Equipment Racks
  • DaveHo
    DaveHo Posts: 3,481
    That's terrible QC. I don't think you are being too picky. I wouldn't accept that.
    Tony M Posts: 11,017
    edited February 2018
    It seems VTi has gone cheap on the cups. Why isn't that common knowledge now?
    Do the older VTi stands have welds on top of the cross bars?
    I also believe VTi could include a 2.00 rubber mallet in one of the boxes so somebody doesn't have to go to the neighborhood hardware store or grocery store either. I've seen rubber mallets in the 3' wide hardware display at Harris Teeter here.
  • stangman67
    stangman67 Posts: 2,190
    I bought my vti unit last year and it didn’t exhibit any of these issues. When I bought mine I was fully aware that the cups were of lesser quality than they used to be. At the end of the day this is a still a cheapish rack and about the best you’re gonna do for the price point. I would however reach out to the company and describe your issues and see what they say
  • halo
    halo Posts: 5,616
    @helipilotdoug is on the case for Drew folks. I'm sure we'll be hearing good news soon. Doug stands behind his products and the products he offers to his clients. I'm sure that this will be no exception.
    SCompRacer Posts: 8,352
    My first VTI rack was the double wide. Over the years I may have exceeded max weight and had point punch through on eight caps. I contacted VTI and they sold me replacement caps. I replaced the punctured caps before I sold the rack.
    I needed some large diameter spike pads for my speakers. I used a hole saw and drilled some hardwood discs. I glued the wood discs into the older VTI caps and added heavy duty adhesive felt on the bottoms. They are thicker than the caps on newer racks, as mentioned and are holding up well. Speakers are ~ 130 pounds. I wouldn't do this with the newer caps.
    Clipdat Posts: 12,608
    Hey Kerry, you are right. On this one particular shelf section, the caps aren't fully installed and seated on the ends of the tubes.
    Additionally, there are small raised lips of metal on the end of the screw holes that you screw the spikes into. As a result, the spikes can not sit fully flush with their mating surface, instead they bottom out against the small lip of metal. This is what is making them skewed off at an angle like I tried to illustrate in the photos.
    Lastly, some of the spikes themselves just don't seem to be true and straight. I would notice with varying degrees of severity, that when I would screw them into the holes, the pointed end would be rotating in the air and making a circle. This means they weren't tooled correctly when they were made or when the threads were cut into them. This is slightly disappointing because I feel like I could get higher quality nuts and bolts for .30 cents each down at the local hardware store.
    kharp1 wrote: »
    @Clipdat It looks like the end caps aren't seated properly. As if they went in slightly c@ck eyed and aren't seated flush thereby throwing off the projection of the spikes, or, the receiving cup. Might try taking the spike out and lightly tapping with a mallet, or dead blow, to see if they seat properly. Should use a piece of sacrificial wood covered in tape to keep from marring the surface.
    Yeah, I'd be a little ticked, but, would make a decision to try and fix, or, return it. No hill too high...
    Your comment, and others, seem to imply that the caps are removable somehow. I'm not sure if they changed the design from how they used to be, but the caps are stuck on there and aren't going anywhere. They aren't just sitting loosely on top of the legs. I wouldn't be surprised if they were welded or glued or something. There is no budge or give to them.
    That being said, it would be really difficult to try to get the legs all aligned by eyesight. As far as the overall alignment of the unit, I would defer to the factory workers who are making/welding these to ensure that. They're all based off of a master jig, so really any abnormal fitment or things that are out of tolerance is the fault of the assembly worker.
    delkal wrote: »
    I agree that the caps are not fully seated. But I think the bigger problem is the legs are not aligned. I would try and remove all of the endcaps and bend the legs till they are aligned with each other. Then place one on top of the other to check the fit and make sure the legs match up perfectly, it looks like yours are 1/8 - 1/4 inch off.
    And be careful bending! When everything lines up seat the endcaps fully with the mallet and wood.
