CRS+ RestoMod
    F1nut Posts: 52,406
    Standoffs.
    You can replace with aluminum hex standoffs, which come in various lengths and various male/female versions.
    SCompRacer Posts: 9,408
    edited May 19
    xschop Posts: 5,931
    But if they're metal, they could wear thru and short two adjacent traces.
  • VSAT88
    VSAT88 Posts: 1,390
    Awesome as always brother! Thank you for the ultimate show and tell!
    F1nut Posts: 52,406
    xschop wrote: »
    I've never heard of that happening, but they also sell nylon hex threaded standoffs, so you can sleep better at night.
    pitdogg2 Posts: 27,921
    edited May 19
    Dave @westmassguy sent M4 size for my stand off XO project for the RTA11 XO. Nylon hex stand off and nylon all thread with stainless M4 pan head machine screw/bolts to connect the stand offs to the binding post spool and XO board to the top of the stand off.
    edited May 19
    Is it OK to use metric in an older Polk speaker?
    :D
    I've got some 7C's I ought to get into.
    xschop Posts: 5,931
    Ordered an M4 kit.
    That one that resides right between the 2 large inductors had to be surgically removed.
    Will have to get crafty to redo that one. Gorilla glue aint budgin'.
    xschop Posts: 5,931
    Settled on X-over bracket design. Ordered some stronger black oxide M4 low-profile button heads. They'll bolt to female end of standoffs thru the thicker acrylic plates and be electrically isolated. Don't trust the 35 y/o pcb coating.
    Installing a single stainless barrel nut with copper antiseize and a large solid brass thumb screw for the outside bling...
    xschop Posts: 5,931
    edited May 22
    Started the drivers...
    xschop Posts: 5,931
    edited May 22
    Stay focused...
    Had some time and knocked out the brass
    grill pegs...
    Made a couple extra rings 0.540" tall for some MW6500s...😁
    xschop Posts: 5,931
    Brass RDO's...
    I'm afraid to ask.....
    xschop Posts: 5,931
    SCompRacer wrote: »
    :D
    Are those 7C's with SL1000's I see on the boxes?
    xschop Posts: 5,931
    Yes, I put bacon on everything.
    xschop Posts: 5,931
    edited May 24
    About 0.050" clearance all around...
    edited May 24
    Boxes say 7C but speakers have what looks like the sl2000 tweeters. Serial numbers of speakers match serial on boxes.
    Styrofoam stuck on corners, other wise in nice shape.
  • Gardenstater
    Gardenstater Posts: 4,991
    edited May 24
    The first year the 7C came out, it had the SL1000, then all the ones after that had the SL2000. According to @DeRod the enclosure walls are thicker on the 7C, than the 7B.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,931
    We'll see if the 0.020 sag is gone permanently in a couple days from this 6511.
    Used the weighted coil centering spud and heated the spider gradually. Its back to normal for now...
    xschop Posts: 5,931
    edited May 24
    First of their species...
    xschop Posts: 5,931
    xschop Posts: 5,931
    xschop Posts: 5,931
  • SIHAB
    SIHAB Posts: 5,902
    edited May 25
    F1nut Posts: 52,406
    Any plans to clear coat the brass?
    edited May 25
    Give it a few weeks, it will clearly be coated with Verdigris
    xschop Posts: 5,931
    edited May 25
    I'm doing a finer grit now, and then scotchbrite pad. Then I'll use Mothers diatomaceous. On 360 grade brass, should maintain its luster for a long time.
    I went with a full 6" diameter and drilled the cabinet fasteners further out to brace the rear of cabinet that much more.
    These things are heavy.
    It's lunch time.Going get myself a chicken bacon sandwich.
    Happy Memorial Day friends...
    xschop Posts: 5,931
    Ivan, I have some old machined 360 brass part offs and it hasn't oxidized much. The alloy is almost like day one from years ago...The OG shop speakers have taken a lickin' no doubt. Still jazzin'....
    I have no doubt. I was being a smartypants
    F1nut Posts: 52,406
    edited May 25
    xschop wrote: »
    Ok, well a few other options are lacquer for brass or Renaissance wax
    https://www.woodcraft.com/products/mohawk-lacquer-for-brass-gloss-aerosol-13-oz
    Edit: If you use the spray lacquer be sure to clean the brass first with a degreasing agent.
