1…150151153155156…207
  • newbie308
    I installed the new Kimber TAK tonearm cable on my Technics SL1200MKII turntable today and I am VERY happy with the results. The original SME cable had failed a couple of months ago, so the right channel would occasionally drop out. I had some Mogami coax on hand so I built a replacement cable using that wire and the original connectors. It worked, but the high capacitance dulled what I was hearing and blurredthe sound stage. The new Kimber cable brought everything back into focus and there are significantly more details being delivered now. Listening to Pink Floyd, Money I can pinpoint each instrument and the Bass guitar is directly in front of me. It's tactile like I can reach out and grab the neck of the guitar. I installed a din connector on the SME 3009 tonearm, so I can more easily experiment with cable options in the future.
    treitz3 Posts: 20,366
    @michaeljhsda2 - Did you ever get a chance to listen to the Lin Lai tubes in the Silk Audio amp?
  • michaeljhsda2
    Tom,
    Not yet, the tubes showed up yesterday evening, very well packaged but they sat out in the cold all day. Unboxed them to make sure there was no shipping damage and letting them get to room temp (didn't want to take a chance of condensation issues). Going to install them in the amp tonight and give them a listen. (tubes are huge btw).
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Ricardo
    Ricardo Posts: 10,634
    Today I bought the first component of my new 2 CH system. From my extensive journey my top 2 speakers included the Dynaudio Contour 1.3 MK II. The other? My modded MMGs (Peter Gunn mods, wood frame and crossovers). But these had a tiny sweet spot, so for my next system I decided to go with the Dyn Special 40 in ebony wave. I have to thank (Or blame?) @Clipdat for pointing me to a pair.
    And the journey starts again....I just retired so I'll have some time on my hands.
    I will initially use the Musical Fidelity M6Si for power and my trusted oppo for source. Probably some tubes and another SACD player will follow. And wires of course.
    Pretty excited to start the build.
    SOPA
    Hey, Ricardo! Congratulations on retirement!!! Did you ever move to the Carolina's? Glad to see you back in action again.
    Thanks for the update, @michaeljhsda2
  • Ricardo
    Thanks Tom. Still in cold (ish) Ohio. Now that the time has come we find it pretty difficult to decide what to do. Both kids live close by so we'll probably stay put for now.
    SOPA
    SCompRacer Posts: 9,405
    Congrats on your retirement Ricardo! How are you doing with it?
  • erniejade
    erniejade Posts: 6,327
    edited December 2022
  • Ricardo
    SCompRacer wrote: »
    Thanks Rich. Well, it's been only a week so can't complain yet. Any tips????
    SOPA
  • michaeljhsda2
    Sounds great so far! They're as tall as the KT88's.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jbreezy5
    jbreezy5 Posts: 1,141
    Tom,
    Not yet, the tubes showed up yesterday evening, very well packaged but they sat out in the cold all day…
    Cryogenically treated; nice!
  • Milito
    Milito Posts: 2,003
    Congrats Ricardo on your retirement. Now more time for your hobbies.
    I always thought time would go slower when I retired, but it goes faster.
  • jbreezy5
    @Ricardo - would love to get my ears on those modded MMGs.
    Cool speaker selection you have!
  • Ricardo
    Milito wrote: »
    Thanks Milito. Yes, I've heard that.
    SOPA
  • Ricardo
    jbreezy5 wrote: »
    They are all gone. 10 years ago I got rid of my 2 ch gear and gave my audio room to my wife for her painting. Has worked well so far. Now it's time to rebuild.
    SOPA
    Any tips????[/quote]
    Ricardo wrote: »
    Any tips????
    Don't get too lazy. :) Exercise the body and keep the mind sharp.
  • skipshot12
    skipshot12 Posts: 2,171
    Hooked up a Bluesound Node 2 to the Oppo.
    Thank you Tom.
    Wife was so happy dancing to her music on her iPhone….
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Ricardo wrote: »
    CONGRATULATIONS on retirement Ricardo B) Life is good :)
  • guyincognito
    I traded in the Arcam SR250 for a proper preamp. The Benchmark LA4 is great!
    Rega Planar 8, Apheta 3 MC , Aria mk2 Phono
    Aurender n100h, Benchmark DAC2 HGC
    Arcam SR250, Parasound JC5
    Revel F208, SVS SB-4000
    Clipdat Posts: 13,105
    Congratulations fellow LA4 owner!
    Loved mine so much that I also bought the HPA4 for my desktop setup.
  • guyincognito
    The only problem is my digital side is so quite I'm having trouble wanting to listen to vinyl now. I think I need to swap out the Rega Aria for a better phono stage. Any suggestions?
    Yes. Appreciate the fact that there are deficiencies and attributes with both formats.
  • dromunds
    dromunds Posts: 10,175
    guyincognito, it may be the photo above but is your VTA correct?
  • xsmi
    xsmi Posts: 1,812
    xsmi wrote: »
    Early Christmas gift to myself. I bought 25-30 used records last month that I’ve yet to listen to, because the first one I pulled out was really dirty. Found out that Project lowered the price on these by $250, so I pulled the trigger at my local dealer. VC-S2ALU.
    Curious to hear what you think. I'm sure it works well, but is it "well worth" the discounted price, as the sale makes it much more tempting.
    This is my first machine. However, I can say that there is less snap crackle pop.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • guyincognito
    @dromunds
    The Rega tables don't have much in the way of adjustment. I have replaced the felt mat with a Teac washi paper mat that is slightly thinner but otherwise it's all Rega (table, cart, phonostage).
    It sounds great and truthfully isn't loud at all. It's just the Benchmark pre and dac have zero noise. Pitch black background when streaming digital music. Now I notice the subtle background noise when the phono stage is on, even before I drop the needle. Has me thinking a upgraded phono stage might even the playing field again.
  • skipshot12
    xsmi wrote: »
    xsmi wrote: »
    Excellent,
    I have an old VPI 16.5 and it does a great job at reducing the clicks, pops and vinyl rush.
    One thing I found was I needed one of those anti-stat guns before removing the lp from the RCM. Helps a shart ton...
  • jdjohn
    jdjohn Posts: 3,454
    I have a Benchmark HPA4, and understand what you mean. Utilizing the XLR/balanced connections might help reduce noise, so consider a phono preamp with those outputs. I use a Musical Fidelity Nu-Vista Vinyl, and it is very quiet.
  • zarrdoss
    zarrdoss Posts: 2,562
    I tried out a set of Martin Logan's and am asking myself why I did not try them sooner?
    nooshinjohn Posts: 26,178
    zarrdoss wrote: »
    Just skip over them and go straight to Magnepan.
    Wow...welcome back to the forum. Long time, no hear from!
