SDA CRS+ With an External Crossover Twist.... :-)
  • gimpod
    gimpod Posts: 1,793
    edited March 2016
    Toolfan66 wrote: »
    Just a personal thought......I might try to relocate that long resistor along the back of the board to clean up the look. I have never liked how those look cramped or wedged onto boards at odd angles.
    I agree, that's the only thing I don't like about the Dueland Resistors, but I will probably just leave it, it's been that way for a few years now..
    Here ya go Larry, The Red X's (with J5 in place) all connect to pad B and the Red Y's connect to pad G.
    Something I plan on doing to my CRS+'s is strip the cabs and take them to a body shop and have them painted a gloss black (Piano Black, no orange peel etc..) then (Hint, Hint) replace that piece off molding below the speaker grills with brushed aluminum of the same shape. If you decide to do the aluminum thing please let me know as I'm having a hard time finding someone who will do this without charging me an arm & leg plus my first born.
    Toolfan66 Posts: 18,414
    My binding post plates as well as my Neutrik plates..
    12 ga #4 Stainless with 3/8 thick delrin on the back side..
    These Neutrik's are for my Dreadnought, I just put them in to give you an idea.. The Neutrik's for these will be here Monday..
    xschop Posts: 5,796
    Those look nice. Is it a must to use non-magnetic alloys when making the custom electronic/crossover housings?
    I have wondered the same thing, but I do see where it makes sense in doing so, but at the same time, most all amps, pre amps, CD players, blue ray players etc. have steel housings..
    F1nut Posts: 52,382
    Looking good Larry.
    F1nut Posts: 52,382
    I've had the idea to build external crossovers for my office speakers for a while now. One of the reasons being the components I want to use would take up way too much internal volume. I recently sat down to design the box and would love to have them made from aluminum, but may end up making them from MDF. Either way I think it's a good idea that they be non-magnetic.
    xschop Posts: 5,796
    I had some spare 304ss, but held off making my crossover adapters, because machining it or a grind/polish returns it back to its magnetic state. I need to adapt the Erse inductors and will ask how they need to be orientated in my thread when they show up.
  • MrBuhl
    MrBuhl Posts: 2,419
    Man that is some beautiful work! Can't wait for the updates!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • boston1450
    boston1450 Posts: 7,758
    Dang Larry everything looks great. Cant wait to see finished results. Great work
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    Seeing double!!!
    I am loving how the internal wiring harness is looking..
    So I made a prototype crossover case that will mount to the stands, wanted to play with the layout with the 16mh inductor, what are your thoughts, back wall or side wall??
    Tomorrow I will be making this out of .090 aluminum with a .125 aluminum top..
  • westmassguy
    westmassguy Posts: 6,850
    You'll want it away from the steel frame, and 90 degree opposite from the board inductors on either plane
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    xschop Posts: 5,796
    Those are also very nice. Will you tig the lower portion AL?
    xschop wrote: »
    Yes sir, already done, and ready for the powder coater..
    EndersShadow Posts: 17,753
    Is any of it going to be see through? Might be cool to be able to see inside and have it light up or not to show off your work...
    I thought about it, but no it will be all be black..
    3/8 thick delrin will be the base for the crossovers..
  • vmaxer
    vmaxer Posts: 5,123
    Too sexy!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Two cables done!!
    Jesse, I missed this, can you send me a drawing??
    F1nut Posts: 52,382
    Larry, I'm still in the planning stages, but thank you!
    I'm being lazy......did you color the Neutrik gaskets or do they sell them that way?
    edited March 2016
    They sell them that way.. B)
    White is the tweeter.
    Red is the Drivers..
    F1nut Posts: 52,382
    Ah, cool!