    Thank you, sir! PM replied. I think I just need a new 7" shelf that hopefully is up to their standards.
    Drew, I'm sorry to hear you have problems with the racks. I'll get with VTI today and see what they will do about this. I have never had any problem with alignment like this in the past with VTI racks. Sending you a PM about this.
    Post edited by Clipdat on
  • kharp1
    kharp1 Posts: 3,453
    It really blows spending the time putting it together only to find out that you're going to have to take it back apart and send it back then reassemble another one. I realize that's likely thing when I order something like this. Like someone mentioned before, I believe when you finally get it squared away you'll have about the best rack at that price point. They seem to jump up considerably from there, so, I think it's a good buy. Doug seems to be all over it, so that's a positive.
    I've suffered through several cappy racks/stands and decided with the system I'm putting together is likely end game, so, I want a worthy piece of furniture for a rack. I haven't been able to bring myself to let go of the monet yet. It's killing me to do it. Somewhere in my mind the thoughts of "go get some cinder blocks and 2x12's!"
    Due to the modular nature of the design, it might not be necessary to send the entire unit back. I believe I'd be satisfied with just a replacement 7" shelf that isn't as wonky as this particular one.
    From a shipping costs perspective, it's probably not even worth it for VTI to pay to have "defective" pieces returned.
    kharp1 wrote: »
    @Clipdat, I thought you had to pop those caps onto the legs. I agree 100% that they should never had left the factory installed like that. :#
    Interesting that they won't move with force to align them. ( rubber mallet time again?)
  • stangman67
    They can be removed for sure, just have to put some force into it. People pop them off to load with lead shot all the time
    I think they must've changed the design and/or the way they are made. I just went and tried to pry, pull, and yank at one of the caps until my fingers were red and painful.
    It's fully stuck on there and isn't budging.
    stangman67 wrote: »
  • voltz
    voltz Posts: 5,384
    Hey Drew
    My VTI caps won't come off either, I would probably damage them if I try any harder to remove the caps.
  • verb
    verb Posts: 10,176
    Hi @clipdat just got home looking at this thread. Wow! Hey a good way to know if the legs are not perfectly true is to measure the diagonal distance from pole to pole. They should be identical. This goes for every shelf. Measure the ends with the welded parts, then compare to the free ends. They should match.
  • Jaybeez
    Jaybeez Posts: 748
    delkal wrote: »
    I hope everything works out or you get a refund......... Its not good spending a lot of money on "cheap". But if you decide to spend a lot less for "cheap" check out this Sanus rack. Its only $120 shipped, can hold 200 lbs, and gets good reviews on Amazon. I know it is bare bones and not even close to most of the racks mentioned but it doesn't look too bad (at least to me). I just ordered one last night (before I looked at this thread). If anyone wants an update I will let you know when it gets here.
    https://newegg.com/Product/Product.aspx?Item=9SIA1CZ1G98946
    I have an older version of this rack (without the wire holes in the back) and really like it. Serves it's purpose quite well. I just ordered 12 inch replacement bars for the bottom shelf, as Zach's old amp doesn't fit in the 8 inch space provided.
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
    Update: VTI will be shipping me a new 7" frame section.
    Thanks so much @helipilotdoug for following up with VTI on my behalf and taking care of this for me. I literally did not have to lift a finger, as soon as @helipilotdoug saw my posts he was in touch with VTI and getting the ball rolling on a resolution for me. That's great customer service! Thank you!
  • helipilotdoug
    Thanks for the kind words Drew. I'll send you tracking once VTI sends it to me.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • helipilotdoug
    New 7" frame on the way and should be delivered Thursday :)
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    Thank you! I'll post up some comparison pics when it arrives. I'll be looking to see if the replacement has fully installed/flush endcaps, and no thread burs sticking up raising the surface where the spikes screw into, making them sit askew.
    Thanks again!
  • helipilotdoug
    Clipdat wrote: »
    Thanks again!
    Keeping my fingers crossed that this frame will be much better!
