The curse of the Treitz, expanding a networking journey
    VR3 Posts: 28,042
    I would be willing to bet 5 dollars you would experience a dramatic improvement
  • jdjohn
    jdjohn Posts: 3,004
    10:1 ?
  • Dr_Wu
    Dr_Wu Posts: 306
    Fellas, I'm nearly ready to jump on the muon filter, but before that, I've got a modem/router powered by a wall wart. I almost got a 12V Teradak for it, but took a last look at the modem manufacturer's statement cautioning against replacing the stock power supply. Is that anything I need to be concerned about?
    VR3 Posts: 28,042
    Nope, just make sure everything is correct polarity, voltage and amperage!
  • Dr_Wu
    Dr_Wu Posts: 306
    treitz3 Posts: 18,334
    So, I sat down to listen tonight for an extended period. Listened to many genre's of music. The Muon Pro brought me that much closer to having live musicians in the room with me. I had mentioned before about in Trey's system, wanting to go back and shake the hand of the piano player behind the speakers right?
    Well, there is something that the Muon does that makes the piano sound eerily real. Does it sound like a "real" piano? Of course not. But with that said, it's the closest I have ever heard from any system I have ever laid my ears on. Both on Trey's system and mine. So, it's obviously repeatable.
    Trey and I went completely different routes with our streaming setup but (again), we both have achieved the same goal. I had already heard much of what the Muon offered because the Shunyata E cables I had already filtered the signal (x3 in my setup) via the cables but the Muon Pro took that and expanded on it in ways I didn't think possible.
    Palpability. Micro and macro dynamics.
    Those two are probably the two biggest things I heard out of the unit (even though it does so much more than that). The past 4 or 5 days have been sheer H. E. Double hockey sticks because of the ups and downs but the sheer cleanliness of the signal has brought into fruition some extremely exceptional musical reproduction.
    I'll put it to you this way. I have had the new (to me) Lampizator DAC and I haven't really felt the need to put it in. Will it help? Oh, I am confident it will but I really am enjoying what I am hearing without it. It's like I have already installed the DAC. The reason I know this is because Trey and Rick brought over the ANK 4.1 DAC to my house and we hooked it up into the system. So, I know what a great DAC can do and what the changes are/can be.
    RS and Dr. Wu, if you are on the fence? Get off it and get 'er done. They do offer a 30 day return policy but I have pretty damned good and solid confidence that you will not be returning it. Just don't even bother to listen during the first 4 days you hook it up. The sound goes all over the place and the ups and downs make you want to pull your hair out. Seriously. But it's worth the wait.
    I don't know what they do in that filter and I don't care. Whatever they do will bring a whole new level of listening enjoyment to your ears. I will say this, the Shunyata E cables did not take more than maybe 2-4 hours to settle in. They were ready to rock after that with no discernible change to anything. With that said, those are much more expensive than the Muon or Muon Pro (I needed 3 E cables to complete my streaming setup) but Shunyata burns them in on a KPIP system for 4 days at the factory before being sent out.
    The Muon in Trey's system made a change that was stunning to listen too. There was a huge difference in what I heard the last time I had visited and after he had the Muon settled in. Granted, he did some other things to his rig other than the Muon but after hearing what the filters did to my system and knowing the changes, I knew what to expect. It offered enough to where I went ahead and ordered one.
    Even though it did not make as big of a difference in my rig? It was worth every penny. The clarity and presentation are wonderful to experience.
    VR3 Posts: 28,042
  • rooftop59
    rooftop59 Posts: 7,981
    Please explain to me the what micro dynamics are with concrete examples. As in what are you hearing when you hear the micro dynamics of a grand piano or acoustic guitar. I’m really curious…
    Game Room 5.1.4:
    Bedroom 2.1
    VR3 Posts: 28,042
    Think about when you hear a piano, you had a hammer striking a string. The hammer provides an impact and then there is the following decay. That decay and initial strike will activate the room and then that will decay.
    A really good setup will capture all of those aspects (with a proper recording of course).
    What is unique about the song Tom is describing, the capture of that strike and decay is amazingly reproduced and is placed very very far back in the soundstage so that you can "sense" the space the actual recording was recorded in. You can feel the reverb of the room and everything.
