New Polk Audio "Legend" Speaker Series shown at 2019 Hong Kong High End Audio Video Show
1246721
  • Upstatemax
    Upstatemax Posts: 2,735
    DSkip wrote: »
    The pricing has always been due to eliminating multiple hands in the delivery of the product to market. Once a company gets as big as Polk, the infrastructure has to be in place to deliver which adds cost. On the flip side, the scale of manufacturing offsets some of these costs. Now people are getting the benefit of scale and no infrastructure.
    This speaker line was basically never available at dealers/retailers and had VERY limited distribution channels from the start, mainly online.
    That has not changed with most of the prices you’re seeing. The biggest factor seems to be that Polk needs to unload the massive financial anchor of their inventory of the LSiM line and just forget about making any kind of profit on them. Clearly Polk is contracting places like Adorama to basically be a clearance house for them.
    But I’m still curious if the newer LSiM speakers are built the same as the original production runs.
    mhardy6647 Posts: 35,005
    edited August 2019
    Looks like a bunch of NP electrolytics in that Focal XO.
    The air core conductors in the Alpine XO are pretty cheesy. The ones in the Focal are better, but still nothin' special. The capacitor in the middle of the Alpine XO looks like perhaps a Bennic(?), and there are definitely NP electrolytics to the left and below it; cannot tell about the one on the far right.
    NP electrolytics -- we're talkin' 50 cent capacitors (retail).
    So... I must be missin' something?
  • WLDock
    WLDock Posts: 3,073
    Remember, its all relative. This is car audio. In the tough car audio environment, the adjustment ability of these passive crossovers is more rare than common. Its the sum of all parts as both of these are good performing 3-way speakers systems. Both are good looking and could be featured in show systems. The Focal is crazy expensive....and I don't know the details of the electrolytics, but there looks to be some poly in there as well.
    Anyway, the point was made that the Elac had a better crossover. Then I indicated that may be true but that does not take away from the fact that Polk does a good job with their crossovers. The older car audio SR line and the home audio LSiM line both measure pretty well. Again its the sum of all parts.
    I purposely compared the above well performing car audio systems to the Polk SR crossover as it holds its own. Polk used 1% resistors and 1% Mylar caps, Air core inductors, Zobel network, tweeter protection, 4 tweeter levels via a low noise jumper, all on a cast aluminum chassis. Again....Look at the white paper measurements:
    The LSiM is much of the same when you look at the overall measurements of the line.
    edited August 2019
    upon reflection, I think we're on two somewhat different wavelengths (heh, see what I did there?) vis-a-vis the crossover topic, so I'm out now.
    Y'all carry on. :)
    It will be interesting to see details on the innards of the new Polks, as well as measurements (impedance curves and whatnot). :|
  • Jstas
    Jstas Posts: 14,985
    edited August 2019
    WLDock wrote: »
    Take price, sound preference, and comparison to other speakers out of the equation. The scientist over at Polk have done a good job designing speakers and crossovers using the latest tools available. I took notice years ago with the SRS then the later the car audio SR6500 series speakers. Back then they were one of the few that offerd a white paper showing the science behind what they were offering. Their SR line could produce a pretty good response in the car which is not easy to do out of the box and takes some engineering and good components. It looks like the same engineering was used in the LSiM line.
    SR6500 White Paper
    http://www.specsserver.com/CACHE/FILE23773.PDF
    Not the best, not the worst, but good design and crossover for the SR series, LSiM series, etc. Price to performance is up to the buyer to decide.
    When we were at the old HQ for a Polkfest in, 2005 I think it was?
    Anyhoo, the LCiRTS series was just getting released and they hooked up the show demo LCiRTS105's for us in the demo room at the HQ. While everyone was listening, myself and MacLeod were staring in the little windows of the speakers mounted in the wall.