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    New frame arrived.
    Let's start by taking a look at the issues with the old frame:
    Thread bur #1:
    Thread bur #2:
    Crooked cap #1:
    Crooked cap #2:
    Now let's take a look at the new frame and see how it looks.
    Unfortunately it also has a thread bur:
    This results in the spike bottoming out on the bur instead of flush with the endcap when screwed in, and thus it does not sit at a straight 90 degree angle:
    You can see the slight gap that gets created as it is not flush with the endcap:
    The new frame also has an issue with one of the endcaps not being fully seated. You can actually see some of what I'm guessing is adhesive on the shaft peaking out:
    Lastly, it's also not aligned correctly and thus isn't lining up with the frame below. You can see the top caps of the frame below getting scratched from me trying to verify if the alignment is accurate and the shelf slipping and scratching the cap:
    I attempted to bend and fix the alignment of that corner, but upon doing so, another corner becomes out of alignment:
    I don't own a "rubber mallet" so I can't try that, but I don't know what else to do about the alignment issue, and the issue with the thread burs making the spikes come out at a skewed angle.
    I guess I'm just either having really bad luck, or the quality is not meeting my expectations.
    I don't know what to do now :(
    Viking64 Posts: 6,693
    Perhaps you could use a Dremel or something similar to remove the burr? Maybe that will get you close enough for the spike to seat in the cup even with the caps not being true?
    I don't own a Dremel.
    And the issue of the spikes not being aligned with their recessions is due to the alignment of the frame itself, it's an independent issue from the spike issue.
    Viking64 wrote: »
  • marvda1
    marvda1 Posts: 4,874
    have you placed a piece of equipment on the shelf?
    the weight bows the frame and the spikes should fall in place.
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
    Yeah, I remember you or someone else mentioning this. I did not actually place a piece of equipment on the shelf, but I simulated doing so by pressing down firmly on it and seeing if it would fall into place. One spike did, the other still did not.
    marvda1 wrote: »
  • kharp1
    kharp1 Posts: 3,453
    I'm kind of thinking like Marvin, I believe that if you put some weight on it things will line up. You could put a piece of tape, or cloth, over the burr and tap lightly with a regular hammer to knock the burr down. To be more precise, you could use a bolt as a "set" and place the tip of the bolt on the burr and then hammer the head of the bolt thereby knocking the burr down.
    From what I can see, there seems to be a combination of 2 or 3 issues, any or all of which are contributing to the alignment issues. If the spikes can't screw down flush to the caps, that will create one issue. If the caps aren't seated correctly, that will create another issue and/or add to the first issue. Also, based on some of the images, it seems like the frame has some kind of warping/torquing issue.
    Have you tried rotating the frame 180 degrees to see if that changes anything? If the frame isn't square, that certainly should have some impact.
    Thanks for the suggestion. I'm going to hold off on irreversibly modifying anything as I don't know if I will need to send back the frame.
    Also, at the risk of sounding like a whiny snobby jerk, I don't feel that I should have to break out the tool box and start attempting to physically alter and modify a brand new equipment rack, in order to simply get it to look and perform as it does in the marketing photographs on VTI's website.
    kharp1 wrote: »
    Correct. You've accurately and succinctly described the situation.
    The frame cannot really be rotated permanently as a solution, because there are two unsightly bolt holes on the rear of the frame which are meant to remain out of sight. But, I went and tried it just now and it results in the misaligned pole sections reversing where they were previously misaligned.
    Viking64 wrote: »
    Clipdat wrote: »
    Ah, that makes sense. Front is front. Back is back. And the poles are messed up.
    One last suggestion: Would pairing the upper and lower frames in a different order do anything or do they need to be where they currently sit for aesthetics and/or functionality?
  • Joey_V
    Joey_V Posts: 8,521
    Now we know why those really expensive racks cost so much.
    I have VTI, no issues like this.
    Good luck clipdat, not sure what to do next
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
