What amp should i run help please...
KSD009
KSD009 Posts: 33
So back in the day i built my parents a home theatre set up. They never use the home theatre set up. So i have it now.
So for the amp i have is a Harman/Kardon AVR 630. I know this is under powering my set up. So what i have for speakers are:
FRONT TOWERS:
Polk Audio RTI12
CENTRE SPEAKER:
Polk Audio CSI5
REAR SPEAKERS:
Polk Audio RTI6
SUBWOOFER:
Velodyne CHT 12
So i have been trying to figure out how to get the max power out of these speakers. I have been look at power amp to hook up to the amp i all ready have or just a new amp. I will be using the set up for music and to watch movies. I want to get the max power i can with out blowing the bank account. So i’m looking to spend up to 2k ish.
Thank for the help.
Best Answers
  • mrloren
    mrloren Posts: 2,454
    Answer ✓
  • FestYboy
    FestYboy Posts: 3,861
    edited August 2019 Answer ✓
    You're thinking about it too hard, and incorrectly. The rti 12s are power hungry, yes, but as @F1nut stated before, it's more about the amp's ability to deliver current than it is the rated watts output. Given that the RTIs are fairly efficient, you will reach concert level volume rather easily. The issue is: at that level, what percentage is distortion?
    So, when looking at an amp's specs, don't focus on the total output, look at it's output in relationship to the load (8 ohm, 4 ohm, etc). Then, at it's rated output, pay attention to it's THD value (the lower the better).
    As for watching movies, look into getting a receiver that has pre outs, pure or direct mode, and has Atmos, if it has those 3 things, the rest of the goodies usually come along with so that you can upgrade later.
    *Edit: think of an amp this way: watts are like horsepower, everyone gets excited about a number that means jack. Torque does the work and it's what you feel. So it is with current.
    F1nut Posts: 49,806
    Answer ✓
    Viking64 wrote: »
    “Warmer sounding amplifier” - :D. Could you please elaborate? Engineers wince whenever it is suggested that an amplifier has a "signature sound" because it suggests coloration, which is directly antithetical to everything Hi-Fi has stood for since the very beginning.
    To suggest that one sounds different from the other means that one or the other is coloring the signal (or even both). The guiding principle of any brand has always been firmly grounded in NO coloration. Coloration is measured as DISTORTION. When an amplifier is spec @ x watts 20-20,000 hz with no more than y% THD, it either performs to that spec or it does not. Pure and simple. If one performs and sounds different than another, either it’s out of spec and needs service or they’re LYING about their performance specs!
    If you don’t like the sound, add acoustic dampening on your walls, get an equalizer, or change your speakers.
    You should change your username to "Fear Inoculum" because you are the new TOOL.
    Better a tool than fool. I’m still waiting for an answer from F1nut :)
    They are one and the same, so there's your answer.
  • daddyjt
    daddyjt Posts: 2,329
    Answer ✓
    Get a 1 or 2 year old Marantz or Denon AVR (it won’t have Atmos, but it will have more HDMI inputs than you can shake a stick at, and almost all the latest processing up-to and including 7.1, and make sure it has 7.1 pre outs). then get a solid 2-3 channel amp, like a B&K or Rotel or even Adcom. Then use your AVR to run your surrounds and possibly your center, and your amp for you fronts and center if 3ch.
    From there, upgrade at will.
    "Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
    ― Aleksandr Solzhenitsyn
  • mrloren
    Answer ✓
    Simple,
    got to A4L and get a Marantz SR6012
    The either get a Monolith 5 or Emotiva XPA5 get some good interconnects (RCA) cables speaker cables and be done.
    You can save more by going the 3 channel amp like I run and let the AVR power the surrounds. Works good for me.
    F1nut Posts: 49,806
    Answer ✓
    KSD009 wrote: »
    All speakers don’t sound the same i know this. But when it comes to avr or amps they all sound different ?
    Yes
    mhardy6647 Posts: 33,049
    edited September 2019 Answer ✓
    KSD009 wrote: »
    mahrdy6647 did i hurt your feeling by saying sound cult ?
    Not at all :)
    I am heavily vested in the cult of the arcane. I thought it was worth mentioning that you've probably only seen the tip of the iceberg, cult-wise. :)
    I mean -- I know some guys --
    nooshinjohn Posts: 25,102
    Answer ✓
    Not you... think of it as good advise in general.
    Answer ✓
«13456
Answers
  • mrloren
    A Denon AVR-X3500 or Marantz SR6013 from A4L https://www.accessories4less.com/
    then an Outlaw 5000 https://www.outlawaudio.com/products/5000.html
    or
    Monoprice Monolith 5 https://www.monoprice.com/product?p_id=15593
    Or
    Emotiva XPA5 https://emotiva.com/collections/amps/products/xpa-5-gen3
    RTi12 are a hard speaker to drive on an AVR alone.
  • KSD009
    KSD009 Posts: 33
    Hello first i would like to say thank you for the info.
    Question if i’m going to run a power amp why not keep the old HK 630 amp ?
    Also with the power amp what out put would you go with just a 2ch driven or 5ch driven ?
    Once again thx
  • Nightfall
    Nightfall Posts: 10,072
    Just a friendly correction, an AVR is not generally referred to as an amp, just an AVR. There's a difference between an AVR, integrated amp, receiver, and amp.
