Billet RD-0194/8 tweeter plate design.
1356789
  • machone
    machone Posts: 1,566
    Very nice work xschop!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    xschop Posts: 5,417
    edited August 2020
    Thank you, it's been a worthwhile journey updating and improving these classic Polk's. The top and bottom edges are not that far from the baffle after all. I may go the further step on my modded 5B's to include the slight angles (calculated 6°) to really update the aesthetics.
    For the dome/coil wire I simply taped 1/4" wide piece of electrical tape to diaphragm. Simple and effective.
  • gp4jesus
    gp4jesus Posts: 2,019
    xschop wrote: »
    The tweeter throat matches factory angle 100%...
    B E A Utiful! WOW!
    *all connected w/Premiere ICs
    xschop Posts: 5,417
    edited August 2020
    Upon further inspection, those lip edges are also there to ensure the plastic fascia doesn't detach from the baffle. I'm going to radius off another 0.020" leaving 0.025" thick lip. This will still be @ 50x stronger than the factory plastic, and the stainless setscrews will set perfectly flush or a tad under....
    xschop Posts: 5,417
    edited August 2020
  • westmassguy
    westmassguy Posts: 6,850
    xschop wrote: »
    That is crazy cool! Beautiful work.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Nesmith98
    Nesmith98 Posts: 224
    Looking good. It's a labor of love for sure. I know too well how much time you have invested in this.
    It would be cool to duplicate the "polkaudio" lettering in that radial pattern around the center.
    xschop Posts: 5,417
    Laser etching would look spiffy in black.
  • Nesmith98
    Laser etch would look great, or a small ball endmill that follows the radial surface.
    xschop Posts: 5,417
    edited August 2020
    I'm going to keep the originals with the extra .020" for the later added angles. Now if I can only decide what type of black to update cabinets.....
  • gp4jesus
    That mid phase plug looks added
  • Gardenstater
    Gardenstater Posts: 4,804
    edited August 2020
    Those things are tricked out! I vote for Zebrawood Veneer (that kinda black). Sound impressions?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,417
    gp4jesus wrote: »
    Surely cleans up vocals and some instruments...
    https://forum.polkaudio.com/discussion/190301/phase-plug-design-for-mw65xx/p1
    xschop Posts: 5,417
    xschop wrote: »
    Thank you WMG. Means a lot coming from a Polk veteran as yourself. You and F1 are an invaluable asset to the community here with your knowledge and experiences.
    xschop Posts: 5,417
    I'm not sure how long it takes for caps to burn in, but so far the sound is excellent and balanced with no errant resonating.
    Also I went to do a weight comparison, but my cheap Harbor Freight gram scale went out. I would say these are 3 to 4 times heavier than factory plastic ones.
    xschop Posts: 5,417
    Shop scale still works....
  • ptrooper
    ptrooper Posts: 501
    Ready to put the orders in ? :p 18
    xschop Posts: 5,417
    ptrooper wrote: »
    You have 3 sets of 2.3TLs? lol.
    I'm sending out a set for a nice set of 2.3Tl's. Can't wait to see them myself.
    xschop Posts: 5,417
    edited August 2020
    Last tidbit detail. I machined the coil lead channels to accommodate any common 1/2" wide electrical tape.(White tape used as reference) Simply snip 1.25" lengths for each side and place over wire lead while slightly overlapping silk dome fabric.....
  • Gardenstater
    What a labor of love, as they say! Did you do the flycutting yet or try that yet?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,417
    edited August 2020
    No, I just pulled this one out to do the tutorial lol. My caps will never be burned in hehe.
    Looks like this batch will be gone with a set of SRS
    I'll build a 6° jig when I get time. As for now I'm enjoying the new look and new sound.
    xschop Posts: 5,417
    If you're interested in a set or more, just PM. I'll take a tally and order material accordingly...
  • motorstereo
    motorstereo Posts: 2,372
    Incredible workmanship!! I'm really looking forward to owning a set for my 1.2tl's.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,841
    Incredible attention to detail!! Perfection!!
    Harry / Marietta GA
  • westmassguy
    Have you considered doing a similar design for the SL1000? The RD-0194 is the replacement for it, however the SL1000 faceplate is substantially smaller.
    xschop Posts: 5,417
    It can be done. The design limitation, is the fact that SL-1000 cabinet router depths are more shallow than the SL2000 and RDO depths, if achieving a curved bezel. A flat plate is easy to do, just need to drill for RDO magnets.
    Also the SL1000 and SL2000 magnet bolts are 41mm on square as opposed to 39mm for RDO
    xschop Posts: 5,417
    Looking back at some of the old posts, a worthwhile mod would be to make an SL1000 plate with the factory RD0- throat angle incorporated?
  • Gardenstater
    edited August 2020
    I'm thinking you could make a curved bezel mounting plate with the RD0 throat angle and all, for folks who want to replace their SL1000's and SL2000's with the RD0194, but don't want to have to route out their cabinets or modify the plastic bezels of the RD0194's. If the router cutout depth is deeper for the SL2000 equipped speakers, perhaps you could have an adapter shim of the required thickness for those folks.
    PS: Or simply make two different thicknesses.
    Post edited by Gardenstater on
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,417
    edited August 2020
    The SL2000s have same mounting dimension as RD0
    I just looked at some old posts of mine and others. These plates fit left and right. The top or bottom needs about 1/8" trim to fit SL1000, but will need @ .080" fly cut from bottom face to get it close to enclosure.
