1153154156158159185
  • xsmi
    xsmi Posts: 1,797
    xsmi wrote: »
    Early Christmas gift to myself. I bought 25-30 used records last month that I’ve yet to listen to, because the first one I pulled out was really dirty. Found out that Project lowered the price on these by $250, so I pulled the trigger at my local dealer. VC-S2ALU.
    Curious to hear what you think. I'm sure it works well, but is it "well worth" the discounted price, as the sale makes it much more tempting.
    This is my first machine. However, I can say that there is less snap crackle pop.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • guyincognito
    @dromunds
    The Rega tables don't have much in the way of adjustment. I have replaced the felt mat with a Teac washi paper mat that is slightly thinner but otherwise it's all Rega (table, cart, phonostage).
    It sounds great and truthfully isn't loud at all. It's just the Benchmark pre and dac have zero noise. Pitch black background when streaming digital music. Now I notice the subtle background noise when the phono stage is on, even before I drop the needle. Has me thinking a upgraded phono stage might even the playing field again.
    Rega Planar 8, Apheta 3 MC , Aria mk2 Phono
    Aurender n100h, Benchmark DAC2 HGC
    Arcam SR250, Parasound JC5
    Revel F208, SVS SB-4000
  • skipshot12
    skipshot12 Posts: 1,017
    xsmi wrote: »
    xsmi wrote: »
    Excellent,
    I have an old VPI 16.5 and it does a great job at reducing the clicks, pops and vinyl rush.
    One thing I found was I needed one of those anti-stat guns before removing the lp from the RCM. Helps a shart ton...
  • jdjohn
    jdjohn Posts: 3,014
    I have a Benchmark HPA4, and understand what you mean. Utilizing the XLR/balanced connections might help reduce noise, so consider a phono preamp with those outputs. I use a Musical Fidelity Nu-Vista Vinyl, and it is very quiet.
  • zarrdoss
    zarrdoss Posts: 2,562
    I tried out a set of Martin Logan's and am asking myself why I did not try them sooner?
    nooshinjohn Posts: 25,136
    zarrdoss wrote: »
    Just skip over them and go straight to Magnepan.
    treitz3 Posts: 18,418
    Wow...welcome back to the forum. Long time, no hear from!
  • zarrdoss
    Tom, Thanks for the welcome back.
  • zarrdoss
    zarrdoss wrote: »
    Meh, besides the more expensive models I never really cared for them.
  • jbreezy5
    jbreezy5 Posts: 1,141
    zarrdoss wrote: »
    zarrdoss wrote: »
    It’s kinda like comparing high sensitivity drivers to average/low-sensitivity drivers, or tubes vs. solid-state.
    Completely different sonics.
  • erniejade
    erniejade Posts: 6,317
    zarrdoss wrote: »
    I could be off but, with the Logan, you don't have to worry about integrating a subwoofer since the Logans have a woofer built in.
    I know both can be a bit difficult on setup and very sensitive to room acoustics and placement.
    I have heard both Logans and Maggie's sound amazing and horrible, depending on the room and placement.
    VR3 Posts: 28,120
    One of these here this coming week...
    See how the ANK stacks up!
    mhardy6647 Posts: 33,103
    A New Years resolution: playing with these -- Altec 409 Duplexes (well, Altec does call 'em that! ;) ) in EV Coronet enclosures. Put them in the enclosures yesterday (replacing the EV Wolverine LS8 twincones that were in them).
    A short listen yesterday evening was pretty encouraging (believe it or not).
  • JayCee
    JayCee Posts: 1,481
    edited January 2023
    I'd expect descriptors like "aggressive", "not for the faint of heart", "claw-like" and "wild" w/the "Wolverine" name and badging. At the very least..."bada$$". Kind of underwhelmed w/...
    pretty encouraging
    LOL. Should be a fun project. Cheers to working on a New Year resolution. I'm busting and pouring cement in the basement.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    edited January 2023
    The Wolverines were "entry level" -- but I guess it's a Michigan thing. :)
    For what were bargain-priced drivers, they were beautifully made, with nice cast baskets and two-inch edgewound copper ribbon VCs. Very sensitive, with excellent midrange.
    source: https://worldradiohistory.com/Archive-Catalogs/Allied-Catalogs/Allied-Catalog-1960.pdf
    The image labeled "LS12" is an LS15, and vice versa. :p
    I take it you set them up with a low powered tube amp? SET?
    treitz3 wrote: »
    Well, not yet :p ATM, they're hooked to that dump find Yamaha RX-V1050 AVR that I tend to use sometimes.
    But, yeah, that's the plan. I have to make (or re-assign) some appropriate cables for 'em. B)
    There are those who claim that the lowly (and still fairly inexpensive) Altec 409 possesses some of the
    legendary Altec 755 driver's strengths in a much, much cheaper package. :) I, unfortunately, don't have any 755 drivers :( -- but I do know some folks who do...
  • stevep
    stevep Posts: 328
    Cool, Allied Radio pre-Radio Shack.
  • Mike Reeter
    Mike Reeter Posts: 4,314
    VR3 wrote: »
    I'm curious about your take on the Lampi, I've had an Amber 3 for a few years now and still quite happy with it.
    Should be delivered today but don't know if he will hook it up today....
    VR3 Posts: 28,120
    Level 5, gen 4
    Dac and separate power supply
    VR3 Posts: 28,120
    VR3 Posts: 28,120
    Time to fight!
    Is that an ANK?
    VR3 Posts: 28,120
    Si senor
    VR3 wrote: »
    Si senor
    what series?
    VR3 Posts: 28,120
    5.1 pro
    VR3 wrote: »
    5.1 pro
    If it has USB, I would love to get my ears on it...
    VR3 Posts: 28,120
    The ank and lampizator both have usb, for sure
    I would note however the ank uses a cheap 25 dollar usb to spidf card to convert that signal to apidf so using a 1.5 bnc cable is the best route for connection
    That can be upgraded though, no?
