cable break in believer
1…34689…11
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited October 2010
    sm88 wrote: »
    It was, up until it was hijacked by a straw man fallacy and followed through with a cocktail of smug posturing and slander
    ah. I think that sums up most arguments that appear on this site.
  • WilliamM2
    WilliamM2 Posts: 4,829
    edited October 2010
    headrott wrote: »
    Why not use an IMPARTIAL person for escrow?? Why would Larry trust CokewithVanilla or XCapri over you? They seem to have as biased a view as you.
    Greg
    So their bias determines their honesty? I doubt it.
    I don't see why anyone would have to hold the money. I don't think either side would welch on charity, or at least I would hope not.
    And two or three members could be chosen by each side to hold the encrypted file, that way we'd know there's no funny business there either.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2010
    halo71 wrote: »
    This was my long term feeling as well. And my system is by no mean anywhere near mid line compared to what some guys on this forum have. Running an Onkyo preamp, M504 power amp, old Phillips DVD player and Monitor 10's.
    Freddy here on the forum so graciously GAVE me a pair of MIT Terminator 6's last month. I had been running some cheap Monster cable for years. Hooking them up....I could tell subtle differences on some recordings. Much more difference on other recordings. Sarah Mclachlan's Angel....OMG. I actually had chills! I switched between the MIT's and the Monster's about 6 times comparing them on this one recording. And it was truly amazing how much better the MIT's sounded. Tighter deeper bass....her voice....sounded like she was in the room with me! Can't imagine how much better a set of RDO's and XO upgrades will make things! So yeah equipment surely has something to do with it. But even on low end gear I think there is a difference to be heard.
    On the subject of cable burn in. I am not a naysayer really. And never asked the question for sake of a **** storm. But from what I have read, and probably way too little at that. Isn't the idea of burn in rearranging the electrons in the wire? And would it not take quite a bit of voltage to do that? With all the talk about burn in. I don't think I have ever head anyone speak of burn in for spades or banana plugs. What about them?
    Glad you liked them :D
    I'm a believer, but I'm not going to argue with naysayers to convince them otherwise.
    To each his own. Keep the tunes going!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • cokewithvanilla
    edited October 2010
    If you go through with the cable test or challenge or whatever, I suggest, if money permits, that you send as many cables as possible... at least 7. Oh, and I also suggest that a random number of them be burned in for the same amount of time. Toolfan should not know how many are burned in, only that at least one is or isn't
    I can just see the outcome if you send 4...
  • jinjuku
    jinjuku Posts: 1,523
    edited October 2010
    WilliamM2 wrote: »
    Good idea. You, Xcapri (if he agrees), Coke W/V and Whomever Toolforlife would like.
  • WilliamM2
    edited October 2010
    Welch??? Well I don't think I need to prove my honesty on this forum or my word and contribution to not only the fourm but Polk Audio as well.
    Nuff said..
    I agree, like I said, I don't think anyone needs to hold the money.
  • jinjuku
    edited October 2010
    The outcome is 6 possible:
    AB
    AC
    AD
    BC
    BD
    CD
    There is a 16.6% chance of simply guessing it correctly. I would take those odds any day of the week.
  • headrott
    headrott Posts: 5,496
    edited October 2010
    WilliamM2 wrote: »
    So their bias determines their honesty? I doubt it..
    Uh huh, and you believe all politicians, judges, etc. are honest I take it? Even with a biased opinion.
    WilliamM2 wrote: »
    I am not saying anyone would welch on sending the money to charity at all. I am just saying that people acting as an escrow holding the information to the true cable designations (i.e. which ones are burned in and which aren't, assuming there are really cables sent that ARE burned in and some that aren't) can be prone to dishonesty (not saying they would be) due to their bias. Do you disagree with that?
    Greg
    Edit: Being as Larry has never heard the Belden cables before (I don't think) how do we know that there is an audible difference after being burned in? (I can see where you want to go with this, but don't....please) Wouldn't a cable that Larry agrees has an audible difference after being burned in be more appropriate?
  • bobman1235
    bobman1235 Posts: 10,822
    edited October 2010
    Um, not sure how or why I got mentioned in this whole thing - I guess that's what makes me impartial?
    I haven't read through the whole thread but if you guys need me to do be some sort of impartial holder of stuff or moneys or whatever I'm happy to do it. Just let me know what I need to do.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited October 2010
    jinjuku wrote: »
    You don't get to set the terms. My cables my terms. I already met you half way. You managed to climb on the pony, saw the view for what it is and climbed right back off.
    headrott wrote: »
    ...assuming there are really cables sent that ARE burned in and some that aren't) can be prone to dishonesty (not say they would be) due to their bias.
    How do you propose to certify that you are actually sending cables with the specified amount of burn in? Is TFLF just supposed to take your word for it?
    Well? Is he?
  • WilliamM2
    edited October 2010
    headrott wrote: »
    I am not saying anyone would welch on sending the money to charity at all. I am just saying that people acting as an escrow holding the information to the true cable designations (i.e. which ones are burned in and which aren't, assuming there are really cables sent that ARE burned in and some that aren't) can be prone to dishonesty (not say they would be) due to their bias. Do you disagree with that?
