1…186187189191192…207
  • invalid
    invalid Posts: 1,560
    skipshot12 wrote: »
    invalid wrote: »
    ^^ Actually doing a little research it turns out the output is 1,000W maximum, which I should've realized from the model name "P1000". Lots of power storage in 16 3,300 uF capacitors I would imagine, to handle short term peak draws. Does it put out more than 1,000W short term because of that? PS Audio has downloads for vintage equipment models, but the one for the P1000 is a link that is not functioning (of course lol).
    Doesn't really seem like a lot, my 300 watt amplifier has 272,000 UF.
    What amplifier do you have?
    I need to look inside my WOPL phase linear 700 and see what the power supply capacitance is. It is 500w per side.
    I have a krell ksa 300s.
  • invalid
    invalid wrote: »
    Perhaps not, but it is additive to what is in your amplifier. In your case it won't make a lot of difference. Circuit Breaker boxes are 0 uf though.
    The p1000 is only rated at 1,000 watts, a 15 amp circuit from the breaker box is actually rated higher at 1440 watts, so how is it additive?
  • skipshot12
    skipshot12 Posts: 2,173
    edited September 2024
    invalid wrote: »
    skipshot12 wrote: »
    invalid wrote: »
    Nice nice.
  • skipshot12
    newbie308 wrote: »
    Furman does the same thing on their 15A IT reference. In fact, I think it has the same number of outlets.
    Huge difference between filtering power vs a sine wave generating piece of equipment……..
    https://www.proaudiodesign.com/products/equitech-model-15wq-studio-wall-mounted-balanced-power-supply-150-amp
    Now that’s a dedicated circuit!
    They also make 200a versions and higher for home builds.
    nooshinjohn Posts: 26,184
    Will you be making more rings?🤣🤣🤣
    txcoastal1 Posts: 13,520
    Wow….
    pitdogg2 Posts: 27,918
  • skipshot12
    Those are sweet.
  • Milito
    Milito Posts: 2,008
    Looks great!
  • Geoff4rfc
    Geoff4rfc Posts: 3,062
    txcoastal1 wrote: »
    Wow….
    Couldn't have said it better myself!
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
  • SIHAB
    SIHAB Posts: 5,900
    Toolfan66 wrote: »
    How much did you say you wanted for these? :p
    This is Polk showroom type stuff.
  • gmcman
    gmcman Posts: 1,887
    Toolfan66 wrote: »
    Nice work! I really like the raised 2nd layer of the X-over..cleans it up very well.
  • SIHAB
    SIHAB Posts: 5,900
    I especially like the added sunroofs!
    Toolfan66 wrote: »
    @pitdogg2
    Ivan, where is your pictures? 😎 did you check where yours is testing at?
    Both my speakers are testing at 2.6 ohm.
    I have not tested the ohms since our last upgrade.
    I do not have any interior speaker shots. 😏
    Checked mine this morning, they both bounce between 2.4-2.6, but settle at 2.5 ohms.
    Wonder what kind of power my Aragon 8008bb sends their way🤔😉. At 4 ohms it is 400wpc.
    treitz3 Posts: 20,367
    With the addition of some new cables, I have been slowly readjusting the subs back to the room and mains, enjoying the hell out of a plethora of music along the way.
    At this point, the Rythmik subs are barely even on anymore but I am very close to being back to that perfect balance. I'm just glad that I don't need to do the human pretzel to adjust them anymore. That helps tremendously.
    :o
    ZLTFUL wrote: »
    Working on tearing it down to sell it off.
    WHY!?!?
    billbillw Posts: 8,371
    edited November 2024
    ZLTFUL wrote: »
    Getting a divorce most likely sooner rather than later.
    Sorry to hear that man. I went through the same at the end of 2021. I was lucky to keep my 2-ch system, but really, much of it has been replaced since then. I can only pray for you that it is not heavily contested. You'll just be feeding the lawyers if it is.
    Sorry to hear about this, Ryan. Divorces are usually system killers. If there is a silver lining though, no more WAF needed moving forward. You do what you want!
    Still bites though that you have to go through this. Maybe the folks here can collectively cobble you a system together after you get your own place.
    msg Posts: 10,650
    For the dedicated 2 channel enthusiast:
    That pillow needs to go. Also, just one set of spikes? Where are the other three? Fetch me more servants! And quiet this one, his moaning is hosing the noise floor.
    ZLTFUL wrote: »
    Sorry to hear that brother. I will be happy to buy everything from you for a buck fiddy and sell it all back to you for a two dollar bill after…
  • Geoff4rfc
    ZLTFUL wrote: »
    Sorry indeed. It's coming up on 6 years since mine, hard to believe. Without knowing your circumstances, I can tell you this, the phrase "time heals all things" is a crappy saying and I hate it. Has this been said to you? Time is irrelevant to each individual. For all the "helpful" people that told me, "it takes a year before you can get over it" can shove it right up the 'ol tail pipe. Now, that being said, Tom is absolutely correct, not a single oz of WAF in my place, I can crap right on my living room floor and no one says $hit. My gear, my seats and the shirt on my back was what I got out of the D. It was my faith that brought me through it. Now you are at the center of my prayers.
  • Tasuke
    Tasuke Posts: 16
    @Tasuke - That looks like a fun system that you have obviously put a lot of effort into putting together. If you haven't already been welcomed to this board, please allow me to offer you a very warm welcome to Club Polk.
    I don't know what gave it away, but do I detect just a tad bit of OCD in that room or what? 😀
  • recoveryone
  • Wardsweb
    Wardsweb Posts: 944
    Audiomirror Reflection in the house. Now to determine which system these will work best in.
