1…4647495152…208
  • jdjohn
    jdjohn Posts: 3,437
    verb wrote: »
    As a Mechanical Engineer, that thing is one of exquisite beauty! Oh, the engineering drawings, tolerance stack ups, machining and material specifications, testing and validation, I could go on. That would have been a fun project to work on! :smile:
    Indeed! Looking at it closer, you can see that the anti-skate adjustment relates directly to the VTF adjustment...and that makes sense.
    There is a steel string wrapped around the VTF roller adjustment dial, and that string is one end of a spring held within the back of the tonearm tube.
    And as you can see, the tension of that string rests against the anti-skate roller with a red line, and a blue line. The AS roller has a blue line for adjustiing conical/spherical styli, and a red line for adjusting elliptical or other fancy styli.
    I appreciate how Micro Seiki related VTF to Anti-Skate in engineering this tonearm.
  • jdjohn
    jdjohn Posts: 3,437
    I now have two Logic DM-101 turntable decks. I really love the suspended chassis design of these Scottish(?) turntables. I am installing a Micro Seiki MA-707 tonearm on one of them.
  • kevhed72
    kevhed72 Posts: 5,207
    Pic of the rack re-design,new speaker stands, and new foliage. I sold my phon pre to fund the amp, so turntable is out of commission for now.
    Clipdat Posts: 13,104
    Nice acoustic plants.
    pitdogg2 Posts: 27,877
    edited July 2019
    Added DH Labs Silver plated OCC copper 14ga. wire to my 2.3tl's. sounding very good.
  • Milito
    Milito Posts: 2,003
    Clipdat wrote: »
    kevhed72 wrote: »
    Looks like James Bond hiding behind the plants.
    mhardy6647 Posts: 35,550
    edited July 2019
    Clipdat wrote: »
    although, I must admit, when I think of acoustic plants, I usually think of something more along the lines of this.
    B) *
    or maybe...
    or, yes, even...
    True story: one of my clients as a consultant has a substantial facility located right at the bottom of the big hill that hosts the above-mentioned company's main (and very imposing) HQ building :p The site is called "The Mountain" -- it is a former, now capped landfill. :)
    _________________
    * Apropos of nothing: I used to drive past the old AMPEX HQ on route 101 more than occasionally when we lived out in "the Bay Area" (1989-91) :)
    Dang! Driver rustlers done struck agin! Form a posse, Earl!
    Milito wrote: »
    Clipdat wrote: »
    kevhed72 wrote: »
    Not doin' a very good job o' it, is 'e?
    Oi mean, you'da tho't 'e'd seen this, wot wif bein' a Brit and all...
    https://youtu.be/C-M2hs3sXGo
  • joecoulson
    joecoulson Posts: 4,979
    kevhed72 wrote: »
    Were you lucky enough to pick up some T4S Totem stands when they were available or are those 3rd party?
    Either way, they look great!
  • motorstereo
    motorstereo Posts: 2,422
    edited July 2019
    Finally got a chance to add this unit to my rig yesterday and give it a good listen.
    I think that if I had a Flux-50 Filter, it would behoove me to break it in listening to this...
    https://youtu.be/U_qHU_6Ofc0
    Tony M Posts: 11,997
    kevhed72 wrote: »
    I think I see Bond, James Bond hiding behind your plant. B)
  • Dr_Wu
    Dr_Wu Posts: 356
    edited August 2019
    Connected the computer to a Pro-ject DAC Box S2 Plus, and have been listening to Tidal on the main rig. Nice, except for all-too-frequent glitching. Not sure what to do about it. Tidal has suggested switching to public DNS server over the one the cable modem/ISP uses by default. I know I'm way behind the curve on this stuff, but any suggestions from you all?
  • joecoulson
    What speed internet do you have and are you streaming 44.1 files (hifi subscription)?
  • codycatalist
    codycatalist Posts: 2,661
    edited August 2019
    Dr_Wu wrote: »
    Go into the GUI of your router (type your IP address on your web browser), login (the credentials are usually admin / admin, if not look at your manual or contact ISP). Set your DNS to 8.8.8.8 which is Google's public DNS.
    Skip brings up a good point, make sure your router/gateway is set for Docsis 3.0 which should be able to handle that fast of a data transfer.
  • Dr_Wu
    Dr_Wu Posts: 356
    edited August 2019
    Thank you all! Here's a snip of my modem speeds. No wifi; just USB cable to DAC. I'm using the Tidal Premium service; not the hi-fi stream. I will make that DNS switch; modem is Docsis 3.0. 9wrnlaga8xmz.png
    Appreciate the help!
    Dr_Wu wrote: »
    To me it sounds like you are describing USB audio dropouts due to an issue with your PC, unrelated to Tidal, your network hardware/configuration, or the speed of your internet connection.
  • CottageChz
    CottageChz Posts: 424
    Hooked up a Lumin D1 and did some Tidal streaming. Happy with it so far, though I only notice a little bit of improvement over the built in DAC in my integrated. I only A/B-ed one song, so I suspect the improvements could be more noticeable in other music. Will be picking up some XLRs soon, I've read that the XLR connection sounds better than RCAs...
  • joecoulson
    Gerres26 wrote: »
    Well maybe not today but very recently moved this monster into the main rig...pictures really don't do it justice.
    Beautiful bro!
  • Gerres26
    Gerres26 Posts: 874
    Beautiful bro![/quote]
    Thanks you sir!
  • BlueFox
    BlueFox Posts: 15,250
    Turned it on this morning so that it will be warmed up for music tonight. The beer will be cold, and the stereo will be hot. :)
  • joecoulson
    I know why you drink the beer Bud, its so you can have a clear conscious when you listen to Gaga and MM on that system... :D
    nooshinjohn Posts: 26,137
    joecoulson wrote: »
    It takes a LOT of beer to make Manson sound good. I didn't care for Gaga's early stuff, but after she started hanging out with Tony Bennet... she can sing.
  • joecoulson
    All in good fun Bud, no harm meant...just razzin ya
    VR3 Posts: 29,730
    MM - the new **** is an awesome track with great dynamic range
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,093
    Gerres26 wrote: »
    It has the look with the TWO KNOBS!! And how does it sound compared to your A308 previously? Only 500 of Trivista's made I read somewhere. The MF sound is the best I have heard. I have a MF 3.2 in my bedroom with my 2B's. I enjoy an A5 at my girlfriend's house.
    Harry / Marietta GA
  • oldrocker
    oldrocker Posts: 2,590
    Girls went Sat shopping.
    Givin the Monitor 500's a good old fashioned "leg stretchin" B)
    Even Hazel is tappin her paw. :p
  • Gerres26
    Gerres26 Posts: 874
    Gerres26 wrote: »
    It has the typical MF house sound but takes it to a whole other level. I've owned the A5 and A308 and they are both excellent pieces especially for the price but the TriVista is just so smooth to listen to and seems to do everything right...not to mention the seemingly limitless power. Its the best most musically involving piece I've had in my setup to date. Besting my Aragon, Belles, McCormack, and PS audio seperates.
