1…150151153155156…208
  • newbie308
    Clipdat wrote: »
    I wouldn't be so quick to upgrade from the Technics table.
    I don't intend to sell the Technics. I've invested a lot of time tweaking it with upgraded parts and modifications. It's kinda my own baby now.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Won an auction for a Denafrips Ares II today.
    Decided it’s time to hear digital the way it all began, prior to delta-sigma chips.
    newbie308 wrote: »
    This hobby sucks! Every time I upgrade a component, reveals deficiencies elsewhere! I recently upgraded the digital side of my system with an Oppo BDP103 disk player and a Musical Fidelity Tri-vista 21 DAC. A Wireworld Silver starlight digital RCA cable between and a Wireworld Oasis RCA 1 meter pair fromtheDAC to the preamp. It sounds so good that now it outperforms my vinyl playback SQ for clarity and imaging. Of course I can't leave the vinyl playback the way it is, so I started investigating phono preamplifiers in another thread. I also ordered two pair of Wireworld eclipse RCA interconnects so I have the same input cables for both sources. Yesterday I purchased a Kimber TAC tonearm cable to try since the current tonearm wiring is a temporary solution and I think it is sucking the life out of the music with its high capacitance. I will be researching MC cartridges in the new year, and eventually upgrade to a VPI signature prime turntable to get my vinyl playback on par with the current digital setup.
    If you bought Kimber directly they have a return policy. They are a great and fair company to do business with. Would give them a call if you’re unhappy.
    I love their speaker wire, but not big on their ICs, so far (Have only tried Hero ICs; I do like the DV30 coax cable, however).
    pitdogg2 Posts: 27,902
    Swapped out the Chinese 12AX7's for these...not sure what brand they are. There's a 12 etched in the bottom between the pins and 4 creases in the top.
    I figured it out. It's a Siemens & Halske, I62 ≠3 ...can't see the rest.
    I was going to mention that Siemens also had the mould creases as well. I'm really surprised any of the lettering is left on 50+ year old tubes. That chalk lettering is so fragile putting them in and out of boxes removes some of it as well. Thank god for the hard to remove symbles and such :smile:
  • michaeljhsda2
    I believe the tube markings (I62xx) is etched in the glass, all of the chalk lettering is long gone :(
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jdjohn
    jdjohn Posts: 3,442
    newbie308 wrote: »
    It sounds so good that now it outperforms my vinyl playback SQ for clarity and imaging.[...] I will be researching MC cartridges in the new year, and eventually upgrade to a VPI signature prime turntable to get my vinyl playback on par with the current digital setup.
    I've chased that rabbit awhile now, and finally came to some hard truthes...at least for me, IME, with my gear, etc.
    The system that sounds 'better' for any particular track will vary by recording, pressing, mastering, original source, etc. I have found that some albums sound better on vinyl for me, and some (most/more) sound better on digital, especially if hi-res digital. It normally comes down to personal preference, by track.
    It could be that if a person had original, NM pressings of all their favorites albums, vinyl would be the overall winner. But that's not realistic, nor something I personally want to even attempt to tackle. YMMV, and enjoy the chase!
  • xsmi
    xsmi Posts: 1,812
    Early Christmas gift to myself. I bought 25-30 used records last month that I’ve yet to listen to, because the first one I pulled out was really dirty. Found out that Project lowered the price on these by $250, so I pulled the trigger at my local dealer. VC-S2ALU.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • skipshot12
    skipshot12 Posts: 2,146
    ^ Very nice. Enjoy your clean rekids.
  • skipshot12
    Pulled the crossover on my right SDA SRS.
    Installing two 130uf Solen caps Christmas Sunday.
    First crossover upgrade…
  • displayname
    displayname Posts: 1,248
    xsmi wrote: »
    I’ve had one of these for a couple years now. Gets the job done!
    Discogs
  • smartie_panta
    xsmi wrote: »
    Curious to hear what you think. I'm sure it works well, but is it "well worth" the discounted price, as the sale makes it much more tempting.
