MagniFi Max SR - Surrounds Popping (despite software updates)
Wow, that would be amazing news! How about the crackling in the subwoofer??????? And is the firmware update in a specially country first, or worldwide?
KennethSwauger wrote: »Polk is aiming for Thursday, the 14th, next week. It will most likely be v112.
I confirm, mail today from the the customer support manager :
Hello,
There will be a new firmware version available later this week that will address these issues.
The firmware version is 112.
Thanks,
Kim -
This night the bar got the update to v112. I can confirm; the popping sounds from the sub are GONE! Good news. What was the reason behind the popping sounds? What was the reason?
Any reason to worry if you're happy with the prior version?
I have the same positiv effect. The first short test was successfull. No popping sound from the sub and rears. -
Hope your build in Chromecast will work further, mine is dead now. I dont' know if it is a combination with the new FW or not, but i have to replace my bar. :-( -
I was one of the two or three original beta testers on the Max SR, since its release in December 2017. It was a tooth-pull for months, with some updates helping, and others making it worse. Once the patch worked for this small group, it was sent out to owners.
I see my v112 was received overnight. I'll give it a try tonight.
Finally, v112 and no pops or cracks from the sub anymore
Tested all weekend. I confirm, the crackles and popping are gone completely.
How do you do the update? If it’s automatic mine is still popping. I’m in the UK.
Hello,
I'll ask for you. -
Hello,
If you are connected to the Internet, you should be able to see the system in the Google home app.
Please give me your MAC ID number found on the rear of the bar. You could send it to me in a PM or post it here. -
I also have had no issues with 112 so far
The latest update seems to be working fine.
KennethSwauger wrote: »Hello,
Managed to update and seems okay so far. Fingers crossed it stays this way. -
Hi, just picked up my Polk MagniFi Max SR the other day. Wow, super impressed and love it. Today I used google home and updated to software 112 it says. There is now popping coming from the Subwoofer at low volumes before the update I never heard anything. I don’t leave back speakers hooked up at all times due to a 1 and 3 year old pulling at the wires so not sure if popping through those too. Any idea on why this might of started with the new update? Thanks
Early days but have to say v.112 is looking very promising so far. Much improved bass & sound from rear speakers. No popping or chirping from rear speakers which previously if you paused a film or stood in front of the sound bar was very bad. I’ll give it a bit longer before making a final judgement but so far so good - better late than never!Post edited by Nick_S on
nbaczek - I would suggest you try resetting soundbar to factory default & then update to v.112 again via google home just in case new software hasn’t initiated correctly. As I said above I suffered very bad crackling from my sub on earlier versions but it does seem much improved (don’t want to say resolved just yet but fingers crossed!). Hope that helps, maybe there will be more suggestions on here...
out of curiosity, what other devices are in the vicinity of the sound bar? Where is your Wi-Fi router? -
How the hell do you update firmware???? I can’t remember doing it last time. Mine has been stuck on v103 for ages according to Google Home. I have the Google home app - the soundbar is on it (I can adjust the volume using my phone) but there is no option to update I can find. Help!!!!
v115 was pushed out this weekend.
MOz, use manual update
Thanks. Sorted this by resetting the bar back to defaults and re-connected it to Google Home. If I use the method you posted above, does it need to be connected to my router by Ethernet cable??
I'm a little bit afraid....
Does anyone know, which changes they released? -
It seems to perform the same as 112. I assume just some minor bug fixes. -
Hello comunity
Looks like last post was on November 18. Does this cracking noises issue was fixed by now?
I also have this issue that was resolved previously by puting mode 4 speakers surround in Music mode.
Any updates? Any comments appreciated -
I started having crackes in right rear dynamic starting around 2 weeks ago
where 4 way surround mode does not help
Sorry, I just realised I havent seen a couple of pages of discussion. I have V.115 and I noticed that I started having minor problems with Chromecast. I cant connect my deezer directly to Polk, however within the group it works well.
Anyone suggests to update to v.118?
