Do power cables make a difference?
189101113
    msg Posts: 10,452
    @K_M
    In all sincerity, what is the question here, again?
    Is it that cables don't make a difference?
    Or that cables don't make enough of a difference that a person couldn't tell the difference in a blind test?
    F1nut Posts: 51,710
    It doesn't matter what the question or topic is, she will troll it. Then, after the push back gets too much she'll PM a bunch of members to complain and look for support. When that goes nowhere she'll disappear for a bit. It's been the same MO since the day she joined.
  • K_M
    K_M Posts: 1,632
    edited April 2018
    msg wrote: »
    @K_M
    my original comment was something about......
    Why bother arguing over them, when even if there are differences, (which I believe there could be, but quite small) when the proponents are only offering an anecdotal account (which is fine) but does not fit into what I would call close to definitive proof, but just an account of an experience online.
    In other words, there is nothing serious enough to argue, as a completely uncontrolled subjective listen, is not worth arguing about pro or con.
    msg Posts: 10,452
    I started another thread detailing a bit the Difference File Test Method. It's an easy way for anyone with a computer to see for themselves the differences component changes make.
    http://forum.polkaudio.com/discussion/181790/do-cables-components-make-a-difference-heres-how-to-test-for-yourself
  • mikeyb128
    mikeyb128 Posts: 2,885
    K_M wrote: »
    msg wrote: »
    @K_M
    Take your own advice, If there’s Nothing to argue over then give it a rest.
    2 channel:
    Theater:
  • gp4jesus
    gp4jesus Posts: 2,016
    mikeyb128 wrote: »
    K_M wrote: »
    msg wrote: »
    @K_M
    PLEASE!!
    *all connected w/Premiere ICs
    msg Posts: 10,452
    K_M wrote: »
    Okay. I thought it might be the latter. In answer to this, I created a separate thread, which you've now seen, detailing a process for determining how much of a difference component changes can make by way of an audio difference file, so that one can actually hear the difference.
    It's better than measurable, it's an audible demonstration of what's missing. As before, the responsibility lies with you to test/evaluate for yourself. I see now though that you've already got an answer for this, as well - a listener may or may not be able to hear the difference between components above audio playing in the original listening context
    For everyone else who subscribes to system component refinements, it doesn't need to be measured by difference recording, nor otherwise proven - it's good enough for them to know through listening that the gains are there. That they're cumulative, and that it all adds to the experience through a collection of nuanced improvements. Everyone knows that's what we're talking about here. Cumulative removal would result in a lesser listening experience.
  • gmcman
    gmcman Posts: 1,842
    When I recorded a few tracks with different power cords just recently, I had switched my cdp, preamp, & amp back to the stock cords. It was then I realized how much the upgraded cords lowered the noise floor of the music. I'm trying to get a file I can share while maintaining the original file quality...or I will just need to find another method.
    I haven't used them in probably 3-4 years since I started down this rabbit hole. What immediately stood out was the slight....."fuzziness"... if you will, surrounding the music or mainly the vocals. The dialog was clear, but the imaging my 2.3TL's provide was not as focused and I was struck by the slightly clouded shrill of the female vocals. Also lost was the finer details of the quiet passages, the last bit of quiet air you can hear from the singer. If you know its there, you can somewhat hear it, but with the upgraded cords, that detail smoothed out and becomes more in focus, cleaning up the subtle details and giving some image depth.....and not as painful to listen to for extended periods.
    How critical do you listen? What is your listening environment like? Do you suffer from some sort of hearing issues mainly regarding the higher pitched notes? All that applies to everyone. I wasn't a believer until I tried it myself. The differences may not jump right out, but the more you know a song and the more revealing your gear is, the more pronounced the experience will likely be.
  • voltz
    voltz Posts: 5,384
    edited April 2018
    1st of all you can not blind test power cables...when you turn it off and let it cool down and then plug in a new cable everything changes...as everthing matters....amps need to warm up etc...
    audio & science don't go together in a way....
    If you need Science to prove your music is good then you missing the whole point of listening to music! Enjoy it or sell it!
    don't judge what you have never heard! or tried! or you just talking to be talking!
    I don't care what anyone else thinks but me & my ears BUT...I found I can trust many of those Texas Dudes! and they have never let me down! they have helped me down this road like several others on this forum.
