I have a couple things to add today:
One is the SVS soundpath isolation feet system to my SB16 Ultra,
The other is adding the Acoustic Zen Satori jumpers to the Elacs
I also have two more Wireworld power cables on the way to round off the new power conditioner connections.
More pics to come. -
Installed.
That IS photo worthy!
I like it! It's very clean.
I'm going in a new direction with streaming. I sold my ELAC Discovery Music Streamer to fund the purchase of a Bluesound Node 2i.
The Bluesound Node 2i arrived today (haven't hooked it up yet).
Interesting warning label on the front of the box:
Am I missing something? Does streaming through the Node 2i not apply to music? Is this a beverage dispenser??HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Just don't lick it and you'll be fine.
Yeah we now have to put a similar label on all vehicles destined for CA. Crazy, IMO.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Lol. CA is slowly becoming its own country.
joecoulson wrote: »Installed.
You might want to make your main connection to the mids/tweet posts, and jumper "down" to the woofers. Just a little tweak that can sometimes make a difference if your jumpers aren't as good as your main cables...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
joecoulson wrote: »Lol. CA is slowly becoming its own country.
We do have the fifth largest economy in the world.
"If the state –with its 39.5 million people – was an independent country, it would have the fifth largest economy in the world, according to new federal figured released on Friday – just surpassing the United Kingdom, which has a population of 65.6 million."
http://fortune.com/2018/05/05/california-fifth-biggest-economy-passes-united-kingdom/
Of course, none of this has anything to do with what anyone did with their stereo last night.
Three 20 amp circuits. -
I do not know if you looked at Axpona Joe, many rooms were diagonal. Red on lower post, black on upper or vice versa. Now it can be like splitting hair but some feel it works. I hook mine just like yours. I've tried it both ways no difference but lower takes some of the strain off the posts
Since both his cables are Acoustic Zen might be a close call Steve. -
Following Joe’s inspiration. Finally installed the Zu jumpers on the Klipsch’s in the spare room!
Ivan/Steve I feel like the Elacs have more tonality with this type of connection. They are just ever so slightly rolled off at the top vs setting as Steve suggested. For the distance I sit from the towers, this works best for me. And yes they are (or at least should be) exactly the same as the speaker wire. AZ Satori’s
They seem to allow a smoother transient is the main change I heard. Smoother at higher volumes.
The feet on the SVS was also a noticeable change. Much tighter and cleaner (less boomy) bass. Better integration into 2.1ch listening. -
Dusted it off and fired it up, after being out of town for 10 days.
As a side note, only being able to see your parents once a year sucks. -
Agreed.Lumin X1 file player, Westminster Labs interconnect cable
I replaced my Rotel transport with my Marantz. The silver face stuck out too much in the sea of black. I ended with cleaner looks and cleaner sound.
Installed my Cullen Gold power series cables and Audience OHNO rca interconnects. Also added a longer Monoprice Ethernet cable to connect the left/right speakers as the stock 10 footer length doesn’t cut it length wise for me. Also these are the first pictures of the KEFS on the Skylan stands. Rocking out to Fleetwood Mac right now!
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
What's the second Rega box for?
Did you notice any changes with the aftermarket power cords?
Right off the bat they are warmer. Seemed very dark at first listen but have livened up a bit. I was a bit worried at first but its coming around now. Not much else to write about at the moment. I’m attesting all the change to the power cords as I don’t think the Ethernet interconnect between the speakers is gonna matter much. The one that came with the KEFS seems to be a run of the mill cat6 cable.2 Channel in my home attic/bar/man cave
Actually bass seems noticeable tighter too. Really getting some impact out of these KEFS now2 Channel in my home attic/bar/man cave
Is there still a digital/streaming component to this setup, or are you strictly vinyl now?
I still stream, utilizing Roon installed on my Synology Nas and using the KEFS as an endpoint. I control roon via the Roon app on my phone. Really cool little integrated streaming setup2 Channel in my home attic/bar/man cave
Wow, very cool!
Awesome setup Zach!
Love Skylan stands...pricey, but worth it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Pic's needed!
If you need a new home for the silver Rotel, my Pass Labs stack can keep it company.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
