1…9192949697…207
  • CH46E
    CH46E Posts: 3,595
    edited July 2020
    treitz3 wrote: »
    Those are to be connected directly to ground. Here is a snippet from the website...
    "Resistors are made in thick film technology. The resistive layer is applied to the ceramic molded body. Then it's drying with high temperature and encapsulated with silicon cement. After applying 0.8mm tinned copper wire, the resistor is almost ready to play, but for ultimate mechanical stability and the shielding advantages it's putted into the copper tube and flooded with the best quality resin. The use of copper tubing allows to drain interferences and this is why we used the third long leadout. It's connected only to the casing, having no contact with the signal transmitted by the resistor. The third leadout should be joined to the ground or "-" speaker input."
    Thanks! I got two in 9.1 ohms in today. These things are heavy and look great.
  • Dr_Wu
    Dr_Wu Posts: 358
    Could, not will! :) I have turned it down, though. And, thanks!
  • joecoulson
    joecoulson Posts: 4,986
    Very cool all sleek and out of the way.
    audioluvr Posts: 6,079
    Glad to hear the garage is done and rocking Dave!
  • verb
    verb Posts: 10,176
    audioluvr wrote: »
    Thanks Rob! Yeah finally have some time over the next couple of weeks! Nice to rock the system while working in the garage!
  • spongebobsquarepants
    I installed the rasberry pi into wicked aluminum case!
    This made the wifi stop working.
    So I ran an ethernet cable to the router.
    I hastily enlarged a 3/8 hole in the floor to 5/8 so I could fit a premade cable, because I didnt want to drive to work to get an RJ-45 crimper on the holiday weekend.
    Roon interface is a lot faster than it ever was on wifi and I'm happy with how it worked out!
    But that hole in the floor is going to haunt me.
  • DaveHo
    DaveHo Posts: 3,586
    No biggie. I've got 4 or 5 behind my racks. One of them is 2".
  • rooftop59
    rooftop59 Posts: 8,120
    Home Depot and Lowe’s and probably amazon sell plugs if the the whole really bothers you...wait, what are we talking about?!?
    Game Room 5.1.4:
    Bedroom 2.1
    Tony M Posts: 12,035
    Caulking comes in colors.
    DaveHo wrote: »
    Perfect size for mice!
    audioluvr wrote: »
    DaveHo wrote: »
    Or other creepy crawlers... :#
  • BlueFox
    BlueFox Posts: 15,250
    Good job.
    Clipdat Posts: 13,107
    Put some pants on, ya bum!
  • Mike Reeter
    Mike Reeter Posts: 4,315
    ZLTFUL wrote: »
    We are back in action after the basement flood!
    Ryan, glad you're back in business! I know the water table is pretty high in parts of Iowa, does the flooding happen very often, or was this just one of those Big Rains?
    nooshinjohn Posts: 26,184
    Thank god Russ and Tony are the only ones here with a foot fetish....
  • Mike Reeter
    edited July 2020
    ZLTFUL wrote: »
    ZLTFUL wrote: »
    TS Cristobal came through that Tuesday and saturated the ground.
    That night there was a second storm systems that was feeding into the warm moist air from the gulf and we got huge rains overnight.
    The sump pump was working and running non-stop but there was just way too much water coming in from the drain tile for it to keep up with.
    Ah man, that certainly sucks. If you haven't, you might consider investing in a good quality Liberty Sump Pump.
    Minimum 1/2 hp. depending on the lift, they will PUMP water.
    pitdogg2 Posts: 27,918
    Or a sewer pump. They tend to pump more water faster. You may need larger piping. My 1hp sewer pump needed 2" pvc. That thing had a head of 15' before any considerable drop in volume of flow.
    One downside is the pit tub may need to also be larger in diameter as their footprint is larger than most sump pumps.
    We needed to separate all my basement drains from the sewer line. The storm water street drain and sewer line at the street were the same. Anytime we got large rains the water would back up into the house. The city paid a plummer to put in new lines in the basement to the pit which was then pumped up and dropped into the sewer stack vent on the first floor.
  • Mike Reeter
    ^^^^Sounds like you'll be well prepared for the next Monsoon^^^^
  • CH46E
    CH46E Posts: 3,595
    Tested my Hafler XL600 for DC offset. I think it's good. Had .03 and .07 at the speaker terminals. Does this just mean dc offset is good? Does that have anything to do with bias?
    When gluing MW drivers, do you have to glue both sides of the magnet? JB weld is pretty strong, and the other side is a pain to get to.
  • CH46E
    CH46E Posts: 3,595
    edited July 2020
    I think you are supposed to put the jb between the basket and the magnet.
    The whole idea is to stop the motor structure from shifting out of alignment with the basket and cone/voice coil.
    edited July 2020
    Yes most of us have done both sides of the magnet.
    We have also moved on to the loctite power grab. It's much easier to apply and cleans up with water unless you choose to use one of their other adhesive products.
    I've used the heavy duty caulk gun size and always do the inside of the magnet first then do the outside the next day.
    They also make a squeeze tube size which may be helpful.
    I've always put it on then smoothed it out with my finger. I've used a fairly generous amount to be sure to push into the area of the magnet and plates.
    https://www.google.com/search?ie=UTF-8&source=android-browser&q=loctite+power+grab#fpstate=imgv&imgv=0
    Wow, that's a nice glue job! I made a friggin mess. After doing the other side of the magnet and making a bigger mess It was starting to feel counterintuitive to "save the speakers" with my messy glue job. I'll try power grab on the other speakers.
  • CH46E
    CH46E Posts: 3,595
    Oh wow, my bad Spongebob! I'm sure glad I did not try this on mine cause I would have screwed that all up. I could have sworn I've seen pics of the basket to the motor structure being glued.
    Doh!
    When using JB Weld I always used popsicle sticks to just dab the end into the mix dab into the corner area around the magnet.
    My instinct was to use a flat head screw driver, but it immediately got stuck to the magnet... ha
    I wound up using a plastic knife and a latex glove
    mhardy6647 Posts: 35,562
    Hey! I am actually "doing something for my 'stereo rig' today!
    To paraphrase Blondie, I ripped it to shreds.
    50108449906_c19a428324_b.jpgDSC_0708 (2) by Mark Hardy, on Flickr
    50108692397_f45e5440cb_b.jpgDSC_0722 (2) by Mark Hardy, on Flickr
    50107888183_2f7ef1d1ba_b.jpgDSC_0724 by Mark Hardy, on Flickr
    more to come... :p
    edited July 2020
    That's a major reorganization going on. ;)
    Can't wait to see the next phase. B)
  • jumpindick
    jumpindick Posts: 428
    I put Star Sound Sistrum Apprentice platforms underneath monoblocks. And audio points underneath preamps.
    As much as I loved the entertainment rack I built recently, it did muddy the overall sound. The Star Sound components seem to remove the vibration and clear background noise.