    Greg
    It's possible, that's why I suggested several people have the zip file sent to them. They could then compare , and make sure they all have the same file, and whether or not the correct cables were chosen.
  • headrott
    edited October 2010
    Please see the edited portion of my last post.
    Greg
  • cokewithvanilla
    edited October 2010
    Are you suggesting that he make a time lapse video of burning in cables? or that he sends them to a member to burn in?
  • DarqueKnight
    edited October 2010
    What is so hard about arguing without taking things personal?
    That ability is only obtained by those who finish law school and pass the bar exam.;)
  • headrott
    edited October 2010
    I am suggesting that cable is used that Larry agrees has a difference in sound after being burned in. That way he will know if they have really been burned in or not. Sounds fair.
    Greg
  • ohskigod
    ohskigod Posts: 6,505
    edited October 2010
    sm88 wrote: »
    you forgot your meds again, schizophrenia is no laughing matter and the meds must be taken under strict regimentation for full desired effect. :p
    by the way, why do I have a feeling you think 9/11 was an inside job too? I'm not arrogant enough to say it's fact, call it intuition.
    do you own a tin foil hat?
    do you believe people hide in your bushes and spy on you, do they work for the CIA?
    dude, I can go all day with this..........long story short, your really coming off like a paranoid loon.
    when you report this post, be sure to tell Patrick and/or Al I said hi, and that I forgot to mail the shirts from Polkfest. I've been busy as hell
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • cokewithvanilla
    edited October 2010
    headrott wrote: »
    Greg
    What? "agrees has a difference in sound after being burned in"??? I thought this exercise was to see if there is a difference in burn in... not "we know there is a difference, now try to pick it out"
    edit: oh, wait.. I think I get it, you mean a brand of cable that experiences burn in? you are also assuming that there is only one outcome.
  • ohskigod
    edited October 2010
    this thread, and challenge, reaks of fail
    http://www.youtube.com/watch?v=FMEe7JqBgvg
  • sm88
    sm88 Posts: 353
    edited October 2010
    ohskigod wrote: »
    How does pointing out a straw man argument that led to this whole ridiculous series of posts make me paranoid? Would you like to reread what I wrote and perhaps use a dictionary? I really don't mean to offend you here but you aren't making a bit of sense unless you quoted the wrong post.
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
  • DarqueKnight
    edited October 2010
    sm88 wrote: »
    Because clearly the price of the cable has a huge effect on whether or not it burns in. The $10,000 cables you so modestly boast of are obviously a better candidate than $100 cables. That is what this hobby is all about, right? Who spends the most money. The more expensive system is ALWAYS the best. His cables are too "inexpensive" to be worth listening to, and the peons who are so beneath you and your high consultation fee best cower before the 99.9999% pieces of silver you paid ten times the material cost for.
    The rule of thumb in high end audio is that retail price is five times material cost. Therefore, for a set of cables retailing for $10,000, the material cost is about $2,000. If you are a shrewd shopper and buy used or demo goods, you typically pay no more than 50% of retail.
    The forum has a group therapy circle for those who find relief in discussing their misconceptions about me and how I pursue this hobby.
    Have fun:
    Darqueknight Group Therapy Relief
    heiney9 Posts: 25,724
    edited October 2010
  • ohskigod
    edited October 2010
    sm88 wrote: »
    you're right bro, it's ok..
    edited October 2010
    http://www.audioasylum.com/cgi/vt.mpl?f=cables&m=149280
    See folks, all audio sites have cable debates, not just us. I say our reputed naysayers give CP a break and head over to another forum and get their "ya ya's" out.
    edited October 2010
    Did anyone really expect a cable thread to turn out any different than it has ?
    Seriously, if those who don't believe in cable burn in, bigfoot, or aliens, man, don't jump in the thread and move on....
  • ohskigod
    edited October 2010
    tonyb wrote: »
    or just say,
    "I really dont belueve cables do all that much, at least in my experience"
    ....as opposed to
    "Cables do nothing, your ears are lying to you!!!!! if you dont prove it to me definitively, then it isnt true......lalalalalalalalala can't hear you!!!!!"
    holy crap. LOL
  • headrott
    edited October 2010
    Keiko wrote: »
    The trick in cooking roast Bigfoot is slow burn in,.....
    That's funny. That's the same recipe I use for burning in my cables.;)
    Greg
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2010
    halo71 wrote: »
    That is excellent Gary. Good on Freddy. I believe I sent those to him (sold) a while back, I begot them initially from Russman and a third cable from used-cables, the bass was the thing I noticed right out as well, yet on a totally different system, so there you go. When you head this way stop off in Brunswick and we will have a time of it chasing Rabbits.
    RT1
  • WilliamM2
    edited October 2010
    heiney9 wrote: »
    If you don't like the discussion, why don't you give CP a break and head somewhere else? Or just don't click on the thread.
    edited October 2010
    Oh William, your retorts are priceless. You should write for one of those failed tv sitcoms.
  • halo71
    halo71 Posts: 4,644
    edited October 2010
    RT1
    Sounds like a plan!
    So these cables made it back to the east coast....well almost. lol
    --Gary--