    I find these aspects happen as you move beyond "sounds" and move into "body/spatiality". That is what is hard to explain to folks that have never heard it, the new HIFI sound is details... hearing all of these little attributes to the music but theres no weight or scale to it. Its like musical wallpaper with maybe some wide staging and good height.
    Not really sure how else to explain it but ultimately when I listen I aim for my system to kind of sound like a Vortex and I am in the middle of everything. I want far left/right staging to be 3 or 4 feet in front of the speakers and on the outer edges or outside the room. I want things that are far away to be far away and I want the singer/center to be right in front of me. Most importantly I want to hear the "scale" of the venue, the reverb. When I am listening, every inch of the room (L/W/H) is a part of the mix. I am in the middle of the mix, not in front of it.
    I have heard very few systems accomplish that feat.
    Hope this makes sense!
    VR3 Posts: 28,042
    This is the track - https://tidal.com/browse/track/212202553
    When I listen to it on my office rig it literally just sounds like someone is hitting a piano key... theres nothing special to it.
    On the big rig it literally feels like I can sense the size, scale of the piano, where the pianist is sitting, the room size it was recorded in, the decay of the notes, etc etc
    That's more macro dynamics but Trey nailed describing that aspect.
    I had written a response in detail and Vanilla apparently didn't save my response when I went to go check on what the newest response was on this thread (weird because it always has). Lesson learned. I'll have to retype it but it won't be tonight.
    I have a date with the pillow.
    Might even make a new thread about it tomorrow, as that is a different subject and IMO, is worth discussing in greater detail.... ;)
  • Dr_Wu
    Dr_Wu Posts: 306
    Tom, would it be difficult for you to remove the ER from your rig, to compare the SQ before and after? Reason I ask is that Hans B's utube test of the eno filter system with the ER suggested the eno was better alone. I think he may have fed the eno to the ER, not the other way around, as I think you have it. Thanks for your thoughts, whether you do it or not!
    VR3 Posts: 28,042
    @treitz3 see above
  • Dr_Wu
    Dr_Wu Posts: 306
    Thanks Trey. To be fair, Hans actually said he preferred the filter w/o the ER; not that it was better that way.
    Yup, got it. Just have to wrap up my "adult" chores first. Yesterday was busy and I still have a few hours to go today.
    Might be able to try different configurations tomorrow night or over the weekend. It's not easy because I have to do the human pretzel but I am all for experimenting.
  • Dr_Wu
    Dr_Wu Posts: 306
    I appreciate it more than you know, Tom! Whenever, and thank you!
  • erniejade
    erniejade Posts: 6,315
    I am curious as well with and without the EtherREGEN
    rooftop59 wrote: »
    My apologies for the delay. My workload got heavy toward the tail end of the week. To answer your inquiry, I’ll try to describe it to the best of my ability.
    It all starts with a very low noise floor but even with a low noise floor, one still might not be able to render micro dynamics well. The rest is up to your system, system synergy, your room and your ears. The other aspect is obviously the recording. Compression kills micro and macro dynamics.
    Micro dynamics on a piano would be being able to hear the individual reverb of a string(s), the sound of the piano player moving the pedals or striking a key softly. Almost as if you can hear the pad hit the string itself on a soft passage. Hearing or being able to detect subtle dynamic changes with the keystrokes (soft or hard hits, are the pedals being used?) whether or not the passage is during a busy one or not so busy…as in just the piano player playing. Are they playing forte, a diminuendo or are they doing a crescendo? Being able to pick up on these things during the reproduction (unless obvious) simply adds to the realism/palpability of the passage/playback.
    Once in a while, on a great/superb recording, you easily pick up on the eco within chamber (body) of the piano and echo off of the top board of a grand, while still being able to detect/observe the reflections of the size of the venue the piano is in as well. All of these are subtle nuances that (if heard) can bring you that much closer to palpability of the piano player and the instrument itself…instead of “just” hearing the notes played back.
    Moving onto the guitar micro dynamics…
    With regards to an acoustic guitar - Can you “hear” the wood or just the note(s)? Can you hear the harmonics inside the body of the guitar, reflecting and radiating around the image? This is (to me) micro dynamics and allows you to, instead of hearing the guitar, you actually “see the guitar”. You'll be able to hear it in the mix clearly regardless of what other instruments are doing. It will have the same tonal characteristics, harmonics, as if it was playing by itself.
