Just a personal thought......I might try to relocate that long resistor along the back of the board to clean up the look. I have never liked how those look cramped or wedged onto boards at odd angles.
I agree, that's the only thing I don't like about the Dueland Resistors, but I will probably just leave it, it's been that way for a few years now..
Here ya go Larry, The Red X's (with J5 in place) all connect to pad B and the Red Y's connect to pad G.
Something I plan on doing to my CRS+'s is strip the cabs and take them to a body shop and have them painted a gloss black (Piano Black, no orange peel etc..) then (Hint, Hint) replace that piece off molding below the speaker grills with brushed aluminum of the same shape. If you decide to do the aluminum thing please let me know as I'm having a hard time finding someone who will do this without charging me an arm & leg plus my first born.
Pink Floyd, Just makes me want to turn it up too 12 and share it with the world!!. JMO
Unfortunately for most of us we only get to experience the first day and then we can't even remember it.
"Close only counts in Horseshoes, Hand Grenades and Thermonuclear Weapons."
"50% Why... That's almost half."
"I know, I'm sick and need help."
---- Gimpod Custom 4th & 5th Gen SDA Circuit Boards
"The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
I have wondered the same thing, but I do see where it makes sense in doing so, but at the same time, most all amps, pre amps, CD players, blue ray players etc. have steel housings..
I've had the idea to build external crossovers for my office speakers for a while now. One of the reasons being the components I want to use would take up way too much internal volume. I recently sat down to design the box and would love to have them made from aluminum, but may end up making them from MDF. Either way I think it's a good idea that they be non-magnetic.
I had some spare 304ss, but held off making my crossover adapters, because machining it or a grind/polish returns it back to its magnetic state. I need to adapt the Erse inductors and will ask how they need to be orientated in my thread when they show up.
Man that is some beautiful work! Can't wait for the updates!
VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power VA 2 Channel Focal Electra 926 speakers, Pass Labs X150.5 Amp, Eastern Electric MiniMax Preamp (Tutay mods), Eastern Electric Minimax CDP (Scott Nixon mods), Music Hall mmf 5.1 Turntable, Parks Audio Budgie Phono Pre , Audioengine B1 streamer, MIT S3 IC's / MIT Shotgun S3 Speaker Cables / PS Audio power cables Noggin Schiit Valhalla, Pangea, Phillips Fidelio X1, Polk UF8000
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
So I made a prototype crossover case that will mount to the stands, wanted to play with the layout with the 16mh inductor, what are your thoughts, back wall or side wall??
Is any of it going to be see through? Might be cool to be able to see inside and have it light up or not to show off your work...
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Larry, I'm still in the planning stages, but thank you!
I'm being lazy......did you color the Neutrik gaskets or do they sell them that way?
12 ga #4 Stainless with 3/8 thick delrin on the back side..
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Randy / Maine
SDA-CRS+ 198 tweeters. WMG upgraded crossovers.
Larry's rings. Stands w/Polk Logo & Spiked nicely
RTA15TL 198 tweeters. WMG upgraded crossovers.
Larry's rings. Gloss tops shine. Spiked nicely
Cs1000p-Yamaha-Parasound-Acurus
MIT speaker cables-Pangea powercords
Camp: Klipsch Heresy ii's Dayton Audio
Dta100a MITcables.Dedicated 100w Grape Solar
panel 2d/c batteries 400w inverter
Seeing double!!!
I am loving how the internal wiring harness is looking..
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
"And keep her under 70, would you, huh? Betty likes a slow ride"
Yes sir, already done, and ready for the powder coater..
I thought about it, but no it will be all be black..
3/8 thick delrin will be the base for the crossovers..
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Two cables done!!
Jesse, I missed this, can you send me a drawing??
White is the tweeter.
Red is the Drivers..
