1…178179181183184…207
  • DarqueKnight
    DarqueKnight Posts: 6,765
    I said:
    The Rossini DAC and Aurender server DO NOT accept 10 Mhz reference clock signals.
    I stand CORRECTED. After further digging in the Aurender's widely scattered online documentation (they do not supply a written manual with the N30SA server), I found this tidbit:
    "Sync with External Clock
    Enable this option when utilizing an external clock like Aurender MC10, MC20, or similar models. For optimal audio quality, 10 MHz Master Clock connections are recommended. Word Clocks that emit clock sync signals at multiples of 44.1 or 48 kHz are also compatible. However, the Word Clock output signal frequency must match the sample rate of the file being played."
    The clock input on the rear of the N30SA server says "WCLOCK", so naturally I assumed this was for a word clock only. I connected the N30SA to the REF10 SE120 and it does indeed accept 10 MHz master clock signal from the REF10 as well as word clock signals from the MC3+USB.
    However, the Rossini DAC only accepts word clock signals. Furthermore, for playback via the AES or SPDIF inputs, the Rossini DAC and the source component must be locked to the same clock. From the Rossini DAC manual:
    "Please note if you lock one of the DAC’s AES or SPDIF inputs to a Master Clock, the
    source equipment (e.g. a CD player) MUST be locked to the same Master Clock,
    otherwise you will experience periodic clicks, dropouts, noises or distortion on the output."
    The above limitation does not apply to the Rossini's USB output. I found the Rossini's AES input to be better sounding than the SPDIF or USB inputs.
    Again, check with Esoteric to verify if the P-01 transport can accept either 10 MHz or word clock input.
    treitz3 Posts: 20,366
    edited April 2024
    I have been told it does [Edit:] accept a master clock input [End edit] and IIRC, the back panel even states this....but based upon your comments here? I damned sure will verify before an extremely expensive purchase!
    Much appreciated, as this kind of thing gets very complicated quickly.
    If I do need a MC3+USB, so be it but I want to know beforehand. The Mutec SE 120 website on compatibility stated that this one was one of the compatible components, so I never did question it....until now.
    I was able to find that list where I originally verified that it is compatible. The two lists above are the gear that is directly compatible with the Mutec Ref10 SE 120.
    From my understanding, I shouldn't need a Mutec MC3+USB - as the CDP and the streaming system will not be used at the same time and they will both be connected via the SPDIF. If I am understanding this correctly, I would only need one if I were to hook up the DAC via the USB (which I do not plan on doing at this time).
  • skipshot12
    skipshot12 Posts: 2,171
    Wow, never heard of them but would love to hear them….
    Very nice.
  • skipshot12
    edited April 2024
    Remind me of a couple of JBL wood infused speakers.
    And pioneer’s exclusive speaker?
    xschop Posts: 5,919
    edited April 2024
    Removed the ball-bearing isolation feet from the converted 8TL-SDA's. Mineral spirits doesn't harm the vinyl veneer and helps release the glue...
    xschop Posts: 5,919
    edited April 2024
    Someone is off their meds if that is off topic lol.
    xschop Posts: 5,919
    Mea Culpa, this should be in "What did I do to my stereo rig today?" :D
  • plastic_avatar
    Off Topic?
    I didn't even know that was a tag option.
    If it matters (when used correctly), to tag truly off topic posts, I'll go spend a few hours flagging and tagging actual offenders =)
    On topic:
    Mineral spirits for gummy goo on vinyl = good to know.
    And those crazy modded RTA/SDA look neat =)
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
    xschop Posts: 5,919
    Acetone would wrinkle the vinyl I'm sure and didn't want to chance it.
    I did add some acetone to the riding mower and it fired right up. Now that's off topic lol.
  • CH46E
    CH46E Posts: 3,595
    I smoked my Ifi Blue Zen tonight!! Accidentally plugged a 12v power supply into it. It calls for 5v. Smells funny now. Crappy pants.
    VR3 Posts: 29,759
    I can smell your part, that sucks! Sorry to hear it. Happens to the best of us
    Oh, chit! Sorry to hear that bro'. That bites.
  • CH46E
    CH46E Posts: 3,595
    $200 mistake. 😢
  • CH46E
    CH46E Posts: 3,595
    I pick up some new Monolith stand last week from a member here. Did not know he was a member here until the meet up.
    Thanks to @dorian (hope I got the right one there)
    These are much better than the wood stands I was using. Now I don't worry about my dog knocking them over.
  • gmcman
    gmcman Posts: 1,887
    edited April 2024
    I lowered the center shelf of the A/V stand.
    This is because I finally pulled the trigger on a PSA Directstream Mk1...need to make it fit. Factory Refurbished from TMR, been really going back and forth with either a preamp or DAC to take this setup a few more feet down the rabbit hole.
    I was debating a R2R, either the Pontus 2 or a Venus 2 but the DS with it's current pricing seems like a no brainer....have to finally get ears on one.
    Was scheduled to arrive monday, but I double checked today and it has moved to Sunday... B)
  • machone
    machone Posts: 1,588
    Switched from Tidal to Qobuz. Tidal no longer works with LMS/Picoreplayer or is beyond my understanding as how to make it work.
    So goodbye Tidal.
    To my delight I can confirm without a doubt that Qobuz sound quality is better.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    billbillw Posts: 8,367
    CH46E wrote: »
    Have you mass loaded them yet? I have the same set. I filled all the legs with aquarium gravel. It was tedious, but probably took no more than an hour to do both. It helped to take the ring away from the legs (if you tap them). Just a dead thunk now. It has to help, right?
  • CH46E
    CH46E Posts: 3,595
    billbillw wrote: »
    CH46E wrote: »
    They are filled with sand. Not sure what kind. There were filled before I picked them up. They are pretty heavy
    pitdogg2 Posts: 27,914
    Beautiful table, I've always admired those.
  • tratliff
    tratliff Posts: 1,906
    The DP-59L is a very nice table. I also have one of the American versions.
    2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
  • skipshot12
    I have a Sony PS-x75.
    It’s close to the same as a Denon DP-47f me thinks.
    Servo tonearm, full auto along with record size and speed detection.
  • xsmi
    xsmi Posts: 1,812
    tratliff wrote: »
    Do you still use the built-in RCA cables or have you switched it to RCA jacks?
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • tratliff
    xsmi wrote: »
    tratliff wrote: »
    Mine has the original. Would like to upgrade it but I don't use the table much. Its my secondary table and not even hooked up currently.
  • xsmi
    xsmi Posts: 1,812
    It'll be my secondary as well. As soon as I get my pre-amp up and running I will be hooking it up.
  • tratliff
    xsmi wrote: »
    I like the semi automatic functionality of it. When I am not paying as close of attention as normal I don't have to worry about getting the tonearm at the end of a side.
    Also, I have a MM cart on it and a MC on my other table. My phono pre has 2 inputs and I can flip back a forth.
  • invalid
    invalid Posts: 1,560
    Are those kt150's?