    Being able to hear very subtle finger slides on the fret or hearing a finger softly hit a fret or finger(s) hitting the fret strings to stop/change the reverb of the string(s) playing. Being able to hear when the hand or palm accidently or purposely hits the body of said guitar to produce a subtle (sometimes overpowering) “drum beat”, if you will. This is not always an intended sound but it is part of the recording.
    It's merely as an additional level of audible resolution on a very subtle degree of listening. At the end of the day (IMO), you don’t want micro-dynamics to get overpowered by the macro dynamics or vice versa. It’s a balancing act, if you will.
    @Dr_Wu - He is doing things bass ackwards. The ER should be BEFORE the Muon. This, at least to the manufacturer's instructions. This is currently how I have things configured.
    With that said, I have a conundrum. I'd like to do as you and Brian (@erniejade) requested but after 2 long months, I finally got in Brad's RAL umbilical's for my amplifier. While he did cook them, their may be another burn in period and I'd like to get that started. Once they stabilize (hopefully soon), I'd love to do exactly what you both requested....with the Lampi DAC in the system as well.
    Please be patient on that aspect but trust me, I will get around to it as I have no more new gear coming in within the near future. The RAL umbilical's should have been in the system already but the first set he sent me was shorter than they needed to be, so I had to return the original set and start over on the waiting list. They just hit the household earlier this afternoon.
    I still have not forgotten about your inquiry about disabling the external clock for the ER to hear what differences that makes. I just have too many things going on with the rig right now.
    VR3 Posts: 28,042
    No more new gear?
    This forum needs a remind me feature... This post will not age well!
  • Dr_Wu
    Dr_Wu Posts: 306
    Tom, no problem whatsoever! Those RALs need 150-200 hours. I just muted speakers and left them on 24/7. Love the result!
    And, yes, I thought the same thing when I saw Hans' set-up.
    Best to you, brother!
    treitz3 wrote: »
    @VR3 - actual quote sukkkafooo. :D
    treitz3 wrote: »
    Well apparently I lied. It appears as if a tube has gone bad in my pre. I am getting a buzz"ish" kind of sound out of the left channel. R channel is fine.
    I have a spare set of signal tubes but it's back to the human pretzel thing for the weekend. The pre and the PS for it ain't light and there are many connections. If the signal tubes don't work out? I guess I'll be talking to Brent Jesse again come Monday and yet (another) shipment will be on it's way. Such is life.
    Sorry guys. This was an unexpected twist. Grrr.
    No one EVER stated that this hobby was cheap! Dag nabbit! I'll be up and running shortly....just gonna take a little bit more time than I planned on.
    Dr_Wu wrote: »
    ...and the hits just keep on a' comin'. DOH!
    VR3 Posts: 28,042
    7:44pm to 10:44pm...
    3 hours!
    A new record!
  • erniejade
    Brad uses a cable cooker, but when I got the umbilical for the tri-vista, I did notice a difference after a week of it playing straight. Same with the usb and Ethernet cable. Even when I have bought used cables, I find it takes it a few days for a cable to settle in and the sound changes.
  • GlennDog
    GlennDog Posts: 3,085
    VR3 wrote: »
    Trey, I found the album on Qobuz . . . . which track on that LP is the one with piano decay
    Is this the filter ya'll are talking about/the one I cannot live without?
    https://www.networkacoustics.com/shop/muon-pro-ethernet-filter/
    For Gods sake, I'm trying to downsize and this rabbit hole opens up!!
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 28,042
    I'm using the standard muon, which is caps at 100 mbps
    The pro is if you need up to 1 gbps
  • GlennDog
    treitz3 wrote: »
    I don't recall the details in that Lampi (or what preceded Engine 53 for that matter) . . .
    is it R2R ? or what identifying numbered chip is it?
    TIA
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 28,042
    Love tastes like strawberries
  • jdjohn
    jdjohn Posts: 3,004
    I think 100mbps is the max needed for digital audio playback.
    VR3 Posts: 28,042
    Some devices need gigabit, just depends on the device and what you are doing with it. I believe roon requires gigabit, but I could be wrong