    As to what amp how often do you sit and listen to regular two channel music vs how often do you use it for TV/movies/video games?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • KSD009
    KSD009 Posts: 33
    I would be using it more for tv and movies. But that being said when i am listening to music i want it to pound. Get as close to max performance in both mods.
    Thx for the help.
    F1nut Posts: 49,806
    You have an Audio Video Receiver not an amplifier. Yours has pre outs, but it doesn't have HDMI, which you'll need, so get a new AVR making sure it has pre outs.
    As for adding an amplifier I suggest you look at a warmer sounding one to help tame your inherently bright speakers. Marantz or Parasound would be a good choice. A 3 or 5 channel amplifier would be best as the front 3 are the most important.
    Speakers do not put out power.
  • KSD009
    KSD009 Posts: 33
    Thx yes speakers don’t put out power. I missed spoke.
    On the power amp how meany watts per ch should i be looking at
    Thx
    F1nut Posts: 49,806
    edited August 2019
    Whatever your wallet can afford, but keep in mind that watts per channel is only part of what counts and it's not the most important one, high current is more important. If an amplifier doubles or comes close to doubling in power from its 8 ohm rating to its 4 ohm rating it is a good sign that it's a high current amplifier.
    This would be a good choice. https://www.parasound.com/a31.php
  • KSD009
    KSD009 Posts: 33
    So if you were in my shoes what would you get ?
    For receiver ?
    Power amp?
    If i’m going to replace my receiver. Too j would be around the 2500 mark.
  • KSD009
    KSD009 Posts: 33
    edited August 2019
    Thx for the info 👍🏽
    tonyb Posts: 32,906
    Suggestions will be all over the place. Also new or used, as used would open up many more possibilities.
    F1NUT's suggestions are spot on with those speakers. Also, leave some room for good cabling in your budget, it does make a difference.
  • mrloren
    With a $2500 budget I think even a used Parasound might be a stretch.
    The Marantz or denon would be good as a pre + amp would not be able to fit in the OP's budget. Thing to watch out for on the Marantz is that darn porthole display, drove me nuts over time.
  • cfrizz
    cfrizz Posts: 13,415
    KSD009 wrote: »
    Thx for the help.
    Welcome to Club Polk. I checked out your HK, It doesn't have all the latest and greatest codecs and no HDMI, but it does have preouts. So if you want you can hook it up with ICs, and just get a 5 channel amp. All of Loren's recommendations are good.
    I would personally go for a new receiver ( I'm partial to Marantz) and then get a separate amplifier to power the speakers. I always suggest a min of 200wpc at 8ohms. This is enough to ensure all of your speakers can operate to their full potential.
    Keep us updated on what you ultimately decide.
    Clipdat Posts: 12,608
    cfrizz wrote: »
    Hahah, here we go again with the "minimum of 200wpc" mumbo jumbo.
  • KSD009
    KSD009 Posts: 33
    Hello thank for all the info.
    From the comment before I know what i have is an avr receiver.
    For cables im using monster pro cables for everything.
    I agree time to change out the receiver.
    So here are a few more question:
    Would you just go with a 5ch not a 7ch power amp for future upgradeability? Is there even a point to 7.1 ?
    200 wats per channel will be enough to power everything else but is that enough power to make the RTI 12 pound ? Get max performance out of them ?
    Also when choosing am should i take i to consideration like the DB? What OMS it will run at ? How big the power supply is ?
    Do power amp connection with an in put for subs ?
    When using a power amp thats whats powering the speakers? Meaning you cant us the receiver and amp to power the speakers?
    Thank guys.
    Viking64 Posts: 6,693
  • BlueFox
    BlueFox Posts: 15,251
    LOL. Good one, but insulting to Tool. :)
  • daddyjt
    S
    ...To suggest that one sounds different from the other means that one or the other is coloring the signal (or even both). The guiding principle of any brand has always been firmly grounded in NO coloration. Coloration is measured as DISTORTION...
    I hate to be the one to break this to you, but EVERY amplifier “colors” the sound to a certain degree. Further, just because it is technically distortion does not mean it is not pleasing to the ear.
    Sounds like you need to listen to a few more amplifiers in quality systems, and it will become apparent.
  • KSD009
    KSD009 Posts: 33
    Cant we all just get along lol. All i want is for my house to shake when i’m watching a movie or playing music. Thank you come again.
    But you're JoJo. You can see into the future. :o
  • BlueFox
    edited August 2019
    KSD009 wrote: »
    Then you need to spend at least $20K.
  • KSD009
    KSD009 Posts: 33
    Ok maybe so but these still can pound. So i want to Get the max performance out if these girls. :)
  • KSD009
    KSD009 Posts: 33
    I will pick up one of the avr you guys Suggested. But i’m not still sure on the amp.
    Also does polk have better tower speakers out now ?
  • KSD009
    KSD009 Posts: 33
    What does colors mean ?
  • FestYboy
    KSD009 wrote: »
    Usually the addition or subtraction of harmonics to the original signal based on the amp's architecture.
    With the possible exception of second harmonic distortion from a single ended
    amplifier, I don't think it's harmonic distortion that's responsible for warmth vs. not warmth of an amplifier's sound.
    This said, I am not sure what the root cause is -- I don't think anyone is, else all amplifiers probably would sound about the same.
    My assessment isn't that such things aren't measurable; just that we don't know what to measure.
    D. R. von Recklinghausen figured that out way before me, though :)
    "If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing."
    http://hhscott.com/vonrecklinghausen.htm