    Inside that little window was the crossover guts.
    http://global.polkaudio.com/en/Media/POLK/Product Catalogs/RTS Catalog-English.pdf
    Those guts had a little plate that said SR Series on it.
    We asked the sales guy who's name escapes me right now if what we were seeing was true. He confirmed it and said that while the SR Series crossovers were not ideal nor the intended production equivalent, they provided the sound stage and crossover curves and points they were looking for to showcase the imaging that the original LSi in-wall speakers were capable of. Mainly because everyone thought that the ring radiator tweeters were going to be too directional and easy to localize.
    The biggest difference between the SR Series and the LCiRTS crossovers were the SR Series used a 22mm (about 7/8ths inch) ring radiator tweeter vs the LCiRTS and LSi series home speakers 1" ring radiator tweeter. This caused the SR Series crossover to be a bit shouty on the larger 1" tweeters as it was truncating the lower range of the larger tweeter and was not damping the higher end peaks. Mainly because they occurred at different points on the response curve than the 22mm tweeter in the car component SR Series.
    They used the SR Series crossover because the LCiRTS/LSi crossovers were not ready in time for show time.
    The SR Series was, hands down, one of the best component systems ever put out on the car audio market. You don't see them come up used very often and when they do, people still want $400-$500 for them. They were $600-$700 new. You needed to upgrade to stuff like Focal Utopia to be able to at least match if not beat the performance from the SR Series. Especially when matched with one of the SR Series subs.
    Expert Moron Extraordinaire
  • motorstereo
    motorstereo Posts: 2,338
    ^^^^^ Doc; Thank you for that khorn link; I'll have to go through it when I have a bit more time to digest it all
  • mantis
    mantis Posts: 17,374
    I don't like the looks of these new models based off these pictures. Nothing says come listen to me.
    Dan
  • SIHAB
    SIHAB Posts: 5,428
    nothing is gonna sound good that way.
    "As an aside, the pic of the Lsim woofer (left) and the Elac woofer (right)"
  • SIHAB
    SIHAB Posts: 5,428
    off topic Doc, but have you tried YOUR speakers in/or near the corner?
    No, actually -- I was 'going to' run them that way, but they'd be too far apart, I think, so I went with the "Cardas" golden ratio positioning (more or less, sort of). :)
    http://www.cardas.com/room_setup_main.php
    I do get tempted, but I'd have to move so much junk (including the pair of Altec Santiagos that actually are in the corners) that that notion has always died aborning.
    tonyb Posts: 33,072
    4k is the retail ? Hmmm....what was retail when the LSIM's came out ? What are they selling for now. Wait a couple years and you'll get these half off at a friends and family sale. Use the other 2k for a kick arse tubed pre amp. :)
    Or one can always take that 2k and put it on the no pass line at the crap table in Vegas.
    Clipdat Posts: 13,095
    edited August 2019
    Looks like these were the L600 (tower) and L100 (small bookshelf) and L200 (large bookshelf). This potentially leaves a couple other spots in the lineup. Maybe there will be a larger "SDA-style" tower as the top model in the line.
  • halen
    halen Posts: 717
    tonyb wrote: »
    Is that the going price?
    F1nut Posts: 51,763
    edited August 2019
    The prices have not been announced.
  • Nightfall
    Nightfall Posts: 10,084
    I have a feeling the price is what Jesse has been alluding to. They will be very reasonable, I suspect.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • halen
    halen Posts: 717
    Thanks guys.
    Regardless of how it looks, if it takes the L series to another level I am in.
    Just something about Polk’s. I may not be a fan of the individual components but I am a fan of how it fits together.
    Cheers.
  • gyosa
    gyosa Posts: 770
    edited August 2019
    I just wish Polk would delve back into the realm of high end, made in America speakers again , like the SDA’s .....
    Instead of Best Buy and Fry’s stuff .....
    That is why my 1c’s will never leave my possession
    These look like they’re made in China ...
    They look cheesy ....
