Well don't forget upgraded DC cables for the linear power supply when the time comes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Congrats man! I just about had a heart attack coughing up $182 for 28ft of DH Labs Silversonic 12awg wire to construct my 2 power cables I have planned! I haven't gotten to your level yet
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Here's a company that makes some great audiophile network switches and steamers
Silent angel is the name -
Trying some speaker wires that the guy that has the Evolution Acoustics loudspeakers where I am working asked if I wanted to try out these speaker wires. They have a 14or 16 gauge cryo pure copper and a 14or 16 gauge cryo silver spun together for each the positive and negative and then there
spun or twisted . His buddy makes them. -
Gardenstater wrote: »Congrats man! I just about had a heart attack coughing up $182 for 28ft of DH Labs Silversonic 12awg wire to construct my 2 power cables I have planned! I haven't gotten to your level yet
I have not been disappointed with any if my DH Labs purchases. I rewired my 2.3tls with the 14ga silver over occ copper wire. Enough black and red to do both sides, it was a bear to work with but the outcome was FAB U lous. -
DH Labs is fantastic wire. I do always caution folks with permanently installing silver wired but with SDAs given their warmer presentation should be a good combo :-D
The Revelation and Air Matrix are fantastic ICs and the Q10/T14 is phenominal speaker wire.
I find their ready made speaker wire to be $$$ for some reason...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
In short, it seemed that the CAT8 cable was emphasizing all the negative aspects of streaming digital playback. I found the BJC CAT6A cable to be more balanced and refined...forgiving.
So, to answer your question from a couple of pages back? I don't think it was the "Cat" rating. It may have been that the connections were slightly better and that the cable was shielded. It turns out that both the Venom and Alpha Ethernet cables from Shunyata are Cat6A. They found that this cable has less noise/interference, amongst other things....which is why they chose Cat6A over any other cable.
So, what you heard, may be the result of what their lab confirmed. FWIW.
I installed these feet under my SVS sb16. It was quite an upgrade over the get you started feet that came with sub. Listening to Manheim Steamroller's Halleluiah and the bass was vibrating the reading glasses I was wearing. That's a first for me.
Thanks for confirmation Ivan. I'm pretty confident in the results because I am replicating a friend's creation already tested on my subwoofer a couple times with great results, only mine is going to be 12awg and his was 14awg. Same otherwise; Cardas male wall plug and Cardas IEC plug. I might twist mine more than he did to get lower inductance. He doesn't really know exactly how much he twisted his so not a lot I think. I may do something closer to 1 twist per inch like Chris Venhaus suggests now.George / NJ
iFi nano iDSD DAC
iPurifier3
Swapped out the Chinese 12AX7's for these...not sure what brand they are. There's a 12 etched in the bottom between the pins and 4 creases in the top.
SDA SRS 2.3TL's
SDA 2B TL's -
How do they sound?Gustard X26 Pro DAC
Really good. Someone on Audiokarma said they were Amperex. Shame all the lettering is missing.SDA SRS 2.3TL's
SDA 2B TL's -
Its' been over a year after the house remodel and finally getting this back in place
https://youtu.be/dA5a4ls8ROk
Sound demo (headphones recommended)
https://youtu.be/NSlpiGBpwlo Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX -
First video is private, bub...
[Edit:] of the second post...(fixed/repaired since then, all is well...)
michaeljhsda2 wrote: »Swapped out the Chinese 12AX7's for these...not sure what brand they are. There's a 12 etched in the bottom between the pins and 4 creases in the top.
I figured it out. It's a Siemens & Halske, I62 ≠3 ...can't see the rest.
SDA SRS 2.3TL's
SDA 2B TL's -
This hobby sucks! Every time I upgrade a component, reveals deficiencies elsewhere! I recently upgraded the digital side of my system with an Oppo BDP103 disk player and a Musical Fidelity Tri-vista 21 DAC. A Wireworld Silver starlight digital RCA cable between and a Wireworld Oasis RCA 1 meter pair fromtheDAC to the preamp. It sounds so good that now it outperforms my vinyl playback SQ for clarity and imaging. Of course I can't leave the vinyl playback the way it is, so I started investigating phono preamplifiers in another thread. I also ordered two pair of Wireworld eclipse RCA interconnects so I have the same input cables for both sources. Yesterday I purchased a Kimber TAC tonearm cable to try since the current tonearm wiring is a temporary solution and I think it is sucking the life out of the music with its high capacitance. I will be researching MC cartridges in the new year, and eventually upgrade to a VPI signature prime turntable to get my vinyl playback on par with the current digital setup.Enjoying the journey while never attaining the destination.
