wrote: »
    Kex
    Hmm nice try aint gonna sucker me into it luckily opinions are like arseholes we all have one including yourself;)
  • seafire
    seafire Posts: 459
    edited March 2009
    'Nuf said.
    Enjoy brother:D
  • NJPOLKER
    edited March 2009
    seafire wrote: »
    Having one and being one is two different things :eek: and I think everyone knows where you fit into the equation.
  • scottnbnj
    edited March 2009
    seafire wrote: »
    heh. of course. i remember you stated that the audible difference was on the order of 0000.0015%.
    anyone that hears differences like that has my props.
    just the same, why the anxiety over someone else chosing to go with the cable that's 0000.0015% better than yours?
  • seafire
    seafire Posts: 459
    edited March 2009
    scottnbnj wrote: »
    No anxiety what about the reverse what about everybody else.Their anxiety that I dare choose cat cable of their chosen brands ..how dare I and not even engaging in open dialog..just one insult after the other gimme a break will yah:rolleyes:
    edited March 2009
    seafire wrote: »
    Just so we're clear the insults are for your approach and attitude NOT because you choose to use something different. Let's not try and confuse the facts. You seem to relish in twisting the situation to fit your needs.
    If CAT5 works for you............get your groove on and be happy, but lose the holier than thou attitude and stop challenging everthing/everybody at every turn like YOU have something to prove.
    That's why people are giving you a hard time. But, I thought you would have gotten that, as smart as you seem to think you are.
  • seafire
    seafire Posts: 459
    edited March 2009
    heiney9 wrote: »
    Ok Heiney in one post I spoke about the monkey on someones back what makes you say I think I'm smart? Again that's YOUR OPINION so I will shut up and respect that now return the favour BE DONE WITH IT:mad:
  • seafire
    seafire Posts: 459
    edited March 2009
    I dont think I'm smart
    I KNOW IT:):):)
