1120121123125126205
  • jbreezy5
    jbreezy5 Posts: 1,141
    Not sure if I did this today or yesterday. Maybe depends on what time zone you’re in. Or maybe, today is always today.
    Anyway, @treitz3, on your suggestion to get a riser/stand with a tilt of small degree for my recently acquired Klipsch Heresy pair, I’ve done some research and the jbl js-120, otherwise ideal, I have concluded won’t work due to the top bar of the rear speaker support (it will be in the way of the speaker wire terminals).
    However, the KLH Super Five riser looks to fit the bill and has a 5 degree tilt angle. Order placed!
  • verb
    verb Posts: 10,176
    Got the builder crew to haul these guys upstairs!
  • GlennDog
    GlennDog Posts: 3,158
    verb wrote: »
    Looks like you're hoarding, err collecting H-Ds, too! B)
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • HzTweaker
    HzTweaker Posts: 1,082
    Hooked up my spinner the analog way and enjoyed several tracks from my SACDs this morning.
    2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
  • BlueFox
    BlueFox Posts: 15,250
    Good job.
  • GlennDog
    edited September 2021
    Hooked up my new spinner and DAC today. This transport is a tank, weighing in at 14.3 lbs. (it seems heavier). 1st cd is Double Vision by Bob James & David Sanborn
    Both made by North Star and a smok’n deal to boot! Connected via RAL I2S and has black SR fuse
    Found the combo thanks to @verb
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • verb
    verb Posts: 10,176
    Beautiful!
  • Willow
    Willow Posts: 11,325
    I dusted everything.
  • BlueFox
    Just turned everything on to warm up five hours before Tuesday night Metal.
    VR3 Posts: 29,662
    Lookin sweet
  • verb
    verb Posts: 10,176
    Couldn’t wait any longer, moved the L200’s to the old garage!
  • TEAforONE
    TEAforONE Posts: 1,100
    With cooler temps starting to set in, I brought the J2 up from the Pit,and put the the F5 downstairs. With my small listening room,the J2 runs too hot to keep there in the summer months. In the summer, the Pit temps remain in the 60’s even with the J2 running for 8hrs.
    SCompRacer Posts: 9,218
    I was going to spin some vinyl. I clicked the remote for the air pump and noticed the tonearm didn't move much. Looks like some Felis catus punctures in the air line....so I fixed that.
  • ALL212
    ALL212 Posts: 1,670
    Took bits and pieces and put up a bedroom rig.
    Roon to PC via wireless, USB to Schiit Modi Multibit to Schiit baby equalizer and off to the Bottlehead S.E.X. 6DN7 tube amp. AV123 speakers round it out.
    It works and I can run headphones off the S.E.X. amp as well.
    Aaron
    Enabler Extraordinaire
    pitdogg2 Posts: 27,691
    SCompRacer wrote: »
    He's one cool cat!
  • verb
    verb Posts: 10,176
    Put my Bottlehead SEX 2.1 back in service!
    audioluvr Posts: 6,037
    Sweet!
  • invalid
    invalid Posts: 1,554
    I also put the 866a Mercury rectifier tubes back in the preamp power supply0bq7si7naovr.jpg
    treitz3 Posts: 20,239
    Good lawd, I have a sickness. The rig is back under construction one year later. The pic is from last year.
    The rig sounds completely different after adding diffraction pads over the MTM drivers, installing the Path Audio resistors, changing up the PC's, losing the BlueSound Node2 and Musical Fidelity Tri-Vista DAC and replacing that with an Auralic G1 NAP with DAC I have yet to listen too.
    Today, I am working on adding additional outlets and losing the Richard Grey Power Supply once and for all. Even though it has a bank of 6 huge caps to give the rig extra power when called upon? It shunted the sound stage, so it's outta here.
    Next up is hard wiring the NAP from the sun room to the rig (no more using the wi-fi for streaming). I'm gonna hate doing that. Crawlspaces are not my favorite thing. I might do a different path and go through the attic....just need to scope it out.
    This hobby is a sickness, I tell ya'!
  • verb
    verb Posts: 10,176
    Got a Samsung Galaxy 8” tablet to run Stream Magic / Tidal to my Cambridge players!
  • jbreezy5
    treitz3 wrote: »
    Nice move to wired streaming!
    Lots of major system changes you got going there. Time for a fresh cut 🎬
    Good luck.
  • verb
    verb Posts: 10,176
    Moved the Cambridge 851N to the living room rig!
  • verb
    verb Posts: 10,176
    And getting ready to box up the CXN v2, which I sold to a friend. He's fairly new to streaming, been mostly doing BT from his phone. He's in for a treat!
  • stangman67
    stangman67 Posts: 2,330
    Beautiful as ever Mike! One day I also hope to combine back into one rack, but too many components and a weird room makes that tough.
