Showcase your setups
Looks like it sounds very hard!
Do you listen to heavy metal?
Mainly Electro pop (i’m from the UK), some EDM and a smattering of alternatives/easy jazz. I do love a bit of Mongolian throat music, though. Always willing to try something new.....Audio Room
PS Audio Perfectwave DAC MK2, Bridge 1 streaming perfectly now
Marantz SM-11S1
Foundation Research LC2
Kef XQ1 bookshelves
Dual Goldenear Forcefield 3 Subs
PS Audio receptacle
3 PS Audio Noise Harvesters
PS Audio power, interconnects and speaker cables
Homemade sound absorption
Lots of blocks for weight and a red single listening chair -
Not into deep/aggressive bass, but I am looking for speed and snap. Yes, this is a pretty analytical setup but I do value imagery hence the solid stands. Mrs Done doesn’t come into my basement room, so have an aesthetic hall pass!Audio Room
Marantz SM-11S1
Kef XQ1 bookshelves
PS Audio receptacle
Thanks.HT
AVR-Pioneer SC99
Adcom 585
RTi12s
Rear- RT150
Center-CSi5
Sub-Rythmik audio F25
Player- Oppo BDP-103
Living room 2ch rig:
Peach Tree Decco, Onkyo CS-5VL SACD and Linn Kelidh
Bedroom 2ch rig.
Cary AE-3, Parasound 2125, Marantz SA8005, Usher V-601 or SDA 1C, SVS SB12-NSD, Intel NUC PC and Panamax MX5105
Headphone rig;
Little DOT MK II with upgraded tube's and Sennheisers HD650. -
joecoulson wrote: »Do you listen to heavy metal?
Or hard rock?First Watt,Monarchy Audio,Aric Audio,Promitheus Audio,April Music,Wyred4sound ,Bluesound,Pro-Ject,Onkyo,Graham Chartwell,Nola,Hornshoppe,HSU Research. -
Ha haaa. Good one.
Finally got the two channel into it’s more permanent location. With the introduction of the Triode (courtesy of @DSkip), it sounds absolutely fantastic. Still not ideal, I know, with it being in a corner, but it’s the best I can do in this space (master bedroom).
Hey, nice HTS2600!
Thank you Joe! That was an awesome karma from you. Also, shout out to Zach (@stangman67) who very generously gave me the rack during one of our numerous transactions. The rack works great, and is rock solid. However, it may only be temporary, as I really need to get something a little wider to move the integrated to the top next to the turntable. It really needs to be showcased - It's beautiful. Even my wife (who has zero interest in audio equipment) said it looks so nice, it needs to be on the top shelf.
This little rig really sounds impressive now. I can only imagine how much better it could sound if I had the space to set it up in a more symmetrical/open arrangement. -
I made a few changes to the system over the last couple of months and thought I would share.
Notice the subs in the corners. Bass is strong, impactful, precise and also very manageable. Was a great addition.
Pictures were taken before the 20-amp dedicated power was run for each of the subs. So, the cabling is a bit messy. I now have 5 20-amp dedicated circuits on that wall. One for each amp, one for each sub and another for all the source components.
You can also get a glimpse of the R2R on the racks that hold vinyl.
I also made some modifications to the rack to hold the Preamp and Receiver in the middle. That involved customizing the pillars for the center rack.
Legacy Focus SE, 2 REL Carbon Limited, McIntosh C50, McIntosh MC601's, VPI Prime w/SoundSmith Zephyr MIMC, Parasound Halo JC3, Denon DP-59l w/Ortofon 2m Bronze, Marantz SA-14s1, Oppo BDP-105, Technics RS-1500, Furman Elite 15PFi, Douglas Connection (Furutech) Alpha Interconnects, Douglas Connection (Furutech) Alpha Speaker Cables, Pangea Power Cables -
I bet that has some serious power in that medium sized room, looks fantastic!
I would certainly keep it as you have it now, the turntable being on the top shelf really makes for convenient record playback. Function over form. I wouldn't move the integrated unless there's an issue with heat with it being on the second shelf. -
Drew,
I agree. I meant that I want to get a wider rack (double width) so I can put both the integrated and the turntable on top. For now, this is fine. I'd never move the turntable to a lower shelf. The heat generated shouldn't be a problem. I had it on for several hours last night and I could easily hold my hand under the top shelf (in contact with the bottom of the glass. It was very warm, but not uncomfortably hot. The open rack gets good ventilation.
