Equipment Racks
2456718
  • marvda1
    marvda1 Posts: 4,943
    kharp1 wrote: »
    Looking at this one with, a special order with an added shelf. I like the ability to put pieces side by side. Three shelves might be enough, but, I'd rather pay for an extra shelf now and not need it then need it and not have the ability to add one.
    I looked at the VTI pieces as well. They make a wide unit labeled a TV stand, but, it's not tall enough. There is an 1/8 inch difference between the audio rack poles and the TV racks, which really sux. Was going to buy one of each and blend them together. I even emailed VTI and they were quick to get back with me letting me know they definitely wouldn't match.
    If all I needed was a good basic audio rack I'd hit Doug up for one of the VTI's.
    here's one that's on sale for you.
    https://www.audiogon.com/listings/stands-double-width-6-shelf-isolation-rack-2018-01-16-accessories
    Puritan PSM156
    Tony M Posts: 11,615
    Clipdat Posts: 13,094
    edited January 2018
    Aside from the spikes on each shelf/section looking cool, what is the real world and/or functional difference between having them or not?
    ASOLIDS24BLK.jpg?scale.width=572&scale.height=572&scale.option=noup
  • kharp1
    kharp1 Posts: 3,453
    They have pretty good prices, but, if you decide to go with VTI I would still reach out to Doug and see what he can do for you.
    edited January 2018
    Go for the VTI shelves. Make payments if you have to. i think you'll be happier seeing how you've gone tubular and mono blocks.
    1st class affordable shelving for 1st class audio components. ;)
    You can't quickly change shelving without the spikes. :(
    You have 12 quick ways to configure the spiked one I think. B)
  • vmaxer
    vmaxer Posts: 5,120
    Clipdat wrote: »
    Paypal address?
    vmaxer wrote: »
    I’ll sell you a full set of 4 for $9.99, well worth it.
    Sorry, cash and carry.......plus shipping of course. B)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    edited January 2018
    I dont't foresee having to change the shelving configuration very often. But if there is another reason for spikes on each section such as better isolation/vibration reduction, then I'd be attracted to that.
    Even with an additional shelf, the VTI is still cheaper than the SolidSteel, so there's that.
    Tony M wrote: »
    I think the spikes do support the theory of isolation of vibrations getting transferred. ;)
  • halo
    halo Posts: 5,616
    VTI racks are very solid. You can fill them with lead shot to further dampen the rack as long as you use silicone sealant on the small holes. You have more color options and combinations with the VTI racks as well. Winner winner chicken dinner!
    SCompRacer Posts: 9,112
    edited January 2018
    My last VTI rack I used pipe insulation in the tubes. One time I had a cap pop off and had lead shot everywhere on the hardwood floor. With the insulation method, you can also take some plastic pipe cut to correct length, cap one end, fill them with oil or shot and cap the other end to further deaden/add weight. You can apply some strips of sound deadener to the cross braces.
    With the VTI racks, what is each shelf sitting on? It's not clear to me how the individual shelves are supported.
    F1nut Posts: 51,749
    Clipdat wrote: »
    The spikes are for isolation/vibration control.
    Thanks Jesse. I'm leaning toward the VTI, just want to make sure I'm making a wise choice.
    F1nut Posts: 51,749
    edited January 2018
    Very nice, but very expensive!
    F1nut Posts: 51,749
    Indeed. Just thought you'd like a look to see what features they have verses what you are looking at to give me a better idea of what is what.
    F1nut Posts: 51,749
    edited January 2018
    Here's another, over engineered to the Nth degree.
    http://www.audiofast.com/main.asp?idm=73&ids=397&r=0&wersja=1
  • BlueFox
    BlueFox Posts: 15,251
    I love my solid maple rack from Mapleshade. It weighs 500 lbs empty, and is vibration free regardless of the SPL. You can create your own custom design to fit your need.
    http://www.mapleshadestore.com/samsonracks.php
    Nice. Their stuff is gorgeous and relatively reasonably priced.
    It's interesting how each company seems to have their own approach for what they think is the best way to support the shelf. For example, Adona seems to like this way:
    I wonder if any one particular way is dramatically better than another, in terms of stability.
  • soundfreak1
    soundfreak1 Posts: 3,414
    The only issue (it seems) none of the manufacturers deal with is standing waves. Don't really know if anything can be done about those. But the points do seem to isolate the Shelf completely as opposed to having the Shelf attached to the supports.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    I wonder at which point vibrations from the speakers even come into play. BlueFox mentioned high SPLs. Even when I listen at what I perceive as louder volumes, I can't feel any resonance of vibration leaving my 703s at all, the cabinets themselves and what they are sitting on isn't resonating at all.
    My current rack is just physically wobbly from side to side, so I think most of the vibrations it's dealing with would be from me or my wife walking past it or her dancing to a song that she likes when in close proximity to it.
    I had a TT on a wobbly table and had rumble feedback BAD. Some guys and or gal told me to get a solid table asap. The new solid table eliminated the rumble. I think the SDA-SRS2's were vibrating that table with low soundwaves.
    Oh yeah I see the advantage for TT for sure. My current rack is nowhere near up to the task of supporting a TT.
    So that's one benefit of getting a new one, a TT in the bedroom. Win-Win.
    Tony M wrote: »
  • halo
    halo Posts: 5,616
  • BlueFox
    Clipdat wrote: »
    The vibrations on the equipment rack, and on the equipment, come from the speaker sound waves hitting them. Gear is susceptible to the tiniest vibrations, and those vibrations alter the sound. That is why in addition to having a solid, vibration resistant rack, the gear should also be on some type of vibration draining footer. I use Mapleshade Micropoint Brass footers, but there are other vendors and types.
    Thanks for the insight. You might have better ears than I do. I don't know if I'd be able to discern/detect a sound wave's vibration/impact on the equipment and the associated negative sound quality.
    BlueFox wrote: »
    F1nut Posts: 51,749
    It's all about lowering the noise floor, which is something one doesn't notice until it is lowered.
    Ah, interesting. Well I'm afraid I don't have experience with the noise floor as it's being described.
    When I think "Noise Floor" I think of background/ambient noise, and how listening late at night is better in that regard because there's less "white" noise coming from outside, cars going down the street, etc.
    It's possible Bud's system is just really THAT much more revealing, and thus the little things like isolation feet start to add up and make a difference.
    It's mentally difficult to wrap my head around THAT nice of a system.
    DSkip wrote: »
    Don't ever say that again please. You can hear a difference... everyone can. If your system was at his level those details can greatly alter the sound. You would be intimately familiar with the sound and pick up on it quickly.
    I'm not being mean but that type of thinking is deadly to growth in this hobby. It represents a closed mind in a way.
