HELP! Problem w/browsing Club Polk
12346
  • Serendipity
    Serendipity Posts: 6,975
    edited October 2007
    audiobliss wrote: »
    Can you install the LiveUpdate 3.1 (symantec Corporation) and Symantec AntiVirus? You'll probably have to do it in a certain order, so if one way doesn't work, I'd try the other one.
    I'm sure they're not causing any problems at all, but if you want to, I can't see any bad effects from uninstalling:
    HP Help and Support
    HP Software Update (might wanna keep that one though, so it'll keep your HP drivers and software up to date)
    HP User Guides 0001
    Yes, that's the HP bloatware I was talking about.
    Nope, LiveUpdate and Symantec AntiVirus both cannot be uninstalled.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • audiobliss
    audiobliss Posts: 12,518
    edited October 2007
    Dangit. I know it's not the way to do it, but if it were my laptop I'd just go to Program Files, find the Symantec/Norton/AntiVirus folder and delete them.
    Actually, I'd pop in my Windows XP Pro CD I bought from school and reformat the dern thing.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    Do you really think this calls for a reformat? I mean my system isn't loaded with THAT much stuff, except for the HP bloatware/junk.
  • audiobliss
    edited October 2007
    I personally would, 'cause I'd much rather run AdAware, Spybot, and AVG instead of that Symantec stuff.
    Do you have to? No. Uninstalling and reinstalling IE6 from that link I gave you may very well solve your problem. Then again, just switching to Mozilla Firefox (it's great!) probably will, too.
    Really depends on what you want at this point.
    Oh, and, again...about those screenshots... :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    Oops, about the screenshots I am using Print Scr for the desktop shots and Alt+Print Scr for the window shots (just so that the window fills the entire shot), paste it into Paint, but I don't compress it in paint.
    Then I use Microsoft Office Picture manager to compress the shots (much better than Paint) into smaller JPEGs.
  • audiobliss
    edited October 2007
    Hmmm. I don't think I have MS Office Picture Manager. But I bet I have it on a CD. I have Office 2003 Pro.
    Thanks.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited October 2007
    I can't even get my list of programs on one screen. So how would you handle that? Is there a way to get it all in one screenshot?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    If you have Office 2003 Pro (I think) it's on the second CD. In the Student and Teacher edition, it's on the first and only CD.
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    In Add/Remove Programs or Start --> Programs?
  • audiobliss
    edited October 2007
    In Add/Remove Programs.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    Try changing your screen resolution. The higher the resolution, the more you can fit on one page.
    For my PC 1280*1024 is more than enough to fit all the programs in Add/Remove Programs.
    Can you post a screen shot to explain?
  • audiobliss
    edited October 2007
    My screen resolution is 1680x1050 on a 21.6" LCD. :D I don't think that's the problem. :D:D
    I'm just saying that I have so many programs installed that they're longer than one window. I was just wondering if there's a way to take a screenshot to include them all so I wouldn't have to take a screenshot, scroll down, and then take another one.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    Does the Alt+Print Scrn work better? I find on my computer maximizing the window also helps.
    Again, do you have a screen shot to explain?
  • audiobliss
    edited October 2007
    Yeah, here it is. Screen is maximized and I used alt + Prt Scr.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    Wow, how many programs do you have installed?!!
    And a 1680x1050 screen doesn't fit it!
    I don't know what to tell ya
  • audiobliss
    edited October 2007
    I have 50 programs listed in Add/Remove Programs.
    This is on the computer I just built last weekend. I'm only using 24GB on the main HD, so far. My Documents is on another HD.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    audiobliss wrote: »
    I have 27 programs listed, and this is on the laptop I've had for 3.5 years.:D
    Methinks you've got a lot of software around the house :)
  • audiobliss
    edited October 2007
    Actually, not so much so. A lot of them are games, Office and Visual C++ are for school, and the rest are pretty much either for the web (AIM, Firefox, MSN Messenger, AVG, etc) or drivers and such.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    I must wonder what your start menu looks like then :)
  • audiobliss
    edited October 2007
    Wonder no more!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    I like the way you have your desktop icons organized. Looks cool.
    Only have 3 desktop icons though...
  • audiobliss
    edited October 2007
    Most definitely.
    Security is in the lower left hand corner right above the Start menu.
    My web stuff is in the upper left corner.
    Then my computer utilities along the top.
    And my music apps below them.
    And all my gaming stuff over towards the right side.
    And nothing on the far right to leave room for my buddy list when I dock it.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited October 2007
    This has turned from a "computer problem" thread to "let's post screenshots thread" :)
  • audiobliss
    edited October 2007
    Booya!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Polk addict
    Polk addict Posts: 558
    edited October 2007
    I'm sad... You don't play wow...
    Chiranth
    hoosier21 wrote:
    Cobra + SDA's = dead amps laying all around.
  • audiobliss
    edited October 2007
    Nope. I might would enjoy it, though. I'm just not into paying money for games. AA is free, and the others my friend gave to me or gifted to me through Steam. So they're all legit, but I haven't paid for any yet.
    I'm DEFINITELY buying Test Drive Unlimited, though, no question about it. And GT Legends would be pretty nice.
    How much is WoW? I've seen a few people play...could be fun. But I'm not sure how much I'd like it.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Polk addict
    edited October 2007
    It's a month per month payment because it's on external servers...
    Chiranth
  • audiobliss
    edited October 2007
    Really? Wow, I didn't know that. Yeah, forget that.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    VR3 Posts: 29,532
    edited October 2007
    Hmmm
    I have no desktop icons -
    Havnt used desktop icons in... years
  • audiobliss
    edited October 2007
    You always just use the start menu?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
