1…7475777980…207
    mhardy6647 Posts: 35,562
    edited March 2020
    The Frankenaltecs are in the midst of a heart woofer transplant.
    Since I am only using the woofer sections of the 604Es at this point anyway, and since the opportunity presented itself, I am swapping out the Duplexes for a gorgeous (and - currently - borrowed!) pair of 515Bs.
    One down, one to go. B)
    I fired it up to give a listen -- and I cannot stop long enough to do the other one.
    B)
    Does the "B" stand for back so you remember which side is which? Yeah, I'm old too...
    You mean, like writing "TGIF" on a pair of sneakers?
    Toes go in first.
    Close! :)
    The cabinetmaker labeled one enclosure "A" and the other "B". The backs of the baffles are likewise labeled A and B. The speakers are also each labeled (1 and 2) :p
    I actually have the measured T/S parameters of "1" and "2" so... it sort of matters. They are, fortunately, pretty close (not a given with drivers that are as old as I am -- perhaps even older).
    PS both cabinets are now rewoofered with 515Bs. I had a town Finance Committee meeting tonight, so I haven't heard the pair -- yet.
  • maxward
    maxward Posts: 1,744
    That’s common practice for cabinet makers. My dad was one and all drawers were labeled, along with other parts that could be swapped.
  • gmcman
    gmcman Posts: 1,887
    edited March 2020
    dromunds wrote: »
    I've been using Denon LO and HO MC's for a long time and never had an issue. gmcman, PM me if you want I may have a spare I'd let go but I'll have to take a look.
    Thanks, I appreciate that.
    I did pick up a new cart anyway, but never can have too many. I went with the Audio Technica 33PTG/2 and pretty much have it dialed in, but need to get back to it tomorrow. Also need to find some shorter screws.
    This is in conjunction to the Cardas tonearm wire and Cardas Spiral air 1M interconnects, both are Litz style wires.
    The results so far are excellent, I'm taken back at the moment at the level of air around the entire audio spectrum. Not overwhelming, but that sense of "being right there" really stands out, and not bright by any means, the highs are well controlled throughout.
    I will revisit this, but for now I wanted to share my experience in leveling the table. I used a Starrett 98-8 level to get as much accuracy as I could, even though my regular bench level is adequate, I feel any amount of added accuracy is worth the trouble.
    This Starrett is very sensitive, it will register the difference if I place a piece of register recipt under one end, each graduation is .005" per foot. The level would pick up a few deg of movement of the feet so this was a tedious task.
    I've had good results with this mat, but cannot use a clamp due to he recessed center. Not trying to bash it, but was surprised at the deviation...and this likely wouldn't be an issue but the thickness varied at many points.
    Once I realized this, I used a pair of calipers on the mat. The thickness varied from two points, 180 deg apart, from .1975" to .2060. This is somewhat depicted with the Starrett.
    I'm currently using the stock rubber mat which is pretty much level, only a small variation but almost .009" across the other mat is still significant...unless I'm way overthinking it.
    If you have the 1200, I highly reccommend at least these wire mods. This current setup is quite the upgrade from where it was.
    Clipdat Posts: 13,107
    That level is awesome. I need one of those in my life at some point.
  • halo
    halo Posts: 5,619
  • Willow
    Willow Posts: 11,371
    It wasn't today but last Friday. I was working from home (very sick dog) and during lunch I decided to calibrate the system again seeing as we have added some art work to the walls. I also decided to lessen the toe in and kept the large speaker setting Audyssey chose and to my surprise the system sounded better than ever. The sound stage increased and there was a big difference in instrument/vocal separation.
  • verb
    verb Posts: 10,176
    Unboxed the Marsh amp, but since I was down here (normally during the week I’m playing the office rig), I decided to burn in the Cary some more! 😀
  • deronb1
    deronb1 Posts: 5,021
    verb wrote: »
    Sorry sir, but your egress is blocked by an 80lb amplifier. You'll have to move it. 😉
  • verb
    verb Posts: 10,176
    I have to tread carefully into my workshop! :smile:
  • deronb1
    verb wrote: »
    My toes hurt just thinking about it.
  • gp4jesus
    gp4jesus Posts: 2,025
    edited March 2020
    verb wrote: »
    Unboxed the Marsh amp, but since I was down here, I decided to burn in the Cary some more! 😀
    whew😓 It’s a tough job but somebody hasta do it😊
    *all connected w/Premiere ICs
    audioluvr Posts: 6,079
    Nice jammies. And socks... What's your schedule for getting those bigguns recapped again?
    nooshinjohn Posts: 26,184
    audioluvr wrote: »
    I have those same house pants on right now! LOL
  • Gardenstater
    Gardenstater Posts: 4,991
    edited March 2020
    Finally got around to doing the crossover mod in my 7B on the right speaker. Sounds like a veil has been lifted. Much more clarity. Won't wait long to do the left one! 12 gauge OCC solid wire for the midbass because I wouldn't have been able to get to it later. Was going to do the wires as stage 2 but had to do it this way due to the huge size of the 34 uF cap.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Willow
    edited March 2020
    audioluvr wrote: »
    You guys share the same house pants? how cute
  • halo
    halo Posts: 5,619
    edited March 2020
    Willow wrote: »
    Maybe those pants were tucked inside the speakers as damping material?
    audioluvr wrote: »
    He needs a pair of these tube socks.
    (IMO, of course)
    https://www.vivatubes.com/matched-pair-of-tube-socks/
    I don't know if anyone's making transistor socks (or IC socks, for that matter). :#
  • jdjohn
    jdjohn Posts: 3,462
    gmcman wrote: »
    That is sexy, right there B) Congrats!
    Don't start measuring the thickness of your vinyl (or look for warps)...then you'll really drive yourself crazy.
    Tony M Posts: 12,035
    I wiped everything down with disinfecting wipes. :D
  • tonyp063
    tonyp063 Posts: 1,157
    edited March 2020
    That'll make the rig sound too sterile.
  • Malbec
    Malbec Posts: 558
    audioluvr wrote: »
    (IMO, of course)
    You'll need a pair of walken shoes to go with those tube socks.
  • verb
    verb Posts: 10,176
    audioluvr wrote: »
    Sometime this year! :smile: Unless of course, I find a pin/blade set of SRS's!
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Clipdat wrote: »
    I bought this simple and unassuming looking Lumin U1 Mini from AudioThesis, and I'm amazed at how much difference a high quality streaming transport can make.
    I've never heard Tidal sound this good on my system. Worth every penny.
    When I decide to obtain a dedicated Streamer, this model is on my "list". I enjoy the Understated appearance as well.
  • maxward
    ^^^On my short list. Enjoy it, Drew.
  • Mike Reeter
    Clipdat wrote: »
    We need a Polk Audio Forum "Excusive Drew Review"
  • displayname
    displayname Posts: 1,248
    Clipdat wrote: »
    At some point down the road I plan to replace my CXN with a separate streamer and DAC. If I was doing it today, this would be the unit I would be getting.
    Discogs
    I have it connected to my Ruby DAC via an Audioquest Forest USB cable. Would like to try a higher end USB cable with it to hear any differences.
