What amp should i run help please...
2456
Answers
  • KSD009
    KSD009 Posts: 33
    All speakers don’t sound the same i know this. But when it comes to avr or amps they all sound different ?
  • Nightfall
    Nightfall Posts: 10,084
    edited August 2019
    KSD009 wrote: »
    Everything sounds different, to varying degrees. Tubes, amps, preamps, cables, speakers, everything. Where you place the speakers, how far from the rear wall they are, side walls, all affect imaging and sound. Some things make smaller differences than others but it all adds up.
    If you're skeptical of something or others have you believe that a certain thing makes zero difference, instead of listening to them listen for yourself. Buy some good speaker wire, try it out. Live with it a while, if you don't notice a difference sell it.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,770
    Nightfall wrote: »
    KSD009 wrote: »
    Not so long ago there was no need to debunk the myriad of myths surrounding the audio (especially high end) industry which was once based on objectivity and the scientific method. When distortion, response and noise were no longer issues even in the most modestly priced hardware, the high end segment had to rely upon **** & bull BS in order to justify its "raison d'etre". Those engaging in this type of activity might well be described as "audio whores" who, rather than educating, instead choose to exploit the underinformed. Well I guess the economy needs its sheep and those taking advantage of them would've made Jordan Belfort proud.
    What a load of audio ignorance.
    F1nut Posts: 51,770
    Says the idiot with a tin foil hat.
    Thanks, now I can use that to ban you.
    F1nut Posts: 51,770
    Keep digging, makes having you banned all that much easier.
    F1nut Posts: 51,770
    Ah, but I am holier than thou.
    nooshinjohn Posts: 25,925
    Bad and Nationwide as well. I knew there was a reason I put this guy on ignore before he had a chance to hit a dozen posts. My advice would be for others to do the same.
  • FestYboy
    FestYboy Posts: 3,861
    Jesse sleeps during the day...
  • boston1450
    boston1450 Posts: 7,758
    edited September 2019
    PolkAudioJoJo [/quote] I’m still waiting for an answer from F1nut :) [/quote]
    . Would you stop trolling on this forum. Grow the F up. Just dont reply & move along
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • daddyjt
    daddyjt Posts: 3,081
    ...To suggest that one sounds different from the other means that one or the other is coloring the signal (or even both). The guiding principle of any brand has always been firmly grounded in NO coloration. Coloration is measured as DISTORTION. When an amplifier is spec @ x watts 20-20,000 hz with no more than y% THD, it either performs to that spec or it does not. Pure and simple. If one performs and sounds different than another, either it’s out of spec and needs service or they’re LYING about their performance specs...
    I will admit I used to think the same way you do.
    In fact, I even waltzed into this forum, and made many of the same proclamations that you have, and I also picked a fight with Jesse (F1nut), AND I also made an **** out of myself. Just like you have.
    Then I stopped and considered, just for a minute, that maybe I didn't know everything. Then I started listening to the wealth of knowledgeable members here. Then I started listening to my gear - really listening -, and not reading the specs.
    That has lead me on a long journey to my current amplifier, a Mark Levinson 331. It’s only rated at 100wpc, and a not so great .5% distortion rating. But I can attest, it completely obliterates any amplifier I have owned - including ones rated at 400wpc at .005% distortion. It’s not about the specs, it’s about the SOUND.
    It’s not too late to apologize for your attitude - we’re a forgiving bunch here. Sit back, read, and learn. If you are in this hobby to enjoy great sound from a home audio system, open your mind and allow yourself to at least be swayed. You won’t be sorry.
    ― Aleksandr Solzhenitsyn
  • 62caddy
    62caddy Posts: 137
    daddyjt wrote: »
    I used the think the way you do now - whenever I bought new expensive amplifiers - that is until I purchased a device that allows switching between them on the fly. It was humbling, disappointing but immeasurably revealing. Any differences that did/do exist were so minute as to have little to no effect on musical enjoyment.
    All the same, I do appreciate well constructed, high quality equipment that is aesthetically pleasing and do not mind paying a premium for those qualities. Resale value value is another important consideration as well. However, audible differences between most electronics is on a negligible order of magnitude far beyond my ears to discern and it is my opinion that the same holds true for the vast majority of the populace -whether they choose to admit it or not.