I wouldn't be so quick to upgrade from the Technics table.
I don't intend to sell the Technics. I've invested a lot of time tweaking it with upgraded parts and modifications. It's kinda my own baby now.Enjoying the journey while never attaining the destination. -
Won an auction for a Denafrips Ares II today.
Decided it’s time to hear digital the way it all began, prior to delta-sigma chips.This hobby sucks! Every time I upgrade a component, reveals deficiencies elsewhere! I recently upgraded the digital side of my system with an Oppo BDP103 disk player and a Musical Fidelity Tri-vista 21 DAC. A Wireworld Silver starlight digital RCA cable between and a Wireworld Oasis RCA 1 meter pair fromtheDAC to the preamp. It sounds so good that now it outperforms my vinyl playback SQ for clarity and imaging. Of course I can't leave the vinyl playback the way it is, so I started investigating phono preamplifiers in another thread. I also ordered two pair of Wireworld eclipse RCA interconnects so I have the same input cables for both sources. Yesterday I purchased a Kimber TAC tonearm cable to try since the current tonearm wiring is a temporary solution and I think it is sucking the life out of the music with its high capacitance. I will be researching MC cartridges in the new year, and eventually upgrade to a VPI signature prime turntable to get my vinyl playback on par with the current digital setup.
If you bought Kimber directly they have a return policy. They are a great and fair company to do business with. Would give them a call if you’re unhappy.
I love their speaker wire, but not big on their ICs, so far (Have only tried Hero ICs; I do like the DV30 coax cable, however).CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
michaeljhsda2 wrote: »michaeljhsda2 wrote: »Swapped out the Chinese 12AX7's for these...not sure what brand they are. There's a 12 etched in the bottom between the pins and 4 creases in the top.
I was going to mention that Siemens also had the mould creases as well. I'm really surprised any of the lettering is left on 50+ year old tubes. That chalk lettering is so fragile putting them in and out of boxes removes some of it as well. Thank god for the hard to remove symbles and such
I believe the tube markings (I62xx) is etched in the glass, all of the chalk lettering is long gone
SDA SRS 2.3TL's
SDA 2B TL's -
I've chased that rabbit awhile now, and finally came to some hard truthes...at least for me, IME, with my gear, etc.It sounds so good that now it outperforms my vinyl playback SQ for clarity and imaging.[...] I will be researching MC cartridges in the new year, and eventually upgrade to a VPI signature prime turntable to get my vinyl playback on par with the current digital setup.
The system that sounds 'better' for any particular track will vary by recording, pressing, mastering, original source, etc. I have found that some albums sound better on vinyl for me, and some (most/more) sound better on digital, especially if hi-res digital. It normally comes down to personal preference, by track.
It could be that if a person had original, NM pressings of all their favorites albums, vinyl would be the overall winner. But that's not realistic, nor something I personally want to even attempt to tackle. YMMV, and enjoy the chase!"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Early Christmas gift to myself. I bought 25-30 used records last month that I’ve yet to listen to, because the first one I pulled out was really dirty. Found out that Project lowered the price on these by $250, so I pulled the trigger at my local dealer. VC-S2ALU.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
^ Very nice. Enjoy your clean rekids.
Pulled the crossover on my right SDA SRS.
Installing two 130uf Solen caps Christmas Sunday.
First crossover upgrade… -
I’ve had one of these for a couple years now. Gets the job done!Analog: Hana ML > VPI Prime Signature 21 > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
Curious to hear what you think. I'm sure it works well, but is it "well worth" the discounted price, as the sale makes it much more tempting.
https://youtu.be/rLJpjX_p_S4
