$2.94 a gallon and dropping
2456789
  • thebluemonkey
    thebluemonkey Posts: 190
    edited October 2008
    heiney9 wrote: »
    Illinois is still at $3.55 most places. Now OPEC says they don't like oil being below $100 so they are considering cutting production. It never ends!!!!!!!!!!
    If that isnt a reason to start really doing something about altenative energy i dont know what is.
  • audiobliss
    audiobliss Posts: 12,518
    edited October 2008
    Or tapping into our oil reserves here at home!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2008
    $2.89 here, shame on me for being happy about it. They sure know how to condition us don't they.....
  • exalted512
    exalted512 Posts: 10,735
    edited October 2008
    bobman1235 wrote: »
    Also, all this entitlement attitude that we deserve fuel under 3 bucks a gallon is kinda funny. Gas has been vastly underpriced for us in America for a long time, it was bound to catch up with the rest of the world. I don't like it, don't get me wrong, but I'm not delusional enough to think it's so unreasonable. We've just all been spoiled by cheap gas for too long.
    100% correct. Gas is really only like 70 cents more expensive/gallon than in the 1960s. There was a long, long time where we were paying a lot less than what we were if you take into account inflation rates over the years.
    -Cody
  • Lowell_M
    Lowell_M Posts: 1,660
    edited October 2008
    heiney9 wrote: »
    Yes most cars (if they are newer) have adaptive timing, but they can only **** or advance so much based on the manufacture tuning parameters. So you can get pinging if you use lower octane fuel simply because the manufacturer tuned the ECU with only so much adaptive capability. Some cars are better than others.
    Generally the more performance oriented the car is the more picky it can be about octane. My car is chipped and the chip is optimized for 93 octane fuel w/ a 10.5:1 compression ratio. In the dog days of summer when it's hot and humid if I use anything less under hard acceleration I get pinging, so all Summer I use 93. Later in the year towards Winter I use 91 octane. Saving .10c a gallon isn't a big deal so I almost always fill up with 93 octane Shell Ultimate.
    Each cars ignition, timing and fuel maps are different and change based on load and atmospheric conditions. Bottom line is if you are getting pinging and your plugs, wires, etc are in good condition you need to bump up the octane of your fuel or investigate why it suddenly started pinging when it didn't before.
    Delicate electronic parts and sensors do fail (like knock sensors) so it's best to have that stuff checked out if you have problems.
    +1 here. The engine in my car has quite high compression (in the 10.something:1 range) and requires 92 or higher octane. If I put anything lower in the tank, gas mileage and power go out the window. I don't mind an extra couple dollars a tank to get the power that I paid for in the first place with the car...plus I get some of that back in gas mileage.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • SKsolutions
    SKsolutions Posts: 1,820
    edited October 2008
    3.39 for knock and ping.
    -Ignorance is strength -
  • Strong Bad
    Strong Bad Posts: 4,278
    edited October 2008
    ND13 wrote: »
    At under $90 a barrel, shouldn't gas be well under $3 just about everywhere? At over $140 a barrel gas was right around $4.09. It always seems to adjust upward a lot faster than adjusting downward.
    I was just wondering the same thing. Oil dropped below $80 a barrel today. It should be $1.00 a gallon cheaper than what it is.
    My **** hurts!
    No excuses!
    treitz3 Posts: 19,951
    edited October 2008
    The politicians are too consumed with greed and corruption to concern themselves with greed and corruption on a lower level.
    It seems "we" are on a back burner and that we had better get used to it. That's my take, at least.
  • danger boy
    danger boy Posts: 15,722
    edited October 2008
    $3.49 here... and dropping. i think it'll stop dropping pretty soon though.
    why is it that the economy is bad, and yet gas prices are dropping? we're still using the same amount of gas we were a year ago.. when it was way over $4.00
    PolkFest 2012, who's going>?
    heiney9 Posts: 25,408
    edited October 2008
    danger boy wrote: »
    No, demand has fallen. Maybe you are using the same amount but on average demand is down; atleast that what they tell us.
  • Jstas
    Jstas Posts: 14,976
    edited October 2008
    danger boy wrote: »
    Economic slow down means less people buying stuff. The less stuff being bought, the less stuff that has to replenish stock in the stores. If less stuff is going to the stores, less fuel is being burned to transport it to the stores.
    The average consumer buying gas for a commuter vehicle is not nearly as big a dent in demand as things like trucking companies, shipping companies, train companies, airlines and so on.