    Too much “bling” ......
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2019
    gyosa wrote: »
    Bk
    I doubt if that will happen. High-end speakers are a specialty market, not a mass market. I think at this point the owners of Polk are only interested in the mass market; that is “Good enough”.
    F1nut Posts: 51,763
    Nightfall wrote: »
    Huh?
  • gyosa
    gyosa Posts: 770
    edited August 2019
    Exactly ....
    So sad ...Polk , once an icon , reduced to big box store , mid fi , good enough, speakers ....
    Going for the mass market, big box store non-audiophile market ...
    Trading on the time honored POLK name ....
    Far cry from the 70’s - 80’s ...
    I wanna see a modern day iteration of the SDA’s with high end crossovers and components like ribbon tweets and SEAS woofers , for example - like the “big boys” use ....
    Something to be said for vintage quality ....
    And .... I’m obviously not a audio snob .... look at my sig tag 😃
    Bk
    I doubt if that will happen. High-end speakers are a specialty market, not a mass market. I think at this point the owners of Polk are only interested in the mass market; that is “Good enough”. [/quote]
  • Nightfall
    Nightfall wrote: »
    Huh?
    All has yet to be revealed...
    afterburnt wrote: »
    F1nut Posts: 51,763
    Ah
    Well -- I'm not atypically clueless.
  • halen
    halen Posts: 717
    And exactly how many here, would buy high end, modern SDA speakers? Much of the same was stated in regards to LSIM at only $4,000 and look how that turned out.
  • motorhead43026
    motorhead43026 Posts: 4,009
    edited August 2019
    ^^ no way I would, too many vintage out there to be had.
    – Kevin Alfred Strom
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2019
    halen wrote: »
    Thank you! Many of you talk the talk, but are not truly willing to put your money where your mouths are, as evidenced by Motorhead's statement. Don't be hypocrites!
    Polk has always marketed itself as a company that makes good quality products that everyone in every catagory can afford. And it's true which is why they are still in business. In other words they have kept up with the times while some of you are still bitching and moaning about how it was in the past...get over it already times have changed.
    In times past if you wanted audio gear, you had to go to an audio store to get it, but as what usually happens, the bigger stores wanted in on the action and so they started getting that same gear in their stores, people went there to get them and usually at better prices while the higher priced stuff stayed in the audio stores.
    Now the vast majority of the audio stores are long gone and have been for decades, more people are buying direct from the companies that have good reputations online, of which Polk is one of them.
    You tell me where Loren would put a pair of SDA's in his living room, providing his wife didn't toss him and his speakers out onto the street! This is how they are designing homes now, small rooms, lots of windows, a fireplace where a HT should go but can't because of said fireplace.
    People if they are even interested, need compact, small footprint speakers that look like they belong, or at least don't stand out like big, ugly, thumbs.
    If you want to continually live in the past, do so, but stop blaming Polk for keeping up with the ever changing market who are NOT interested in big, fugly, overly expensive speakers, that they have no room to put them.
    Polk is doing what they have to in order to provide the majority of us with well made, good looking, terrific sounding speakers that can fit just about anywhere we want them to.
    If the new line looks similiar to the Signature series, that should tell you something. It tells me, that it is a successful line that is doing very well both in Europe and here in the states.
    Rock on Polk, and good luck with your new line, that the majority of the whiners on here won't buy new anyway because they are too cheap to spend the money.
    F1nut Posts: 51,763
    cfrizz wrote: »
    halen wrote: »
    Not a clue
  • halen
    halen Posts: 717
    Rare few moments I post sober, before 5 pm.. and F1 responds before midnight as well. What is a white walker doing posting at this time, F1? Maybe the stars lined up.
    Anyhow. I hear Motörhead is really good looking. That beast of beauty him. I am honored.
  • I hear Motörhead is really good looking. That beast of beauty him. I am honored.
    So true. even K_M would swoon over me.