I just really want to showcase the Triode a little more! Eventually, I'm looking to upgrade the turntable as well. That little Audio Technica really performs well and sounds great, but I still get a buzz with it. I'm leaning towards the Fluance RT85 in walnut (if they EVER come back in stock!). I figure it would go nice with the Monitor 11s and the specs for the price are hard to beat. -
I wonder where the buzzing is coming from, even with a lower priced turntable that shouldn't be happening.
I actually thought that was a Technics 1200. That might be a solid upgrade for you, they pop up on craigslist quite often at least around here. -
It's something I've been battling for two years now. Don't know if it's the TT, but I've tried 'buzz filters', ground cheater plugs, grounding the chassis of the TT to the amp, etc. Nothing works. This new location of the setup is in our addition (with newer wiring and proper grounding) and I was hoping that might remedy it, but it's still there.
The AT-120 is internally grounded or grounded through the RCA. Perhaps it's a bad RCA?
It's really not that bad. I only hear it when there is no music playing or VERY quiet segments when music is playing. Regardless, it would be nice if I could eliminate it. -
Stupid question, but it's not related to the phono preamp being used at all?
The Pro-Ject table I had for years did that - something in the tonearm
got the new Rega, had no buzzing, but had a weird hiss with the Vincent that was only prevalent when volumes were high, but it still bothered me. Now with the Rega Fono pre - no noise at all. -
Audio: Von Schweikert VR-2 * Musical Fidelity M2si * Bluesound Node 2i * APC H10
Vinyl: Fluance RT82 * Bottlehead Reduction + Integration Upgrade * KAB RF1
Video: VIZIO M55Q8-H1 * Panasonic DMP-UB200 * ROKU SS+ * Z-line Designs Elektra -
Looking good Victor, I like the LP showcase on the left.
I've heard Victors set up. Rather exquisite sound reproduction.
@halo Have you ever tried removing the turntable's dust cover while playing a record? Someone told me recently that it's advantageous to do so, as it cuts down on the resonance in the soundwaves being picked up by the turntable and getting transferred back into the plinth.
Yes, I have, I just didn’t do it for the photoAudio: Von Schweikert VR-2 * Musical Fidelity M2si * Bluesound Node 2i * APC H10
Thanks Russ!joecoulson wrote: »Looking good Victor, I like the LP showcase on the left.
Thanks Joe! Those IKEA Kallax shelving units fit the LPs quite nicelyAudio: Von Schweikert VR-2 * Musical Fidelity M2si * Bluesound Node 2i * APC H10
A couple of highlight shots.
Couple of setups I've had in the past few years.
SDA 1.2's
Surround setup, SDA 2B's L/R, Peerless Monitor 5's center, Peerless Monitor 4's rear
Dynaudio Emit M20's on Skylan stands - current setup but different room.
Testing out some speakers I bought on Craigslist for @dromunds but I forget what they were.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Found another.
RTA-12B's
...and a real old one when I was just running off a Yamaha Aventage AVR, no tube preamp, no amp, just AVR, radio shack spool of wire, and speakers.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
D a m n. You go through gear like Cheetos.Lumin X1 file player
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Magico S5 MKII Mcast Rose speakers, SPOD spikes
Three 20 amp circuits. -
So, @Mike Reeter inspired me to post an update. We got some new carpet, and with that decided to do away with the full bookcase behind the couch.
Made a new base cabinet hutch to hold The tank and store records and whatnot.
With that; I had to put the surrounds into the ceiling. Much cleaner look we think. And the sound is better as the speakers are an upgrade over the old bookies that were back there. More room to breath for all this gear.
Stripped down den rig - no Joule or turntable, sniff.
Study: Roon * ProJect Stream Box Ultra & Pre Box S2 * Pass ACA * DH Labs SS Q10 * Brines Folded ML-TQWT RS 40-1354
Audio: PS Audio DirectStream Jr. * Belles 20a * Pass Aleph 30 - Zu Omen DW * Sunfire Sig II - Polk SRS 2.3tl * PSAudio PP3 * MIT S3
Den: Sonore ultraRendu * Cary xCiter * Dayens Menuetto * KEF LS50