  • newbie308
    I installed the new Kimber TAK tonearm cable on my Technics SL1200MKII turntable today and I am VERY happy with the results. The original SME cable had failed a couple of months ago, so the right channel would occasionally drop out. I had some Mogami coax on hand so I built a replacement cable using that wire and the original connectors. It worked, but the high capacitance dulled what I was hearing and blurredthe sound stage. The new Kimber cable brought everything back into focus and there are significantly more details being delivered now. Listening to Pink Floyd, Money I can pinpoint each instrument and the Bass guitar is directly in front of me. It's tactile like I can reach out and grab the neck of the guitar. I installed a din connector on the SME 3009 tonearm, so I can more easily experiment with cable options in the future.
    treitz3 Posts: 20,356
    @michaeljhsda2 - Did you ever get a chance to listen to the Lin Lai tubes in the Silk Audio amp?
  • michaeljhsda2
    Tom,
    Not yet, the tubes showed up yesterday evening, very well packaged but they sat out in the cold all day. Unboxed them to make sure there was no shipping damage and letting them get to room temp (didn't want to take a chance of condensation issues). Going to install them in the amp tonight and give them a listen. (tubes are huge btw).
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Ricardo
    Ricardo Posts: 10,634
    Today I bought the first component of my new 2 CH system. From my extensive journey my top 2 speakers included the Dynaudio Contour 1.3 MK II. The other? My modded MMGs (Peter Gunn mods, wood frame and crossovers). But these had a tiny sweet spot, so for my next system I decided to go with the Dyn Special 40 in ebony wave. I have to thank (Or blame?) @Clipdat for pointing me to a pair.
    And the journey starts again....I just retired so I'll have some time on my hands.
    I will initially use the Musical Fidelity M6Si for power and my trusted oppo for source. Probably some tubes and another SACD player will follow. And wires of course.
    Pretty excited to start the build.
    SOPA
    Hey, Ricardo! Congratulations on retirement!!! Did you ever move to the Carolina's? Glad to see you back in action again.
    Thanks for the update, @michaeljhsda2
  • Ricardo
    Thanks Tom. Still in cold (ish) Ohio. Now that the time has come we find it pretty difficult to decide what to do. Both kids live close by so we'll probably stay put for now.
    SOPA
    SCompRacer Posts: 9,394
    Congrats on your retirement Ricardo! How are you doing with it?
  • erniejade
    erniejade Posts: 6,327
    edited December 2022
  • Ricardo
    SCompRacer wrote: »
    Thanks Rich. Well, it's been only a week so can't complain yet. Any tips????
    SOPA
  • michaeljhsda2
    Sounds great so far! They're as tall as the KT88's.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jbreezy5
    Tom,
    Not yet, the tubes showed up yesterday evening, very well packaged but they sat out in the cold all day…
    Cryogenically treated; nice!
  • Milito
    Milito Posts: 2,003
    Congrats Ricardo on your retirement. Now more time for your hobbies.
    I always thought time would go slower when I retired, but it goes faster.
  • jbreezy5
    @Ricardo - would love to get my ears on those modded MMGs.
    Cool speaker selection you have!
  • Ricardo
    Milito wrote: »
    Thanks Milito. Yes, I've heard that.
    SOPA
  • Ricardo
    jbreezy5 wrote: »
    They are all gone. 10 years ago I got rid of my 2 ch gear and gave my audio room to my wife for her painting. Has worked well so far. Now it's time to rebuild.
    SOPA
    Any tips????[/quote]
    Ricardo wrote: »
    Any tips????
    Don't get too lazy. :) Exercise the body and keep the mind sharp.
  • skipshot12
    Hooked up a Bluesound Node 2 to the Oppo.
    Thank you Tom.
    Wife was so happy dancing to her music on her iPhone….
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Ricardo wrote: »
    CONGRATULATIONS on retirement Ricardo B) Life is good :)
  • guyincognito
    I traded in the Arcam SR250 for a proper preamp. The Benchmark LA4 is great!
    Rega Planar 8, Apheta 3 MC , Aria mk2 Phono
    Aurender n100h, Benchmark DAC2 HGC
    Arcam SR250, Parasound JC5
    Revel F208, SVS SB-4000
    Clipdat Posts: 13,104
    Congratulations fellow LA4 owner!
    Loved mine so much that I also bought the HPA4 for my desktop setup.
