19293959798177
  • displayname
    displayname Posts: 1,085
    jdjohn wrote: »
    I'm pretty stoked about this new-to-me Basis Audio 1400 turntable with a Rega RB900 tonearm. The chassis and platter are clear acrylic, so looking forward to hearing what this has to offer.
    This will be my first tt with an off-board motor.
    This looks really cool! I haven’t heard of this company before, but that looks like some solid design philosophies.
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
    Discogs
    VR3 Posts: 27,543
    That is neat looking for sure!
  • jdjohn
    jdjohn Posts: 2,875
    Thanks guys!
    Basis Audio is a German company that prides itself on tight tolerances. This 1400 tt is entry-level for them, but I was curious, and figured the RB900 arm alone was worth something.
  • gp4jesus
    gp4jesus Posts: 1,956
    edited July 2020
    RB 900 looks near-identical to the RB300. Either are great tone arms
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • maxward
    maxward Posts: 1,437
    I thought Basis is an American company. Their website is not too clear, but indicates a New Hampshire address, which I suppose could be the distributor. Founder A. J. Conti was a very well regarded designer-builder. Nice looking tt.
  • joecoulson
    joecoulson Posts: 4,943
    Looks like a modded Rega
  • aprazer402
    aprazer402 Posts: 3,007
    The guy I bought my Aragon amp from had this TT. He said it was the only one of its kind. I cannot say it is for fact. It didn't have any name on it I could find.
    Ivan, Do you know the maker/brand of the black cabinet? Vented, locking... looks nice. The LED's inside were probably added by the owner.
    pitdogg2 Posts: 23,799
    edited July 2020
    aprazer402 wrote: »
    No I do not.
    Here is his HT
    The plasma is just for TV. He has a screen and projector in ceiling not pictured.
  • Mike Reeter
    Mike Reeter Posts: 4,311
    edited July 2020
    Good looking Record Player
    SDA SRS 3.1TL's/SDA CRS+4.1TL's and some other stuff
  • gp4jesus
    PT2: The tone arm on that table looks like a Rega - suggestive of the TT’s SQ.
    Very long story: Rega tone arms are some of, if not the industry’s most under rated arms. Real pain in the rear echelon to set up but worth the trouble because their “set and forget” nature. Near Lambo sound performance at just above Fiat 500 prices.
    Enjoy! Tony
  • jbreezy5
    jbreezy5 Posts: 1,075
    Dr_Wu wrote: »
    Installed a new to me PS Audio power regenerator. Nice improvement in sound: vocal clarity, bass volume and definition - could probably do without the subwoofer at this point. My SDA-CRS+ have never sounded better. Everything I've done to clean up my power supply has really paid off. Huge thanks for guidance go to @DarqueKnight - you're the man, Ray!
    Was about to like your post, then saw, “...could probably do without the subwoofer...”
    Make sad 😢
    Line purification and voltage regulation really does make a difference. Congrats on your purchase!
  • CH46E
    CH46E Posts: 3,400
    edited July 2020
    treitz3 wrote: »
    Those are to be connected directly to ground. Here is a snippet from the website...
    "Resistors are made in thick film technology. The resistive layer is applied to the ceramic molded body. Then it's drying with high temperature and encapsulated with silicon cement. After applying 0.8mm tinned copper wire, the resistor is almost ready to play, but for ultimate mechanical stability and the shielding advantages it's putted into the copper tube and flooded with the best quality resin. The use of copper tubing allows to drain interferences and this is why we used the third long leadout. It's connected only to the casing, having no contact with the signal transmitted by the resistor. The third leadout should be joined to the ground or "-" speaker input."
    Thanks! I got two in 9.1 ohms in today. These things are heavy and look great.
  • Dr_Wu
    Dr_Wu Posts: 291
    Could, not will! :) I have turned it down, though. And, thanks!
  • joecoulson
    Very cool all sleek and out of the way.
    audioluvr Posts: 5,213
    Glad to hear the garage is done and rocking Dave!
    Gustard X26 Pro DACBelles 21A Pre modded with Mundorf Supreme capsB&K M200 Sonata monoblocks refreshed and upgradedPolk SDA 1C's modded / 1000Va DreadnaughtWireworld Silver Eclipse IC's and speaker cablesHarman Kardon T65C w/Grado Gold. (Don't laugh. It sounds great!)There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January. by Dr. Sardonicus
  • verb
    verb Posts: 10,176
    audioluvr wrote: »
    Thanks Rob! Yeah finally have some time over the next couple of weeks! Nice to rock the system while working in the garage!
    I installed the rasberry pi into wicked aluminum case!
    This made the wifi stop working.
    So I ran an ethernet cable to the router.
    I hastily enlarged a 3/8 hole in the floor to 5/8 so I could fit a premade cable, because I didnt want to drive to work to get an RJ-45 crimper on the holiday weekend.
    Roon interface is a lot faster than it ever was on wifi and I'm happy with how it worked out!
    But that hole in the floor is going to haunt me.
  • DaveHo
    DaveHo Posts: 3,439
    No biggie. I've got 4 or 5 behind my racks. One of them is 2".
  • rooftop59
    rooftop59 Posts: 7,826
    Home Depot and Lowe’s and probably amazon sell plugs if the the whole really bothers you...wait, what are we talking about?!?
    Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply Game Room 5.1.4: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology Power Monitor 900 mains, CLR-3000 center, StudioMonitor 350 surrounds, ProMonitor 800 atmos x4; Sub - Monoprice Monolith 15in THX Ultra Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer
    Tony M Posts: 10,977
    Caulking comes in colors.
    DaveHo wrote: »
    Perfect size for mice!
    audioluvr wrote: »
    DaveHo wrote: »
    Or other creepy crawlers... :#
  • BlueFox
    BlueFox Posts: 15,251
    Good job.
    Clipdat Posts: 12,286
    Put some pants on, ya bum!
