Should be. Those are the Creme' De-la Creme'. Nice score.
Would love to hear about a shoot out between them and 12AX7 Ei Gold Pins.
They'll be battling against Amperex 7308's._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
What specific Amperex 7308’s? What year and getter?
Burned the Cary in a bit more! 😀
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I wish I had some McIntosh amls to block my doorway! Nice set up Verb.
Those pants just reminded me of why I am so glad I am divorced.
Oh, I almost forgot. Is this day 6 or 7?
Must be day 7.
Wait until you retire. Sometimes it takes me a while to remember what day it is, let alone the date.
Three 20 amp circuits. -
I only know what day of the week it is by which pills I take in the morning. -
I got a 3 speakers OFF of movers' dollies and organized some more.
I played my Triton Ones A LOT tonight. Being planted on the floor and nothing in front of them clearly helped their sound.
They are truly AMAZING speakers.
I have only been able to imagine how much better a lot of my speakers would sound in the old open space I used to have out there. This year has been the best yet for my energy and scratching things off of my LONG to-do list.
The start;
The before;
The after;
I rearranged my rack again. The April Music DAC runs HOT,just like I read. So,I moved that away from my cdp. Now it has plenty of breathing room.
See my profile for list of gear. -
Picked-up a couple of spare headshells for my Micro Seiki arms.
The H-40 fits the MA-505, and the H-707 fits the MA-707.
The start;
The before;
The after;
Tony, Are the Triton Ones in those pictures?
Harry"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Took the top off my Furman pc to have a look inside as the differential outlets are running 4 volts higher than the wall voltage. Also my electrical checker says they have a open neutral. The high current outlets read the same as the wall voltage so I'll be using them instead. I didn't spot anything wrong so I'll check with Furman to see if this is normal. One thing I did notice while it was on my bench was the pc works even when nothing is plugged into it. The emi on the workbench socket dropped from 415 to 78 just by plugging the Furman in.
BlueBirdMusic wrote: »I got a 3 speakers OFF of movers' dollies and organized some more.
The start;
The before;
The after;
Harry
Yup.
Yard sale find a year or two ago.
Amazing sounding speakers.
It's a "Where's Waldo" game he plays with us every once in a while.BlueBirdMusic wrote: »Tony, Are the Triton Ones in those pictures?
motorstereo wrote: »Took the top off my Furman pc to have a look inside as the differential outlets are running 4 volts higher than the wall voltage. Also my electrical checker says they have a open neutral. The high current outlets read the same as the wall voltage so I'll be using them instead. I didn't spot anything wrong so I'll check with Furman to see if this is normal. One thing I did notice while it was on my bench was the pc works even when nothing is plugged into it. The emi on the workbench socket dropped from 415 to 78 just by plugging the Furman in.
Nice looking tranny...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I just went out there and put a second coat on that bottom wood shelf ( it replaces a broken one. I found that rack on the side of the road a block from my house last summer) and then rocked out the Tritons and the Pinnacle Classic Gold Towers beside the center stereo rack for an hour. I only listened to one pr. at a time. The Pinnacles are efficient but the Tritons are a bear for an amp reviewers have found. At the volumes I was playing at times, I didn't want to melt the NAD receiver playing all 4 speakers at once.
It's a little chilly today so I brought the shelf into the cottage to dry. BIG mistake! The fumes were WAY TOO MUCH so I put it back outside to dry! Spray can paint...
All smiles for a while! Maybe the fumes. Maybe the music. Maybe BOTH.
I missed not playing the Polk 12bs this afternoon. I unhooked them from my JVC receiver yesterday.Most people just listen to music and watch movies. I EXPERIENCE them.
butterbean wrote: »This could go on for different threads! Move my rig to a different wall, much better depth ! Great news!
What's behind the grills?Most people just listen to music and watch movies. I EXPERIENCE them.
You got a smoking deal on those Polks brother! Congrats!
Good deal you scarfed up, rock it brotha.HT SYSTEM-
lsi 9's -
Hooked up a "New to me" Halo A21. Resting on the top shelf atm, until I get around to reworking the Rack to accommodate it.
Short review to follow after I've had some time with it.
Cool man, how they sounding and jiving with everything ?HT SYSTEM-
lsi 9's -
Looking really nice. This is exciting. I am telling you... that NS DAC can boost the performance big time
Enjoy my friend.
Just curious-- what power cables do you have? -
bet those would sound killer with a mastersound integrated.
Puritan PSM156 -
Looks awesomeNew speakers have been set up...the pictures don't do the finish justice. Absolutely gorgeous.
Is that a Kenwood KD-500 tt? Maybe the front badge is missing? "This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Got my Pass X600.5 amp back from repair, installed, and now listening to tunes till late.Lumin X1 file player, Westminster Labs interconnect cable
Bud....Do NOT judge right now. The best is yet to come, with the very best happening about 2 weeks from now based upon how much you listen.
Yes, the whole stereo needs to break in again since I turned everything off while the one amp was gone. That’s fine though. Just means I will appreciate it more. However, after listening to a TV music channel with a sound bar, the stereo sounds awesome.
Everyday is Saturday!
