How many watts per channel do you listen with?
Clipdat
in Electronics
How many watts per channel do you listen with on your main/most popular 2ch system?
This is a public poll: others will see what you voted for.
300+ wpcI have had various power levels over the years, and enjoyed them all. My current system is 1200/w per channel, and I am completely satisfied now. However, when I was first getting used to it I broke both speakers (Magico S5 v1) at the time. Now I never come close to doing that again.
Three 20 amp circuits. -
100-150 wpcMy NAD c370's specs;
Output power: 120Wpc (20.8dBW), continuous average power into 8 ohms, both channels driven. IHF dynamic headroom into 8 ohms: 3dB. IHF dynamic power (8, 4, 2 ohms): 210W, 340W, 450W. Frequency response: 20Hz-20kHz, ±0.3dB. THD: 0.03%. S/N Ratio (A-weighted, ref. 1W): 94dB. Damping factor (ref. 8 ohm 1kHz): >150. Preamp output impedance: 100 ohms. Headphone output impedance: 220 ohms.
Dimensions: 17 1/8" W by 5 ¼" H by 13 13/16" D. Weight: 26.5 lbs.Most people just listen to music and watch movies. I EXPERIENCE them.
300+ wpcI put down 300+ but that's not my amplifier's rating. That is actually only 210 @ 4 ohms. But, I have two direct servo subs that are both 800 watts RMS. So, I guess around an available 1,800 watts and high current.
With that said, I have had systems that were well over 3K watts and some down to 8 watts. I had a lot of fun with that 8 watt rig and the one thing I have learned in my travels is that watts really don't mean a hill of beans. It really doesn't equate to much to me but that's what the "public" usually goes off of.
150-200 wpcdo you mean the total watts of the amp or how much of that total we use most of the time?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
100-150 wpcWhatever your amp is rated at into 8ohms.
100-150 wpcIt really doesn't equate to much to me but that's what the "public" usually goes off of.
I agree. This is just meant to be a fun informal poll. -
50-100 wpcI have an Adcom GFA 535ll that I believe is rated at 60wpc? I have read that it tests higher but who knows, I never push the 2Bs that hard anyway.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
300+ wpcWhatever your amp is rated at into 8ohms.
My answer was based on how it is rated at 4 ohms, which is the speaker rating. At 8 ohms it is 600/w per channel.
300+ wpc800 wpc @ 8ohms. I typically listen at lower volumes, but appreciate the improved dynamics and presence of high current amplifiers.
200-300 wpcWith one pair of Amps, 50 WPC Tube. With another Amp 250 SS.
50-100 wpcMy Dayens 100 watt monoblocks are in my 2 channel but my surround system is 250, 275, and, 150
200-300 wpcParasound rated at 250 @ 8 ohms if that means anything . Others @ 200 @ 8 ohms and 100 @ 8 ohms and a couple @ 120 @ 8ohms.Home Theater
300+ wpcI have four 2 channel rigs, one is 500+, one is 8, one is 100 and the last is 45 or so.
200-300 wpc250 @ 8 bedroom Parasound A21 , SDA 1c’s
200 @8 pool B&K ex442 , Boston acoustic voyager 7
140 @ 8 den ps audio s300 , Salk SCST
BkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
Not sure how to answer this. 600 wpc with dual 600 watt subs but never get close to max.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
100-150 wpcParasound A23 @ 125
Yamaha A-S501 @ 85
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables -
100-150 wpcMy Parasound:
125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven
I haven't ran it out of steam yet, so its a keeper.2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: Magnepan LRS w/Magna Riser stands -
1-20 wpcMy NAD is rated at 85 WPC into 8 ohms, but my Martin Logans are 4-ohm speakers and the NAD's 4-ohm rating is 150 watts. I put down the 8-ohm rating. I also sometimes use an Optonica SA-5105 receiver rated at 15wpc into 8, and I think 25wpc into 4 ohms? I can't quite remember. Both sound great.
Now, the watts I use of that power? Given my speakers' sensitivity at 92DB, and my tendency to listen well below that even when no one else is home, <1 watt.
-Micah -
I listen to all the watts but only some of the ohms.Expert Moron Extraordinaire
100-150 wpcOutlaw 5000 HT amp - 160wpc @ 8ohm two channels driven.
Onkyo A-9150 Integrated 30wpc @ 8ohm. Bookies in family room.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
100-150 wpcI think people would be shocked on how little power we use on a day to day basis. In a full 7 9 or what have you surround system, you might be using 10-30 watts per channel under normal conditions and peak for seconds at a time to 100-200 watts per channel.Dan
50-100 wpcOh, I got a 70w (soon to be 250w) system, a 330w system and, a 125w system also.
With the adv 6 ohm load 1 amp at 400+ 2nd amp 300+ my speakers can dip to2 maybe less ohm on occasion.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
1-20 wpcI think people would be shocked on how little power we use on a day to day basis. In a full 7 9 or what have you surround system, you might be using 10-30 watts per channel under normal conditions and peak for seconds at a time to 100-200 watts per channel.
Not those of us who choose to live fleapowered.
I bet my 2 amps never get out of class A operation except for milisecs at a time. Unless I get a little too twisty with my right hand. But adv listening levels prob less than a few watts. But when a note wants power ...they have it!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
200-300 wpcB&K 4420 Reference 225 wpc.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
300+ wpc2 channel – 400 watts plus 2 - 800 watt subs
HT – approx.. 5000 watts
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
220, 221.... whatever it takes
