  • codycatalist
    codycatalist Posts: 2,662
    Added some MIT EXPs2 cables. My problem is whenever I do one change or upgrade I also do something else so no idea if the changes I hear are due to the cables or speaker placement. However the length of the cables allowed me to move my rack from between the speakers to outside to the right of them.
  • verb
    verb Posts: 10,176
    edited May 2019
    maxward wrote: »
    I swapped my old interconnects for the Groneberg I just received from @ALL212. So, apparently nothing much. The old ones (DAC to preamp) we’re Straight Wire Symphony II and too long for the purpose. I was pleasantly surprised with the new ones and told Aaron as much. The Odyssey website showed that they should be connected one way, but Klaus emailed me with the opposite recommendation. So I swapped ends thinking that could hardly make a difference, but i think it did. When I played Pop Pop by famous vocalist/mumbler Rickie Lee Jones, I was able to understand a bit more of the words. This is a nice, mostly acoustic, album that was used by the guy to demonstrate the Joule Electra to me when I bought it. At the time, I had not heard much of it. Thank you, Aaron.
    Hey Aaron was reading through some old threads. IIRC, did you ever modify/upgrade your Joule?
  • verb
    verb Posts: 10,176
    So I had to hook up these little babies in the upstairs rig. Nelson Pass Amp Camp monoblocks! Eventually they’ll make it into my office rig. Test driving em now! :smile:
    audioluvr Posts: 5,432
    WOW! Nice! you'll have to start spending more time in the bedroom now!
  • verb
    verb Posts: 10,176
    audioluvr wrote: »
    Only if the Mrs kicks me out, cause I’ve been a bad boy! :smile:
  • joecoulson
    joecoulson Posts: 4,943
    ^you typically stay for that behavior
    nooshinjohn Posts: 25,093
    That dresser looks like something from a 1970’s waterbed room set...
  • jdjohn
    jdjohn Posts: 3,000
    edited May 2019
    Got a used Micro Seiki MA-505 tonearm :) Yeah, it's missing a couple of bits, but those have been procured and are in transit. Bearings are in perfect working order. Ok, it's a little rough around the edges, but I got a good deal on it, and it should clean up enough to suit me. I'm much more about function over form when it comes to cosmetic issues, but that's just me.
  • verb
    verb Posts: 10,176
    So today is day 2 with these little guys, and having fun! They sound great! More critical listening is store for sure, but one thing I noticed almost immediately was the lower end was better, Seemed to be extended and a bit tighter compared to the Antique Sound Labs monoblocks.
    Shpongle putting em through the test!
    Another surprise for me was that these little heaters never really got that hot! Warm yes, concentrated toward the center of the heatsink, but not bad to the touch. Even after about 90 minutes of playtime. So, IMO no need for special measures to manage the heat.
    Having fun for sure! Loving these little guys! :smile:
    mhardy6647 Posts: 33,027
    looks purposeful.
    jdjohn wrote: »
    Spend some time with a good detailer and the proper tools and it should shine up like new. Good score.
  • jdjohn
    jdjohn Posts: 3,000
    edited May 2019
    Thanks! Detailing is my specialty B) I like Peek cream or paste for polishing. It has diamond dust mixed into it. Greased Lightning is my go-to de-grimer for anodized aluminum oxidation as a first step. Unfortunately, I can't fix pitting :( Also need to clean and re-lube the VTA section.
    It is all a little sticky, and not working as intended.
    You can take the pitted parts and have them reworked if you want to go that deep taking it apart.
  • Willow
    Willow Posts: 10,871
    Willow wrote: »
    I replaced my Rotel transport with my Marantz. The silver face stuck out too much in the sea of black. I ended with cleaner looks and cleaner sound.
    Willow wrote: »
    Willow wrote: »
    I mean, a broad point black Sharpie could've taken care of that problem.
  • gyosa
    gyosa Posts: 699
    Tidal HIFI rocks .....
    Why buy CD’s ?
    Bk
    indyhawg wrote: »
    Started a subscription to Tidal...finally. I am wondering WTH took me so long now.
    Dayens Ampino , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
    PS Audio S300 - sitting in the closet for now …
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
  • Thorton
    Thorton Posts: 1,324
    Added a marine amp to the pontoon. It sounds so much better. Great upgrade.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • BlueFox
    BlueFox Posts: 15,251
    Not to sound stupid, but what is a ‘marine amp to the pontoon’? It sounds aquatic.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    BlueFox wrote: »
    Marine amplifiers are similar to car audio amplifiers but the boards are dipped in an epoxy to seal the components from moisture intrusion.
    A pontoon is a type of boat usually a large platform mounted on 2 or more pontoons (of floats) allowing for a large platform for aquatic parties, fishing, "camping" etc.
  • BlueFox
    Okay. Thanks. We went from land stereos to boats. :)
  • Thorton
    Thanks ZLTFUL
    DAC: Bricasti M1SE
  • indyhawg
    indyhawg Posts: 1,636
    JL Audio....nice job @Thorton.
    pitdogg2 Posts: 24,554
    It's a drinking barge.....
  • cortico
    cortico Posts: 587
    I’m replacing all cables with MIT T2 (period correct), one at a time! :)
  • verb
    verb Posts: 10,176
    Playing with the Acurus A80 after swapping out the power switch last week. Liking it so far! :smile:
  • indyhawg
    edited May 2019
    Following @verbs lead, I built an amp stand for my Stratos Extreme. Excuse the crappy cell phone pics.
  • verb
    verb Posts: 10,176
    Looking good Jeff!
  • voltz
    voltz Posts: 5,384
    edited May 2019
    wtg! very nice ..I have to use amp stand myself....nice!!!
    oops this was for what Indyhawg was doin! So ROCK on my Man!!!
  • indyhawg
    Congrats on that acquisition. I caught a demo of the Sugarcube last year at AXPONA. It was the most impressive thing we saw all day. It has been on my wishlist for a.while now.
