Post a picture... any picture
Dayyum. Now THAT's a tub! Wow!
So how do you get in and out without barking your shin on the spigot?
I wouldn't have put the faucet there but I do like the look. The scale is also off to me but I liked the looks of it, along with the scenery outside of that window.
Catching either the first or last rays of the day...
Dear lawd, some people's kids....
Yeah need a tub like 4 times that size and more space in the openings
Otherwise cool vision- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
^^ I agree, would be easy to remove.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey.
Religion began when the first scoundrel met the first fool……….Voltaire. -
In a pinch I thought that fuse was ingenious. As long as it is the same value fwiw
If Paul Klipsch made pianos.
^^^ stealin' borrowin' that one!
Meanwhile -- at least in northern New England, it's quite brumous today.
Thanks I had to look up brumous
So what's it mean????Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I looked it up...it means crappyMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
A co-worker gave me this truck many, many years ago (15+) because he liked my truck and saw this at a store.
This truck has all wheel friction drive. You push it and it goes and goes... It was green. I was bored after trying to do some work in the front room sealing those ceiling board joints since they opened up a little. I can't reach any higher without putting my scaffolding back up.
I saw this truck and thought...I've got primer and white spray paints. Do it.
I did ok taping, but I sure wasn't trying to do contest level prepping.
After sanding, priming and painting the white.
Getting the side ready for metalflake blue. I taped it off and then sanded, primed and painted.
This blue is close to what's on my truck. The blue on my truck is micro-metalflake.
I really liked FINNALY painting this diecast truck to look kind-of like my full size one.
From a distance, you can't see the flaws. The flaws will be fixed when I go to paint the black side trim with the chrome center. This diecast even has 3 ridges for that side trim layout. The tailgate has to be detailed also. The front of the hood and one rear side bottom needs more white paint. The windshield trim needs to be chrome along with the the side mirror's fronts. I just saw the rear taillights. I need red too.
soundfreak1 Posts: 2,939
12:32PM
is that another adjustive
(ASR)
Ya gotta love capitalism. Wish I had thought of that!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Nice job!
Here's models of the cars I had in high school. Correct colors on both and accessories, but don't look to close at the workmanship as I'm not the model builder I use to be. Hard to paint a straight line at my age.
Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
I always wondered what you'd get if you crossed a Rottweiler
with a bat.
Pretty potent Woof Woof I'd say.
Might want to have it tested for any contagious infections though. 🦇😷
Sal Palooza -
Those are some great high school cars for sure.
Your paint jobs look great from here.
@Milito quote;
Found out that Kennedy Space Center has a steady supply of E85 fuel. Very hard to find in Brevard County. Been driving 60 miles for it. Now I can run a E50 blend tunefrom ZFG Tunning. Now I have about 525HP. So much fun on this tune. It breaks all four 275/45/21 loose when it hits second. Pretty sure I'll end up in jail soon.
