SDA CRS+ With an External Crossover Twist.... :-)
2456789
  • gimpodgimpod Posts: 1,784
    edited March 2016
    Toolfan66 wrote: »
    Just a personal thought......I might try to relocate that long resistor along the back of the board to clean up the look. I have never liked how those look cramped or wedged onto boards at odd angles.
    I agree, that's the only thing I don't like about the Dueland Resistors, but I will probably just leave it, it's been that way for a few years now..
    Here ya go Larry, The Red X's (with J5 in place) all connect to pad B and the Red Y's connect to pad G.
    Something I plan on doing to my CRS+'s is strip the cabs and take them to a body shop and have them painted a gloss black (Piano Black, no orange peel etc..) then (Hint, Hint) replace that piece off molding below the speaker grills with brushed aluminum of the same shape. If you decide to do the aluminum thing please let me know as I'm having a hard time finding someone who will do this without charging me an arm & leg plus my first born.
    Pink Floyd, Just makes me want to turn it up too 12 and share it with the world!!. JMO
    Unfortunately for most of us we only get to experience the first day and then we can't even remember it.
    "Close only counts in Horseshoes, Hand Grenades and Thermonuclear Weapons."
    "50% Why... That's almost half."
    "I know, I'm sick and need help."
    Gimpod Custom 4th & 5th Gen SDA Circuit Boards
    "The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
  • Toolfan66Toolfan66 Posts: 14,332
    My binding post plates as well as my Neutrik plates..
    12 ga #4 Stainless with 3/8 thick delrin on the back side..
    These Neutrik's are for my Dreadnought, I just put them in to give you an idea.. The Neutrik's for these will be here Monday..
  • xschopxschop Posts: 1,129
    Those look nice. Is it a must to use non-magnetic alloys when making the custom electronic/crossover housings?
    I have wondered the same thing, but I do see where it makes sense in doing so, but at the same time, most all amps, pre amps, CD players, blue ray players etc. have steel housings..
  • F1nutF1nut Posts: 43,620
    Looking good Larry.
    I've had the idea to build external crossovers for my office speakers for a while now. One of the reasons being the components I want to use would take up way too much internal volume. I recently sat down to design the box and would love to have them made from aluminum, but may end up making them from MDF. Either way I think it's a good idea that they be non-magnetic.
    I had some spare 304ss, but held off making my crossover adapters, because machining it or a grind/polish returns it back to its magnetic state. I need to adapt the Erse inductors and will ask how they need to be orientated in my thread when they show up.
  • MrBuhlMrBuhl Posts: 2,427
    Man that is some beautiful work! Can't wait for the updates!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • boston1450boston1450 Posts: 6,605
    Dang Larry everything looks great. Cant wait to see finished results. Great work
    Randy / Maine
    SDA-CRS+ 198 tweeters. WMG upgraded crossovers.
    Larry's rings. Stands & Spiked nicely
    RTA15TL 198 tweeters. WMG upgraded crossovers.
    Larry's rings. Spiked nicely
    Cs1000p-Yamaha-Parasound-Acurus
    MIT speaker cables-Pangea powercords
    Camp: Klipsch Heresy ii's-Qinpu 2.5w tube amp-MITcables.Dedicated Solar 100w Grape
    solar panel-2 D/C/S batteries 400w inverter
    I am loving how the internal wiring harness is looking..
    So I made a prototype crossover case that will mount to the stands, wanted to play with the layout with the 16mh inductor, what are your thoughts, back wall or side wall??
    Tomorrow I will be making this out of .090 aluminum with a .125 aluminum top..
  • westmassguywestmassguy Posts: 6,512
    You'll want it away from the steel frame, and 90 degree opposite from the board inductors on either plane
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
    Those are also very nice. Will you tig the lower portion AL?
    xschop wrote: »
    Yes sir, already done, and ready for the powder coater..
  • EndersShadowEndersShadow Posts: 17,035
    Is any of it going to be see through? Might be cool to be able to see inside and have it light up or not to show off your work...
    I thought about it, but no it will be all be black..
    3/8 thick delrin will be the base for the crossovers..
  • vmaxervmaxer Posts: 4,591
    Too sexy!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Jesse, I missed this, can you send me a drawing??
    Larry, I'm still in the planning stages, but thank you!
    I'm being lazy......did you color the Neutrik gaskets or do they sell them that way?
    edited March 2016
    They sell them that way.. B)
    White is the tweeter.
    Red is the Drivers..
    Ah, cool!
Howdy, Stranger!