    Expert Moron Extraordinaire
  • Mike Kozak
    Mike Kozak Posts: 931
    edited October 2008
    cmy330go wrote: »
    What year is it? Chances are it's got electronically controlled ignition which will **** timing to avoid pinging or knocking. It won't hurt the engine, but it will just make it pretty sluggish.
    I one time had to put standard gas in my Lexus GS430. The car ran just fine. It's just that it felt like I lost about 70hp.
    It is a 1992 Touring Sedan DeVille with a 4.9L V-8, needs the good juice. currently 48000 original miles in pristine condition
  • goingganzo
    goingganzo Posts: 2,793
    edited October 2008
    well when gas is $3 a gallon 20 extra cents for 92+ octane is not bad.
  • marvda1
    marvda1 Posts: 4,940
    edited October 2008
    funny, it seems as the stock market drops so does the price of gas.
    Puritan PSM156
  • george daniel
    george daniel Posts: 12,096
    edited October 2008
    just filled up at "racetrac",, 3.68.9 gallon--87 octane---georgia :(
  • Polkitup2
    Polkitup2 Posts: 1,640
    edited October 2008
    $2.87 just now in Minnesota.
  • NotaSuv
    NotaSuv Posts: 3,871
    edited October 2008
    2.94 yesterday when I posted first thread................today down to 2.87.....one year ago it was at 2.76 here...... at this rate it will be lower than a year ago prices....no complaints here..now I am just trying to rent a large tanker or 2 to fill and bring to the South Eastern US to cash in on those high prices ;)
    wow
    Polkitup2 beat me by mere seconds LOL
  • Early B.
    Early B. Posts: 7,900
    edited October 2008
    Just got back from the Chevron gas station here in metro Atlanta. Premium was $4.69! Regular was $3.75. Across the street premium was only $4.15. Not sure why the huge price difference.
    "God grooves with tubes."
  • ND13
    ND13 Posts: 7,601
    edited October 2008
    Got 87 for $3.05 in Indy this afternoon.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
    edited October 2008
    $3.49 for the cheap stuff in Illinois. Of course we have the most corrupt governor in the U.S.
  • NotaSuv
    edited October 2008
    Keiko wrote: »
    3.87, 3.99 and 4.09 here yesterday when I filled up. I don't care what anyone says about how we've been paying less than other countries, yadda yadda yadda. These oil companies/OPEC and affilliates(for lack of another word which I won't use here) are a bunch of greedy ****. 'F' em' all. :mad:
    Yes my friend there is a price to pay for livin in PARADISE :D
    funny thing is gas has always been refined on the islands costs the same price as the mainland but always higher per gallon than the mainland....I remember gas was more expensive on Farrington near the refineries than it was on the windward side ....go figure
  • NotaSuv
    edited October 2008
    LOL 2.79 this morning I saw on the way to work, down another 5 cents from yesterday....
  • bobman1235
    bobman1235 Posts: 10,822
    edited October 2008
    Keiko wrote: »
    I'd like to soak some corporate testicles in kerosene, then light em.
    :eek: Tell us how you really feel Keiko :)
  • Lowell_M
    edited October 2008
    heiney9 wrote: »
    $3.39 for 88 this morning... I filled up with 93 for $3.55.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • sucks2beme
    sucks2beme Posts: 5,681
    edited October 2008
    Oil prices were driven by speculation. Gas prices were based on oil price
    and refinery capacity. The gas guys haven't built any new refineries in
    decades. Kinda like the electric market, not enough capacity=higher prices.
    A little glitch and you're in trouble. And we've got more than a little glitch
    in the gulf.
  • BAD ASP
    BAD ASP Posts: 361
    edited October 2008
    I live in the northwest suburbs of Chicago in good old Cook County. On the way into work this morning Shell regular was $3.75 gallon.:mad:
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
  • Airplay355
    Airplay355 Posts: 4,298
    edited October 2008
    3.19 here in Maine...it goes down a few cents every day...yesterday is was 3.24
  • exalted512
    edited October 2008
    Tuesday it was 3.29, this morning it was 3.23 when I went to school. I needed to fill up but i was running late, so i didnt. got out of school and the price was 3.09. Chalked it up to being late is one of my best virtues.
    -Cody
  • Danny Tse
    Danny Tse Posts: 5,206
    edited October 2008
    $3.49 in Dublin, California....40 minutes outside of San Francisco. Lucky I averaged over 36 mpg in my non-hybrid Honda Civic :D
  • tboo72
    tboo72 Posts: 225
    edited October 2008
    $3.07 here in Tucson yesterday