    As always, YMMV. :)
    Main:
    McIntosh: MC 2155, MC 2125(x2), MR 80, C 32, MQ 101; Snell J7; Polk: RTiA7, RTiA9;
    Pioneer PL-518; A/T 440 MLa; Yamaha CD
    Vintage:
    McIntosh: MX110Z, MC 2505, MC 240, Thorens TD 145; Shure V15III; Altec 14, Boston T1000; Yamaha CDX 393 CD; Yamaha Cass
  • Nightfall
    It is my opinion that I would have ended that post after the word discern.
    Why not just get a Hello Kitty boombox, disconnect the included speakers, and wire your own up to it? Super cheap and would sound no different than anything else.
    afterburnt wrote: »
  • daddyjt
    62caddy wrote: »
    daddyjt wrote: »
    As always, YMMV. :)
    Interesting point of view. It does however raise the question of why you own so much McIntosh gear. At those prices, I’d think you would have abandon them after the first one, with little to no discernible difference to say, a Crown pro amp...?
    F1nut Posts: 51,770
    62caddy wrote: »
    daddyjt wrote: »
    As always, YMMV. :)
    You do realize that rapid switch between components is absolutely the wrong way to evaluate audio gear, right?
  • I never new there was a sound cult out there. This **** is interesting
    mhardy6647 Posts: 35,014
    a sound cult -- as in opinions outside of the mainstream in terms of hifi reproduction?
    ... you have no idea...
    48315102407_769060669d_b.jpgDSC_5909 (2) by Mark Hardy, on Flickr
    B)
  • 62caddy
    62caddy Posts: 137
    62caddy wrote: »
    daddyjt wrote: »
    As always, YMMV. :)
    In my book that is the only way to do it with any chance of making meaningful comparisons. This view is also shared by many of the foremost authorities on the subject.
    Main:
    Vintage:
  • 62caddy
    62caddy Posts: 137
    daddyjt wrote: »
    62caddy wrote: »
    daddyjt wrote: »
    As always, YMMV. :)
    First, because pre-owned Mc in good nick is one of the best investments as far as home electronics goes.
    Secondly, its product support is second to none with one of the foremost Mc restoration/repair specialists that happens to be located within a relatively short driving distance from my location. This is a major convenience for vintage repairs.
    Third is for deep personal reasons dating back many decades.
    Last but by no means least, is the sound quality which I find immensely satisfying which seems to bring out the best of whatever speakers it's being used with.
    Main:
    Vintage:
    F1nut Posts: 51,770
    62caddy wrote: »
    62caddy wrote: »
    daddyjt wrote: »
    As always, YMMV. :)
    No, that view is not shared by anyone other than the ignorant and/or the habitual naysayer.
    F1nut Posts: 51,770
    62caddy wrote: »
    But you stated earlier,
    So, you either think that all amps sound like a Mac or you just stepped on your tail.
  • daddyjt
    62caddy wrote: »
    You beat me to it -
    F1nut Posts: 51,770
    daddyjt wrote: »
    62caddy wrote: »
    You beat me to it -
    I know, right! It never fails, give'em enough rope and they hang themselves every time. Amusing to say the least.
  • verb
    verb Posts: 10,176
    daddyjt wrote: »
    I feel your journey @daddyjt! One difference, I admitted I didn't know anything! :) With that, comes a whole bunch of humility. Listen and learn, was my modus operandi, for quite a while.
    However, I did manage to, not necessarily pick a fight, but get spanked, by @F1nut nut, IIRC! Ah, tough love! But love nonetheless! :)
    Viking64 Posts: 7,552
    verb wrote: »
    *don't
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    verb wrote: »
    *don't
    Yes! :) Then and now!
  • mahrdy6647 did i hurt your feeling by saying sound cult ?
    verb wrote: »
    Viking64 wrote: »
    verb wrote: »
    *don't
    accuracy + self-awareness = Why we love Dave. :p
    KSD009 wrote: »
    I am sure he is inconsolable at the moment.
    Speaking of "inconsolable"...... :o
  • 62caddy
    62caddy Posts: 137
    62caddy wrote: »
    "Seems to bring the best" should have been self-explanatory as it was never intended to be declaration of fact in the absolute.
    I have also never labored under the delusion that equally satisfying results cannot be obtained with non-McIntosh electronics.
    Main:
    Vintage:
