CRS+ RestoMod
Standoffs.
You can replace with aluminum hex standoffs, which come in various lengths and various male/female versions. -
You can get standoffs in plastic or brass too. Nobody may see them but you'll know they are there. Available in 4-40, 6-32, 8-32.....
EDIT: Mouser has plastic barbed ones too.
https://www.mouser.com/ProductDetail/Heyco/10154F-P?qs=vHuUswq2%2BsxFzbMtOF2bBw==&mgh=1&utm_id=22410597967&utm_source=google&utm_medium=cpc&utm_marketing_tactic=amermsp&gad_source=1&gad_campaignid=22400569371&gbraid=0AAAAADn_wf3JE7FbfBrjtkEtwSMaGt0XJ&gclid=Cj0KCQjwlLDQBhDjARIsAPlIefFUJJxZJ8h9pu--8_zQ2iqWkRSkfSgeTVvBR_lUzjWRcMwZS0lvTJEaAlycEALw_wcB
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
But if they're metal, they could wear thru and short two adjacent traces.Don't take experimental gene therapies from known eugenicists.
Awesome as always brother! Thank you for the ultimate show and tell!
I've never heard of that happening, but they also sell nylon hex threaded standoffs, so you can sleep better at night. -
Dave @westmassguy sent M4 size for my stand off XO project for the RTA11 XO. Nylon hex stand off and nylon all thread with stainless M4 pan head machine screw/bolts to connect the stand offs to the binding post spool and XO board to the top of the stand off.
Is it OK to use metric in an older Polk speaker?
I've got some 7C's I ought to get into.
Ordered an M4 kit.
That one that resides right between the 2 large inductors had to be surgically removed.
Will have to get crafty to redo that one. Gorilla glue aint budgin'.Don't take experimental gene therapies from known eugenicists. -
Settled on X-over bracket design. Ordered some stronger black oxide M4 low-profile button heads. They'll bolt to female end of standoffs thru the thicker acrylic plates and be electrically isolated. Don't trust the 35 y/o pcb coating.
Installing a single stainless barrel nut with copper antiseize and a large solid brass thumb screw for the outside bling...
Started the drivers...
Stay focused...
Had some time and knocked out the brass
grill pegs...
Made a couple extra rings 0.540" tall for some MW6500s...😁
I'm afraid to ask.....
SCompRacer wrote: »Is it OK to use metric in an older Polk speaker?
Are those 7C's with SL1000's I see on the boxes?Don't take experimental gene therapies from known eugenicists. -
About 0.050" clearance all around...
Boxes say 7C but speakers have what looks like the sl2000 tweeters. Serial numbers of speakers match serial on boxes.
Styrofoam stuck on corners, other wise in nice shape.
The first year the 7C came out, it had the SL1000, then all the ones after that had the SL2000. According to @DeRod the enclosure walls are thicker on the 7C, than the 7B.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
We'll see if the 0.020 sag is gone permanently in a couple days from this 6511.
Used the weighted coil centering spud and heated the spider gradually. Its back to normal for now...
First of their species...
I may go back with a finer grit...
Any plans to clear coat the brass?
Give it a few weeks, it will clearly be coated with VerdigrisAny plans to clear coat the brass?
I'm doing a finer grit now, and then scotchbrite pad. Then I'll use Mothers diatomaceous. On 360 grade brass, should maintain its luster for a long time.
I went with a full 6" diameter and drilled the cabinet fasteners further out to brace the rear of cabinet that much more.
These things are heavy.
It's lunch time.Going get myself a chicken bacon sandwich.
Happy Memorial Day friends...
Ivan, I have some old machined 360 brass part offs and it hasn't oxidized much. The alloy is almost like day one from years ago...The OG shop speakers have taken a lickin' no doubt. Still jazzin'....
I have no doubt. I was being a smartypants
Ok, well a few other options are lacquer for brass or Renaissance wax
https://www.woodcraft.com/products/mohawk-lacquer-for-brass-gloss-aerosol-13-oz
Edit: If you use the spray lacquer be sure to clean the brass first with a degreasing agent.
