CRS+ RestoMod
    Would be nice to find an obscure cast brass emblem, if they existed. The sanded top does match the billet theme, but not going there this time...
    Looking forward to hearing the Silver Dragons. They didn't come in 20 and 40uf, so the Black Dragons will be just fine.
    Hat's off to @VSAT88 suggestion. These still remain in the XS-8TLs. I tried a Clarity PX and CSA on their
    tweeter circuits and could not hear much a difference, just fantastic clarity. I will do the same for these when the time comes.
    Went with a 3 ohm wire wound resistor since I deleted the safety polyswitch. Had to mount it this way to keep it off the TL shunt cap cause the leads are short with longer bodies.
    Is that a Jantzen or Mundorf resistor?
    edited May 19
    What are the white inserts called?
    If I could find some with threaded bases and pronged inserts would be ideal...
    Standoffs.
    You can replace with aluminum hex standoffs, which come in various lengths and various male/female versions.
    edited May 19
    But if they're metal, they could wear thru and short two adjacent traces.
  • VSAT88
    Awesome as always brother! Thank you for the ultimate show and tell!
    xschop wrote: »
    I've never heard of that happening, but they also sell nylon hex threaded standoffs, so you can sleep better at night.
    edited May 19
    Dave @westmassguy sent M4 size for my stand off XO project for the RTA11 XO. Nylon hex stand off and nylon all thread with stainless M4 pan head machine screw/bolts to connect the stand offs to the binding post spool and XO board to the top of the stand off.
    edited May 19
    Is it OK to use metric in an older Polk speaker?
    :D
    I've got some 7C's I ought to get into.
    SCompRacer wrote: »
    :D
    SOLD!!! :smiley:
    Ordered an M4 kit.
    That one that resides right between the 2 large inductors had to be surgically removed.
    Will have to get crafty to redo that one. Gorilla glue aint budgin'.
    Settled on X-over bracket design. Ordered some stronger black oxide M4 low-profile button heads. They'll bolt to female end of standoffs thru the thicker acrylic plates and be electrically isolated. Don't trust the 35 y/o pcb coating.
    Installing a single stainless barrel nut with copper antiseize and a large solid brass thumb screw for the outside bling...
    edited May 22
    Started the drivers...
    edited May 22
    Stay focused...
    Had some time and knocked out the brass
    grill pegs...
    Made a couple extra rings 0.540" tall for some MW6500s...😁
    Brass RDO's...
    I'm afraid to ask.....
    SCompRacer wrote: »
    :D
    Are those 7C's with SL1000's I see on the boxes?
    Yes, I put bacon on everything.
    edited May 24
    About 0.050" clearance all around...
    edited May 24
    Boxes say 7C but speakers have what looks like the sl2000 tweeters. Serial numbers of speakers match serial on boxes.
    Styrofoam stuck on corners, other wise in nice shape.
  • Gardenstater
    edited May 24
    The first year the 7C came out, it had the SL1000, then all the ones after that had the SL2000. According to @DeRod the enclosure walls are thicker on the 7C, than the 7B.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    We'll see if the 0.020 sag is gone permanently in a couple days from this 6511.
    Used the weighted coil centering spud and heated the spider gradually. Its back to normal for now...
    edited May 24
    First of their species...
  • SIHAB
    edited May 25
