How many watts per channel do you listen with?
Clipdat
Clipdat Posts: 13,098
How many watts per channel do you listen with on your main/most popular 2ch system?
Sign in to vote!
This is a public poll: others will see what you voted for.
«13
  • BlueFox
    BlueFox Posts: 15,250
    300+ wpc
    I have had various power levels over the years, and enjoyed them all. My current system is 1200/w per channel, and I am completely satisfied now. However, when I was first getting used to it I broke both speakers (Magico S5 v1) at the time. Now I never come close to doing that again. :)
    Tony M Posts: 11,664
    100-150 wpc
    My NAD c370's specs;
    Output power: 120Wpc (20.8dBW), continuous average power into 8 ohms, both channels driven. IHF dynamic headroom into 8 ohms: 3dB. IHF dynamic power (8, 4, 2 ohms): 210W, 340W, 450W. Frequency response: 20Hz-20kHz, ±0.3dB. THD: 0.03%. S/N Ratio (A-weighted, ref. 1W): 94dB. Damping factor (ref. 8 ohm 1kHz): >150. Preamp output impedance: 100 ohms. Headphone output impedance: 220 ohms.
    Dimensions: 17 1/8" W by 5 ¼" H by 13 13/16" D. Weight: 26.5 lbs.
    treitz3 Posts: 20,037
    300+ wpc
    I put down 300+ but that's not my amplifier's rating. That is actually only 210 @ 4 ohms. But, I have two direct servo subs that are both 800 watts RMS. So, I guess around an available 1,800 watts and high current.
    With that said, I have had systems that were well over 3K watts and some down to 8 watts. I had a lot of fun with that 8 watt rig and the one thing I have learned in my travels is that watts really don't mean a hill of beans. It really doesn't equate to much to me but that's what the "public" usually goes off of.
  • marvda1
    marvda1 Posts: 4,953
    150-200 wpc
    do you mean the total watts of the amp or how much of that total we use most of the time?
    Puritan PSM156
    100-150 wpc
    Whatever your amp is rated at into 8ohms.
    100-150 wpc
    treitz3 wrote: »
    I agree. This is just meant to be a fun informal poll.
  • polrbehr
    polrbehr Posts: 2,842
    50-100 wpc
    I have an Adcom GFA 535ll that I believe is rated at 60wpc? I have read that it tests higher but who knows, I never push the 2Bs that hard anyway.
  • BlueFox
    300+ wpc
    Clipdat wrote: »
    My answer was based on how it is rated at 4 ohms, which is the speaker rating. At 8 ohms it is 600/w per channel.
  • Jazzhead
    Jazzhead Posts: 526
    300+ wpc
    800 wpc @ 8ohms. I typically listen at lower volumes, but appreciate the improved dynamics and presence of high current amplifiers.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    200-300 wpc
    With one pair of Amps, 50 WPC Tube. With another Amp 250 SS.
    pitdogg2 Posts: 27,142
    300+ wpc
    My Aragon is rated 200@8 ohm 400@4 ohm and doubles down to very low ohms. My 2.3tls sit at about 4 ohms and drop a little lower.
  • afterburnt
    afterburnt Posts: 7,892
    50-100 wpc
    My Dayens 100 watt monoblocks are in my 2 channel but my surround system is 250, 275, and, 150
    gudnoyez Posts: 8,169
    edited May 2020
    200-300 wpc
    Parasound rated at 250 @ 8 ohms if that means anything . Others @ 200 @ 8 ohms and 100 @ 8 ohms and a couple @ 120 @ 8ohms.
    F1nut Posts: 51,870
    300+ wpc
    I have four 2 channel rigs, one is 500+, one is 8, one is 100 and the last is 45 or so.
  • gyosa
    gyosa Posts: 770
    200-300 wpc
    250 @ 8 bedroom Parasound A21 , SDA 1c’s
    200 @8 pool B&K ex442 , Boston acoustic voyager 7
    140 @ 8 den ps audio s300 , Salk SCST
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • tratliff
    tratliff Posts: 1,798
    Not sure how to answer this. 600 wpc with dual 600 watt subs but never get close to max.
  • rburgess714
    rburgess714 Posts: 618
    edited May 2020
    100-150 wpc
    Parasound A23 @ 125
    Yamaha A-S501 @ 85
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • HzTweaker
    HzTweaker Posts: 992
    100-150 wpc
    My Parasound:
    125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven
    I haven't ran it out of steam yet, so its a keeper.
  • mlistens03
    mlistens03 Posts: 2,767
    1-20 wpc
    My NAD is rated at 85 WPC into 8 ohms, but my Martin Logans are 4-ohm speakers and the NAD's 4-ohm rating is 150 watts. I put down the 8-ohm rating. I also sometimes use an Optonica SA-5105 receiver rated at 15wpc into 8, and I think 25wpc into 4 ohms? I can't quite remember. Both sound great.
    Now, the watts I use of that power? Given my speakers' sensitivity at 92DB, and my tendency to listen well below that even when no one else is home, <1 watt.
    -Micah
  • Jstas
    Jstas Posts: 14,990
    I listen to all the watts but only some of the ohms.
    Expert Moron Extraordinaire
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    100-150 wpc
    Outlaw 5000 HT amp - 160wpc @ 8ohm two channels driven.
    Onkyo A-9150 Integrated 30wpc @ 8ohm. Bookies in family room.
  • mantis
    mantis Posts: 17,537
    100-150 wpc
    I think people would be shocked on how little power we use on a day to day basis. In a full 7 9 or what have you surround system, you might be using 10-30 watts per channel under normal conditions and peak for seconds at a time to 100-200 watts per channel.
    Dan
  • afterburnt
    edited May 2020
    50-100 wpc
    Oh, I got a 70w (soon to be 250w) system, a 330w system and, a 125w system also.
  • soundfreak1
    soundfreak1 Posts: 3,414
    With the adv 6 ohm load 1 amp at 400+ 2nd amp 300+ my speakers can dip to2 maybe less ohm on occasion.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    mhardy6647 Posts: 35,118
    1-20 wpc
    mantis wrote: »
    Not those of us who choose to live fleapowered. ;)
  • soundfreak1
    I bet my 2 amps never get out of class A operation except for milisecs at a time. Unless I get a little too twisty with my right hand. But adv listening levels prob less than a few watts. But when a note wants power ...they have it!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Milito
    Milito Posts: 2,003
    edited May 2020
    200-300 wpc
    B&K 4420 Reference 225 wpc.
  • Thorton
    Thorton Posts: 1,324
    300+ wpc
    2 channel – 400 watts plus 2 - 800 watt subs
    HT – approx.. 5000 watts
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
    300+ wpc
    Thorton wrote: »
    Jesus I had no idea BINFORD made an amplifier ...
  • ken brydson
    ken brydson Posts: 9,008
    220, 221.... whatever it takes
