Thanks guys!
Basis Audio is a German company that prides itself on tight tolerances. This 1400 tt is entry-level for them, but I was curious, and figured the RB900 arm alone was worth something."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
RB 900 looks near-identical to the RB300. Either are great tone armsSamsung 60" UN60ES6100 LED
Outlaw Audio 976 Pre/Pro
Samsung BDP, Dish Rcvr, Phillips CD chgr, various game consoles
Canare 14 ga - LCR tweeters inside* & CC outside
BJC 10 ga - LCR mids, inside* & out
8 ga Powerline - LR woofers, inside* & out
*soldered
LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Mids & Tweets- 981
CC: Rotel RB981 -> Bi-amped CSi A6
5 Subs: Sunfire True Sub Signature -> LFE & CC & 4 Audio Pro Evidence Subs
Surrounds: Rotel 981 -> AR 12 ga -> RTi A3
3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s -
I thought Basis is an American company. Their website is not too clear, but indicates a New Hampshire address, which I suppose could be the distributor. Founder A. J. Conti was a very well regarded designer-builder. Nice looking tt.
The guy I bought my Aragon amp from had this TT. He said it was the only one of its kind. I cannot say it is for fact. It didn't have any name on it I could find.
Looks like a modded Rega
Ivan, Do you know the maker/brand of the black cabinet? Vented, locking... looks nice. The LED's inside were probably added by the owner.
aprazer402 wrote: »Ivan, Do you know the maker/brand of the black cabinet? Vented, locking... looks nice. The LED's inside were probably added by the owner.
No I do not.
Here is his HT
The plasma is just for TV. He has a screen and projector in ceiling not pictured. -
Bad ****.
Good looking Record Player
SDA SRS 2.3TL's/SDA SRS 3.1TL's/SDA CRS+4.1TL's and some other stuff -
PT2: The tone arm on that table looks like a Rega - suggestive of the TT’s SQ.
Very long story: Rega tone arms are some of, if not the industry’s most under rated arms. Real pain in the rear echelon to set up but worth the trouble because their “set and forget” nature. Near Lambo sound performance at just above Fiat 500 prices.
Enjoy! TonySamsung 60" UN60ES6100 LED
*soldered
Cambridge Audio 851N Streamer/DAC
Belles 350A Reference modded with Mundorf Supreme caps
There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January.
by Dr. Sardonicus -
Installed a new to me PS Audio power regenerator. Nice improvement in sound: vocal clarity, bass volume and definition - could probably do without the subwoofer at this point. My SDA-CRS+ have never sounded better. Everything I've done to clean up my power supply has really paid off. Huge thanks for guidance go to @DarqueKnight - you're the man, Ray!
Was about to like your post, then saw, “...could probably do without the subwoofer...”
Make sad 😢
Line purification and voltage regulation really does make a difference. Congrats on your purchase! -
Those are to be connected directly to ground. Here is a snippet from the website...
"Resistors are made in thick film technology. The resistive layer is applied to the ceramic molded body. Then it's drying with high temperature and encapsulated with silicon cement. After applying 0.8mm tinned copper wire, the resistor is almost ready to play, but for ultimate mechanical stability and the shielding advantages it's putted into the copper tube and flooded with the best quality resin. The use of copper tubing allows to drain interferences and this is why we used the third long leadout. It's connected only to the casing, having no contact with the signal transmitted by the resistor. The third leadout should be joined to the ground or "-" speaker input."
Thanks! I got two in 9.1 ohms in today. These things are heavy and look great. -
Could, not will!
I have turned it down, though. And, thanks!
Finally got the garage rig set up!
Cambridge Audio 640A Integrated from our very own @mantis
Project BoxE used to stream Tidal
Shunyata 2 outlet power conditioner
Douglas Speaker Cables (a bit too long, I may need to order some shorter ones)
Polk TSi200 speakers (I'll be able to rotate other bookies in this rig as well!)
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Very cool all sleek and out of the way.
Glad to hear the garage is done and rocking Dave!Cambridge Audio 851N Streamer/DAC
by Dr. Sardonicus -
Thanks Rob! Yeah finally have some time over the next couple of weeks! Nice to rock the system while working in the garage!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I installed the rasberry pi into wicked aluminum case!
This made the wifi stop working.
So I ran an ethernet cable to the router.
I hastily enlarged a 3/8 hole in the floor to 5/8 so I could fit a premade cable, because I didnt want to drive to work to get an RJ-45 crimper on the holiday weekend.
Roon interface is a lot faster than it ever was on wifi and I'm happy with how it worked out!
But that hole in the floor is going to haunt me. -
No biggie. I've got 4 or 5 behind my racks. One of them is 2".
Home Depot and Lowe’s and probably amazon sell plugs if the the whole really bothers you...wait, what are we talking about?!?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SR250; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Game Room HT: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology Power Monitor 700s mains, CLR-3000 center, StudioMonitor 350surrounds, ProMonitor 800 atmos; Sub - Monoprice Monolith 15in THX Ultra
Master Bedroom
Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Caulking comes in colors.Most people just listen to music and watch movies. I EXPERIENCE them.
Perfect size for mice!Cambridge Audio 851N Streamer/DAC
by Dr. Sardonicus -
Or other creepy crawlers...Most people just listen to music and watch movies. I EXPERIENCE them. -
We are back in action after the basement flood!
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
Good job.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Put some pants on, ya bum!
Ryan, glad you're back in business! I know the water table is pretty high in parts of Iowa, does the flooding happen very often, or was this just one of those Big Rains?
Mike Reeter wrote: »
TS Cristobal came through that Tuesday and saturated the ground.
That night there was a second storm systems that was feeding into the warm moist air from the gulf and we got huge rains overnight.
The sump pump was working and running non-stop but there was just way too much water coming in from the drain tile for it to keep up with.
