HELP! Problem w/browsing Club Polk
Serendipity
Serendipity Posts: 6,975
edited March 2008 in The Clubhouse
Hi,
I'm getting this error message on my computer whenever I visit this forum. And then the forum window closes.
Anybody know what might be causing the problem?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
«134567
  • Serendipity
    edited October 2007
    I clicked "OK" and all I get is the following:
  • McLoki
    McLoki Posts: 5,231
    edited October 2007
    I assume you have powered off and back on? If so - try another brower (like firefox or opera) and see if you get a similar error. If they work, reinstall I.E.
  • exalted512
    exalted512 Posts: 10,735
    edited October 2007
    download mozilla, try again.
    -Cody
  • Serendipity
    edited October 2007
    McLoki wrote: »
    Yes, I have powered off and back on to no avail. I'd also like to point out that this does not happen on any other website, only when browsing Club Polk.
    Forum software problem maybe?
    It forces me off every time and I have to restart.
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited October 2007
    nothing to see here
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • Serendipity
    edited October 2007
    you need to be logged in, otherwise the forum s/w has no idea how many posts you have.
    eh? Can you elaborate a bit?
  • Disc Jockey
    edited October 2007
    bahh, wrong window, sorry. Was trying to answer somebody else
  • Serendipity
    edited October 2007
    Oh yeah it doesn't depend on whether I'm logged in/out, posting, or just reading.
  • Disc Jockey
    edited October 2007
    Try this:
    Step 1
    On the menu bar, click on 'Tools', then click on ‘Internet Options…’.
    Step 2
    In the window that pops up, go to the ‘Advanced Tab’. Scroll down to where it says ‘Browsing’.
    Step 3
    Uncheck the check box beside the phrase that says ‘Enable third-party browser extensions’.
    Click on OK and restart Internet Explorer.
    It also seems that this process is sometimes initiated by recent software or driver installs. Did you install anything recently? If so, you may want to try uninstalling it or going back to a recent restore point.
  • Serendipity
    edited October 2007
    Try this:
    Step 1
    Step 2
    Step 3
    Did that, but same problem. Also no, I did not install or change anything in the past 3 months on this computer. No new hardware either.
  • Serendipity
    edited October 2007
    As per going back to a recent restore point, I can't, because apparently System Restore was never enabled on this computer.
  • Disc Jockey
    edited October 2007
    Hmm, well I don't have much else to offer you. Maybe someone else will. Good luck.
  • Disc Jockey
    edited October 2007
    appadv wrote: »
    Ouch:mad:
  • Mike682
    Mike682 Posts: 2,074
    edited October 2007
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • Serendipity
    edited October 2007
    Mike682 wrote: »
    I went to that website and looked at the instructions, and to my surprise, the animations were already DISABLED!
    Now what?
  • Serendipity
    edited October 2007
    Please don't tell me it's spyware :(
  • Mike682
    edited October 2007
    scroll down to the bottom of that page, someone posted another method and claims to have worked
    Mains: polk R30
    Center: polk CSi3
  • Serendipity
    edited October 2007
    Mike682 wrote: »
    I looked at that method, but it only applies to systems with IE7.
    That's why I'm still using IE6. Waiting until all the bugs are fixed.
  • Serendipity
    edited October 2007
    I'm starting to think it's spyware. Attached is the processes that are currently running on my system - I don't see anything suspicious but I'm not 100% sure these days.
    What's weird is that I have a CPU Usage of 10% when the system is idle.
  • Mike682
    edited October 2007
    I'm not sure what it is
    Checked on Google: some say it is an Nvidia graphics file
    http://www.processlibrary.com/directory/files/sysfader/
    Mains: polk R30
    Center: polk CSi3
  • Serendipity
    edited October 2007
    Mike682 wrote: »
    I don't have a nVidia graphics card on my laptop, only an Intel GMA915 onboard graphics.
    Wait - all of a sudden I have a LOAD of processes running on my system, that weren't running before!
    WTH?
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2007
    Have you started simple, and deleted all your temp internet files, cleared your cookies, and re-logged back in?
  • Serendipity
    edited October 2007
    RuSsMaN wrote: »
    Yes.
  • Serendipity
    edited October 2007
    Totally puzzled - why are there 14 more processes running on my system after going on Club Polk?
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Somethings up. This might sound odd, but there doesnt seem to be enough precesses running.
    IE7 is working great, I suggest getting it.
    Under the visual effect tab...check off..let windows choose what best.
    But I have been using IE7 for months now without a glitch. Just keep it up to date.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Serendipity
    edited October 2007
    jakelm wrote: »
    Huh? My system is functioning normally.
    I think it could be spyware.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Take another snap shot of processes..
    I didnt think you had enough system or user processes running.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    appadv wrote: »
    No... I know that sounds wierd, but I don think so.
    Get IE7
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Serendipity
    edited October 2007
    jakelm wrote: »
    Here ya go:
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    appadv wrote: »
    WTH?
    Now thats more like it.
    Alot of those processes , that werent there, are needed...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
