CRS+ RestoMod
124»
    F1nut Posts: 52,103
    Any plans to clear coat the brass?
    pitdogg2 Posts: 27,488
    edited May 25
    Give it a few weeks, it will clearly be coated with Verdigris
    xschop Posts: 5,561
    edited May 25
    I'm doing a finer grit now, and then scotchbrite pad. Then I'll use Mothers diatomaceous. On 360 grade brass, should maintain its luster for a long time.
    I went with a full 6" diameter and drilled the cabinet fasteners further out to brace the rear of cabinet that much more.
    These things are heavy.
    It's lunch time.Going get myself a chicken bacon sandwich.
    Happy Memorial Day friends...
    Post edited by xschop on
    xschop Posts: 5,561
    Ivan, I have some old machined 360 brass part offs and it hasn't oxidized much. The alloy is almost like day one from years ago...The OG shop speakers have taken a lickin' no doubt. Still jazzin'....
    I have no doubt. I was being a smartypants
    F1nut Posts: 52,103
    edited May 25
    xschop wrote: »
    Ok, well a few other options are lacquer for brass or Renaissance wax
    https://www.woodcraft.com/products/mohawk-lacquer-for-brass-gloss-aerosol-13-oz
    Edit: If you use the spray lacquer be sure to clean the brass first with a degreasing agent.
  • dkfreebird
    dkfreebird Posts: 1,188
    What I picked up from you look the same. The speakers I dropped off not so much.🤣 I can’t wait to see the finished product. Great work.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
    xschop Posts: 5,561
    xschop wrote: »
    Ill check out the wax. Once I settle on patina matched to RDO plates. Will do face operation next.
    xschop Posts: 5,561
    dkfreebird wrote: »
    Another reason we need a "badass" button.