    Enjoy your ride like I have or give it up!
    stick with those cheap patch cables that came with your CD player and that brand new power cable they gave you and count yourself blessed o:)
  • K_M
    K_M Posts: 1,632
    voltz wrote: »
    Blind means to listen without knowledge of what is being used.
    It is a method of seeing if a difference is truly real to the listener or they are simply perceiving a difference aided by knowledge of what is being used.
    Clipdat Posts: 13,089
    Cool, why don't you drop $100 on a Shunyata Venom 14 and have your husband setup a blind test for you against a stock cord on your source, and see what you think.
    Are you afraid that you might prefer the sound of the Shunyata?
    K_M wrote: »
    Viking64 Posts: 7,528
    Shunyata Venom? That sounds like the verbal abuse you would have to take from a Japanese girl when she rejects your advances. :p
    Speaking from experience?
    Viking64 wrote: »
    Clipdat wrote: »
    Nope. HAHAHA Back in the 80's, that may have been an interest, but the internet has dulled the appeal, if you catch my drift. :p
    "Back" in the 80s? I was born in the 80s..
    Sup gramps?
    Viking64 wrote: »
    Clipdat wrote: »
    Sup gramps?
    Normally I am one of the oldest members of forums that I frequent. Here? Not so much. :p
    pitdogg2 Posts: 26,974
    Clipdat wrote: »
    Sup gramps?
    Viking64 wrote: »
    That EXPLAINS a LOT....
    Such as?
    Tony M Posts: 11,591
    Clipdat wrote: »
    Such as?
    You're too young to hear about such things right now. :#:D
    Tony M wrote: »
    Clipdat wrote: »
    Such as?
    Bingo
    Oh I thought you were going to list some actual things, but if you're just flapping your gums then that's cool too.
    You were in diapers while i was well .... not soiling myself......
    I see not much has changed I'm still not soiling myself and you have moved up to training bras
    I was already getting speeding tickets and chasing chicks in the early 80's >:)
    tonyb Posts: 33,069
    ....30 years later, nothing has changed too. :)
    Before the thread goes off the rails, like these usually do, bottom line is to tune out all the negativity and simply try a few for yourself, listen with your ears and then make judgements as it applies to you.
    It's not hard, doesn't warrant 14 pages of back and forth. You have to approach these things with an open mind, and no wax build up in the ears. ;):)
  • K_M
    K_M Posts: 1,632
    edited April 2018
    Clipdat wrote: »
    Sup gramps?
    Viking64 wrote: »
    Same here. early/Mid 80's.
    Neat.
    I wish you would've replied to this post of mine instead, so I'll just paste it again here:
    Clipdat wrote: »
    K_M wrote: »
    K_M wrote: »
    txcoastal1 Posts: 13,505
    When it comes to power cables you need, don't forget the Douglas Connection custom power cable selection. :)
    And he will be personally signing autographs in two weeks at Lonestar audio fest
  • mikeyb128
    Hahahahaha!
    2 channel:
    Theater:
  • Nightfall
    Nightfall Posts: 10,084
    edited April 2018
    Clipdat wrote: »
    Sup gramps?
    Viking64 wrote: »
    Every generation says the same thing. The Beatles? Sounds like noise to me! Elvis? Devils music, look at the way he shakes his hips! Back in my day we were in the coal mines by 14, look at these kids at their Woodstock's making premarital sex and doing drugs, we're doomed when they take over. To the dismay of your older generation you turned fine.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • gp4jesus
    K_M wrote: »
    If I take someone up an an "Offer"...
    Innuendo for one who cares infinitely more about being right, about serving their agenda, their ego, than getting to truth.
    K_M wrote: »
    it will not be announced publicly but will be done in PM.
    perfect! You can protect your ego by hiding behind the internet. Perish the thought that you have accountability to someone.
    No, my dear lady, it is YOU w/a member present, that must prove to all these people you checked it out by the numbers. A member present during the trial will provide accountability of the process and if your system can resolve the difference/truth. W/out someone present you can and will say what serves your agenda. You expect these people to do what you can’t - trust another.
    Your personality type can’t handle conflict. If backed into a corner, where you hafta choose between your ego or your integrity shutting down prevents your compromising either because you hafta win.
    K_M wrote: »
    I can not force you to quit replying to me...geez.
    too bad the same applies to all Polk Forum members.
    In conclusion, it’s beyond logical why I, or anyone else, should waste any more time or olive branches on you.
    Good day.
