Post a picture... any picture
An F-102 that must've been goin' so fast as to invert spacetime.
23_0005374 Convair F-102 Delta Dagger by SDASM Archives, on Flickr
Ahh, the good ol' lumber yard, yard stick. Had a few of those broken over my **** back in the day. A little secret, laughing at dad when it breaks is not a good idea!
Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Haha... Not Canada -
You sure take of your feathered friends.
I'm getting the few remaining squirrels around here ( the Hawk family across the street about wiped them out this year!) to come to us. I throw the peanuts under my truck for the most part.Most people just listen to music and watch movies. I EXPERIENCE them.
boston1450 wrote: »
Put a 2/1 lift in the Taco & added some studded grabbers. It added 3in to front & 2in to back. Drives the same as stock IMO. Lost some mileage from studs (they will not be used in winter again-i will go narrow tire next winter on the steelies). Overall it sits a tad higher in front now. I like the looks better & at my age i even went 4 wheeling in the snow that day pictured & had a blast. Still better mpg than the work truck v10. Getting ready to order summer wheels for the general grabbers & gearing up for more upgrades.
Looks great! Did you add new struts or spacers to the front?
I have the Bilstein 6112s and 5160s w/Bilstein coils on my 4Runner set for a 2/1 lift. Initially I had and an inch more than what was spec. but it settled down eventually.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
2in Spacer in front to bring up front level & 1in block on back. Also went up 245/75/16 to 275/75/16 on tire size added 1 more inch. 2/1 lift + 1tire size. Made it 3/2 ( I think) ..... Keep in mind. This is a 2.7 4banger 4×4. Was getting 25 highway 28 back roads @ 50mph. Not a power horse by far. I have a f350 & i use the Taco for travel. As you can see it IS a stripped model. I have added lift. Cover. Hood deflector. . Tow hitch. Mudflaps. Tube steps. Undercoating. Next is speakers. Front brush guard & alum wheels with those Grabbers on it. Steelies will have different tires. Fuel mileage dropped to crazy low amounts due to size & studs. I wanted regular cab. Couldn't find one. Went 3 hours to pick it up @ 26,800.00 not bad. Hated it at first. Raised seat in rear & was soar for 2 weeks. Now 14,500 miles since May 11'th I like it very much. Back n forth to camp. May be interested in a 4dr v6 with HP lift in future. Here is a picture of what it use to sit at. Looked more grandpa'ish IMO..... #1 thing I really hate. Is the dinger. My driveway is quite long. I have to wear seatbelt on a dirt road or else Ding Ding Ding .# 2 no key fob. So ONLY 1 key hole. Driver side. No keyhole on passenger side. The good outweigh the bad by far. Also it only hauls a alum boat trailer
n snowmobile 4wheeler so 4banger does well
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Im thinking your truck is the 6. So understand the settle in part. Not sure the 4 has enough ump to do that lol. That system you installed is way better than mine. How do you like it ? Would you do it again ? Mine was only 420.00 installed & alignment so I'm very happy. If I upgrade truck I plan on lifting to the sky. I see a 4doors lifted like 5-6 inches & drooled. I like the looks of Tacomas over Tundras anyways. My son-in-law talked me into buying this. He shitt when i bought the Taco & 4banger at that. It will never hit the mud. He has Tundra Ted pro sport or something like that. 55000.00 truck. CrazyRandy-Maine
by David WMG
Ken's Minions
Whoa what kind of twisted DNA comes out of that??
aprazer402 wrote: »
Been there, seen that.... -
Sorry but my toilet has never looked that badRandy-Maine
by David WMG
boston1450 wrote: »Im thinking your truck is the 6. So understand the settle in part. Not sure the 4 has enough ump to do that lol. That system you installed is way better than mine. How do you like it ? Would you do it again ? Mine was only 420.00 installed & alignment so I'm very happy. If I upgrade truck I plan on lifting to the sky. I see a 4doors lifted like 5-6 inches & drooled. I like the looks of Tacomas over Tundras anyways. My son-in-law talked me into buying this. He shitt when i bought the Taco & 4banger at that. It will never hit the mud. He has Tundra Ted pro sport or something like that. 55000.00 truck. Crazy
No it’s unlikely to settle any significant amount with spacers. I didn’t realize you were including the additional height from the tires. That makes sense. I had a 1” “Cornfed” spacer/leveling kit for about a year before I went with the full on suspension lift. Never had any issues and it maintained the stock ride. You can’t go wrong with the 4cyl unless you need to tow a boat. That engine is as reliable as they get.
My neighbor just bought a new Tundra TRD sport as well. Nice Truck. Has those sport tuned Bilsteins from the factory and oversized sway bars.
My 2/1 lift, the coil springs started out about an inch an a half higher than expected and it took about 1000 miles for them to settle in to the 2” front and 1” rear it was supposed to be. I really like the 6100 5160 combo with the matching Bilstein coil springs on all four corners. It got rid of the excessive brake dive I had on the OEM struts and improved handling as well; despite the extra height. The ride still feels close to original but a little firmer over broken pavement.
