1…151152154156157…207
  • zarrdoss
    zarrdoss Posts: 2,562
    Tom, Thanks for the welcome back.
  • zarrdoss
    zarrdoss wrote: »
    I tried out a set of Martin Logan's and am asking myself why I did not try them sooner?
    Just skip over them and go straight to Magnepan.
    Meh, besides the more expensive models I never really cared for them.
  • jbreezy5
    jbreezy5 Posts: 1,141
    zarrdoss wrote: »
    zarrdoss wrote: »
    It’s kinda like comparing high sensitivity drivers to average/low-sensitivity drivers, or tubes vs. solid-state.
    Completely different sonics.
  • erniejade
    erniejade Posts: 6,327
    zarrdoss wrote: »
    I could be off but, with the Logan, you don't have to worry about integrating a subwoofer since the Logans have a woofer built in.
    I know both can be a bit difficult on setup and very sensitive to room acoustics and placement.
    I have heard both Logans and Maggie's sound amazing and horrible, depending on the room and placement.
    VR3 Posts: 29,759
    One of these here this coming week...
    See how the ANK stacks up!
    mhardy6647 Posts: 35,562
    A New Years resolution: playing with these -- Altec 409 Duplexes (well, Altec does call 'em that! ;) ) in EV Coronet enclosures. Put them in the enclosures yesterday (replacing the EV Wolverine LS8 twincones that were in them).
    A short listen yesterday evening was pretty encouraging (believe it or not).
  • JayCee
    JayCee Posts: 1,509
    edited January 2023
    I'd expect descriptors like "aggressive", "not for the faint of heart", "claw-like" and "wild" w/the "Wolverine" name and badging. At the very least..."bada$$". Kind of underwhelmed w/...
    pretty encouraging
    LOL. Should be a fun project. Cheers to working on a New Year resolution. I'm busting and pouring cement in the basement.
    ➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S3.3 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    edited January 2023
    The Wolverines were "entry level" -- but I guess it's a Michigan thing. :)
    For what were bargain-priced drivers, they were beautifully made, with nice cast baskets and two-inch edgewound copper ribbon VCs. Very sensitive, with excellent midrange.
    source: https://worldradiohistory.com/Archive-Catalogs/Allied-Catalogs/Allied-Catalog-1960.pdf
    The image labeled "LS12" is an LS15, and vice versa. :p
    treitz3 Posts: 20,366
    I take it you set them up with a low powered tube amp? SET?
    treitz3 wrote: »
    Well, not yet :p ATM, they're hooked to that dump find Yamaha RX-V1050 AVR that I tend to use sometimes.
    But, yeah, that's the plan. I have to make (or re-assign) some appropriate cables for 'em. B)
    There are those who claim that the lowly (and still fairly inexpensive) Altec 409 possesses some of the
    legendary Altec 755 driver's strengths in a much, much cheaper package. :) I, unfortunately, don't have any 755 drivers :( -- but I do know some folks who do...
  • stevep
    stevep Posts: 368
    Cool, Allied Radio pre-Radio Shack.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    VR3 wrote: »
    I'm curious about your take on the Lampi, I've had an Amber 3 for a few years now and still quite happy with it.
    Should be delivered today but don't know if he will hook it up today....
    VR3 Posts: 29,759
    Level 5, gen 4
    Dac and separate power supply
    VR3 Posts: 29,759
    VR3 Posts: 29,759
    Time to fight!
    nooshinjohn Posts: 26,178
    Is that an ANK?
    VR3 Posts: 29,759
    Si senor
    VR3 wrote: »
    Si senor
    what series?
    VR3 Posts: 29,759
    5.1 pro
    VR3 wrote: »
    5.1 pro
    If it has USB, I would love to get my ears on it...
    VR3 Posts: 29,759
    The ank and lampizator both have usb, for sure
    I would note however the ank uses a cheap 25 dollar usb to spidf card to convert that signal to apidf so using a 1.5 bnc cable is the best route for connection
    That can be upgraded though, no?
    VR3 Posts: 29,759
    edited January 2023
    Ank recommends if you want to use USB to buy an external USB to spidf converterIMO and in my research, your transport should already have a good USB to spidf converter if it has spidf out...
    Again, alot of redundancy there.
    If both pieces of gear has spidf connections, just use the spidf connection.
    I requested they throw the USB board in there just so it had USB, easier for future resale
    audioluvr Posts: 6,079
    In with 46 on the one you don't keep!
    Clipdat Posts: 13,105
    It's "spdif" ffs, not "spidf"
    VR3 Posts: 29,759
    So my first impression is the lampizator has better detail retrieval but the ank is more musically engaging... But I've only spent about thirty minutes with the lampizator.
    Will keep hooked up for a few weeks and then install the ank back in
    What is the tubes used in the Lamp?
    VR3 wrote: »
    I heard that the Lampi gear likes to be left on. You might not hear what it is truly capable of for a couple days.
    Yeah, I heard that too.
