How do the new L800 SDA compare to the Original Legend SDA-SRS 1.2TL?
1356713
    pitdogg2 Posts: 27,197
    FTGV wrote: »
    Thanks Fred 👍
    Well Polk told F1 otherwise so I'm sure they will add clarity to the subject.
    We will find out here in a few months now won't we ;) .
    I still respect your take you have a keen knowledge.
    edited September 2019
    VR3 wrote: »
    Looking at the values, I actually think changing the caps and resistors would be fairly simple...
    Changing all those iron core inductors would be a true bear and require remote mounting but not impossible.
    Those are poly caps no or are they Mylar? Wonder who supplies them for Polk?
  • VR3 wrote: »
    @Vr3,
    What do you think?
    Is it likely to be worth it for the improvement in sound quality, perhaps, without changing the inductors?
    Even at the price Polk is advertising, I would bet they had to make some compromises on component quality to reduce costs.
    F1nut Posts: 51,917
    Mylar
  • F1nut wrote: »
    Mylar
    OK, @F1nut, I'll bite: What do you mean by "Mylar?"
    yellow caps on the XO board are Mylar not polypropylene. He answered my question.
  • pitdogg2 wrote: »
    Thanks, @pitdogg2.
    Please pardon my ignorance.
    Of course, @F1nut, characteristically [ :) ] provides no context, but I should have read your comment, which Vanilla indicates you posted several minutes before my post.
    mhardy6647 Posts: 35,183
    Can they be? Sure, but there's a lot of components on the board, so it isn't going to be cheap.
    They're $6k loudspeakers, so that's OK.
    I mean, it's like buying a BMW (especially a used, older one) -- it's a given that the parts and service are gonna be costly.
  • FTGV
    FTGV Posts: 3,650
    also known as polyester.
  • vmaxer
    vmaxer Posts: 5,120
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    VR3 Posts: 29,520
    Absolutely, changing them with a cap like the Clarity Cap CSA and the resistors to Jantzen superes would yield gains. Everything can be improved, there is truly no limit in audio. You could build an enclosure externally the size of the speakers, drop $30k in duelund caps and resistors. The world is your oyster!! haha
  • verb
    verb Posts: 10,176
    Love it! We're (I mean you guys) already hot rodding the XO's! :)
    Viking64 Posts: 7,601
    verb wrote: »
    Hot Rodding the broads? I mean boards?
    Here's mine. Look at the inductors on this one. Do you have the capacity to resistor?
    nooshinjohn Posts: 25,973
    The dynamic interface could use a new grill....
  • Nightfall
    Nightfall Posts: 10,083
    Is that Caitlyn Jenner?
    afterburnt wrote: »
    Village Idiot of Club Polk
    I hope she isn't bi-wired.
    Nightfall wrote: »
    Just before the Olympic tryouts in 1972....
  • verb
    verb Posts: 10,176
    Hard to tell from the pic, inductors and all :) but is that a Cadillac? Coupe Deville or Eldorado
    I’m guessing.
    verb wrote: »
    I’m guessing.
    It started life as a ‘57 T-bird...
    verb wrote: »
    I’m guessing.
    I did a little research and found it to be Dick Jackson’s custom 1957 T-bird. :)
    https://kustomrama.com/wiki/Dick_Jackson's_1957_Ford_Thunderbird
  • verb
    verb Posts: 10,176
    Very cool! As usual I’m way off! :smile:
    verb wrote: »
    We know... :p
    From what I've seen, it would seem very difficult to upgrade the stock crossovers,...
    Not for those of us who know how to design circuit boards. ;)
    In the future, when I am more dedicated to audio than I am now, I will buy two sets of L800's, one to mod out to the nines, the other to keep stock, both to compare to my hot rodded SDA SRS 1.2TLs. :)
    I think I safely speak for all of us in saying we eagerly await that review. Would a GoFund me page help?
  • Metalized polypropylene will definitely improve the performance, but consider the original TOT SRSs were mostly NP Electrolytics. I'll take Mylars over Electrolytics any day.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    FTGV wrote: »
    Yup, PET (PolyEthylene Terephthalate) the original, trademarked polyester "plastic film" from Dupont (Better Living Through Chemistry) :)
  • dromunds
    dromunds Posts: 10,136
    Viking64 wrote: »
    verb wrote: »
    The dude looks like a lady
  • Willow
    Willow Posts: 11,246
    dromunds wrote: »
    Viking64 wrote: »
    verb wrote: »
    Is that Russ?
    Viking64 wrote: »
    verb wrote: »
    I’m guessing.
    Whew. At least it wasn't Dick Johnson. :/
    OK, I actually want to talk about the new SDA's XOs! :)
    Here's the thought I wanted to share. Passive crossovers are fundamentally simple. Not saying that the design or engineering is simple, but the components are. With fairly rare exceptions (tapped inductors and autoformers, e.g.), we're talkin' rather prosaic L, C, R (inductors, capacitors, and resistors) wired in series and/or parallel, and the wires to hook 'em together and hook the Gemisch to the drivers. Straightforward for a patient person to reverse engineer or for anyone who can read a schematic to clone (or 'improve', at least in terms of component substitution -- not talkin' about actual redesign).
    Now, my point is that 'souping up' the new L800 XOs is a straightforward exercise -- but -- I wonder whether the complexity (i.e., parts count) of the board(s) might mean that souped up XOs containing boutique Cs (especially), but also Ls and maybe even Rs might take up so much space (relative to the manufacturer's stuffed XO boards) as to impact the enclosure volume and thus the tuning of the speaker system?
    Not trying to be an alarmist (!) -- just musing.