I also added FALKEN Wildpeak AT3Ws and ICON wheels, but kept the OEM tire size. The zero offset wheels gives it nicer stance IMO. The tires are still under the fenders which is what I wanted. I also added tubular upper control arms with more caster built in to ensure the alignment angles were still achievable. I did the install myself but had Toyota do the alignment after. Other things I added was a roof rack, the predator step bars were an add on, and the black badges.
My 4Runner is a 2018 SR5 because with 4 kids I need the 3rd row which isn’t available in any of the TRDs. I’d love a Tacoma though for the obvious utility of the bed. I do miss having a pickup. When my kids are older and driving I won’t need the seats and look forward to another truck.
Haha... Not Canada
No, but we can see it from here on a clear day!
OK... almost. -
mhardy6647 wrote: »mhardy6647 wrote: »
Haha... Not Canada
OK... almost.
I listen to CJRT. Does that count?
jeremymarcinko wrote: »boston1450 wrote: »Im thinking your truck is the 6. So understand the settle in part. Not sure the 4 has enough ump to do that lol. That system you installed is way better than mine. How do you like it ? Would you do it again ? Mine was only 420.00 installed & alignment so I'm very happy. If I upgrade truck I plan on lifting to the sky. I see a 4doors lifted like 5-6 inches & drooled. I like the looks of Tacomas over Tundras anyways. My son-in-law talked me into buying this. He shitt when i bought the Taco & 4banger at that. It will never hit the mud. He has Tundra Ted pro sport or something like that. 55000.00 truck. Crazy
Your 4runner is beautiful. You have the wheels & step I like too. I put my cheap tube step on before I put lift on. It was 130 bucks I think. I knew when I ordered them I was going to change them out. At time I did NOT know I was going to lift it.Then I lifted it & added 10ply tires, now i want a step like yours. Wheels, I like the black with aluminium tips to break up the black like yours. Very nice. Btw the rack looks great.... Does the 4runner ride comfortable compare to the Tacoma ? I've heard the 4dr Tacoma ride better than AC long bed like mine. Maybe more like yours. Overall is there anything you don't like about the 4runner ? Do you drive in snow & how does it do ?Randy-Maine
by David WMG
as seen Elsewhere (ahem, ASR, ahem)
boston1450 wrote: »jeremymarcinko wrote: »boston1450 wrote: »Im thinking your truck is the 6. So understand the settle in part. Not sure the 4 has enough ump to do that lol. That system you installed is way better than mine. How do you like it ? Would you do it again ? Mine was only 420.00 installed & alignment so I'm very happy. If I upgrade truck I plan on lifting to the sky. I see a 4doors lifted like 5-6 inches & drooled. I like the looks of Tacomas over Tundras anyways. My son-in-law talked me into buying this. He shitt when i bought the Taco & 4banger at that. It will never hit the mud. He has Tundra Ted pro sport or something like that. 55000.00 truck. Crazy
There isn’t much I don’t like about it. The fuel mileage isn’t that good 17/20mpg because of the 4.0v6 and 5spd auto. Toyota has been using this combo for over a decade so it’s not as efficient as some of the competitors. It works well though and has proven its reliability. The OEM SR5 ride is very comfortable not near as firm as the Tacoma, but does tend to dive under normal braking more than most would want. The Bilstein struts fixed this. Unlike most other mid size SUVs it’s still built on a truck frame which I like and it feels like a truck. Like you with your Tacoma I like the 4Runner more now than when I bought it. I needed 3rows but didn’t want a car crossover or a minivan. The Tahoes and Expeditions were too big to allow both the wife and I to park in the garage easily. The 4Runner had all the things I needed, space, a true 4wd, tow package. After having it for two and a half years I love how versatile it is. We’ve taken it camping several times, it goes fantastic in the snow, hauls all of us when I need it to, and the rear seats hideaway wonderfully when I don’t need them. I’ve used it to pull trailers and stumps. It doesn’t have a lot of modern tech and it’s on a chassis Toyota has been using well over a decade. Those things don’t bother me though and I’ve actually grown to like that. Did I mention the rear window rolls down too. It’s nice to put all the windows and back glass down and the sunroof back and just go drive. It’s a Jeepish feel, but not quite.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
hoarfrost.
it was one degree F when we got up this morning.
Sunset (well, almost -- since the hill obscures the horizon to the southwest) on Thursday (Dec. 17) after the snowstorm.
KennethSwauger wrote: »
A Nakamichi 1000 and an AKAI 8 track cartridge deck. Cool. -
Thank you kindly for all the info. It may make me change mind as I like SUV's & have trucks now. I miss my XC90 & wish i hadn't sold it now. Too many vehicles & ins is killing me. Thanks again. Happy Holidays to you & your family.
Randy-Maine
by David WMG
Wow, old age! I glanced at ^^^ this before I had my glasses on. I thought it looked like a drive-in car hop tray with a soda and a glazed donut at the bottom. Carry on!
Probably safe to bring that hummingbird feeder in.
Winter time in Florida.
