Best speaker wire
  • And now you have more money invested in two power cables than I have in my entire rig. :pB)
    When Joey goes in he goes all in. Now if he'd just spend some on some new shorts...
    If Audioquest just made some "wildwear" he'd be styling B)
  • I simply don't get this "placebo effect" "expectation bias" thing. Over the years I've returned, resold or resold and taken a hit over things that didn't work out for me. Some of them were significant outlays compared to my means and I wanted them to work.
  • txcoastal1 wrote: »
    Besides, no one likes me anyway
    I go away for 36 years and come back to this???????
    Okay, let's try it again, go to the mirror and repeat after me..."I'm good enough, I'm smart enough, and doggone it, people like me"!
  • Geoff4rfc wrote: »
    txcoastal1 wrote: »
    Not me!
    :o
  • I have discovered, after 53 years above dirt on this fine earth, that it is far easier to simply hate everyone with equal vigor. :*;)
  • All red wines taste the same, right? I mean, they pretty much do to me, at least in the $10-$15/bottle range.
  • I find much more variety in whiskey and beer than I do wine. Whenever somebody asks me for wine, I start carrying on about crap like a snowflake college brat.
  • DarqueKnight
    edited January 2019
    Jstas wrote: »
    Wires shouldn't be breaking in. They should how they are going to sound from the factory.
    gdphoto wrote: »
    Sorry to get back on topic, but I just listened to my new DYI cables for about an hour and now they seem a bit bright. Getting back to my earlier question, do speaker cables need time to break in? What I hear now is reminiscent, but now as bad, as when I had my XO's rebuilt and upgraded to RDO194's. Back then the sound was bright and even a little raspy. After about 200 hours, as per F1's advise, they were completely settled in and now sound great. Now with the cable switch, so far, I feel like I am back there again, a bit. Should I wait awhile before passing judgment, or is this a case of it is what it is?
    Wire, the metal conductor part of a cable, does not break in, but the dielectric properties of the cable insulation can change over time. This has to do with the ability of the cable insulation to store and release energy - an cause noise and distortion.
    To hear differences in audio equipment or cables, you need to be using components that are of a level that the typical stuff from Best Buy can’t touch.
    You're being elitist and an audio snob. >:)
  • I would love to see your analysis on the effects of high performance audio cables on entry-level AVR’s, DVD players and speakers.... should make for a fun read. :p
  • Wire, the metal conductor part of a cable, does not break in, but the dielectric properties of the cable insulation can change over time. This has to do with the ability of the cable insulation to store and release energy - an cause noise and distortion.
    That shouldn't be happening.
    Insulation is supposed to prevent interference with signal transmission. If it is coloring the signal then that is a problem.
    There are times when a polarizing insulation is important. Things like radiation barriers or certain kinds of antennas. Otherwise, a dielectric is better suited for things like capacitors where they don't work without it or like in phase shifters, voltage controlled oscillators or tunable filters like what is used in certain radar systems where the dielectric properties improve performance.
    In audio, a clean, unfettered, unmolested signal path is the desired result. Wire insulation that has dielectric properties strong enough to create signal abnormalities that manifest in audible manners is undesirable insulation. All insulation is going to have an effect of some sort but to deliberately choose a material for insulation that has a dielectric property that creates force of any kind on the signal path is the exact opposite of what a wire should be doing. If you have cables that are doing that, you need to get different ones because that is a failure, not a feature. Even if it was intended by design.
    Expert Moron Extraordinaire
  • Jstas wrote: »
    Might disagree there John. Nice theory, but in practical use it doesn't hold water because everything in the chain effects the sound in some manner. Change the internal wiring in your speakers and the sound changes, doesn't mean the new wire is broken, just that it has different properties....and that will effect the sound.
    From the recording to your ears, the signal path has been molested numerous times. Between the gear playing it, the source, the pre, the dac, the amp and the speakers along with every interconnect and speaker cable used.
    In audio, one camp certainly professes a shorter signal path is the best, for the reasons I just explained in the previous paragraph. Less gear, less cabling, shorter path, may indeed grant you a better sound, in theory anyway, but as we know sound is not a one size fits all game to play.
    It could be said, everything I just mentioned is simply coloring the sound, and you'd be right. However, coloring the sound plays into personal preferences and one's idea of what good sound should sound like. If nothing molested the signal, in a perfect world, every CDP would sound the same, every pre/dac/amp, cables, and even speakers to some degree.
  • mdaudioguy wrote: »
    Bottle you say? Whats this? I thought it only came in square?
    more like rectangular or a cardboard cylinder of some some lol...
    Game Room 5.1.4:
    Bedroom 2.1
  • Don't you boys get me started on wine. :)
    Actually I can relate wine to the thread topic. Some say they can't taste a difference in wine, good, you saved yourself some coin then. Same with cables.
    Some say wine, like cables, gets better as you move up in price points. It does...
    Some say wine's characteristics are defined by various things such as the type of grape used, the ground it's grown in, climate, storage temps, aging, etc. Everything matters in the chain of processes to the final taste that hits your mouth. Cable building also has a few processes involved, and pairing those characteristics to those of the associated gear will give your ears the best taste of sound defined by your preferences.
    Some people are happy as a clam drinking cheap wine, pleases their taste buds and they see no reason to spend more. Others may have a more demanding taste bud and like the more expensive wines. Cables are no different.
    The commonality, is personal preferences, which dictate what we buy, what we use, what we listen to. In order to please the various differences in preferences, we have a variety of products to suit any of them. So yes, in food, wine, and audio, everything colors the sound, tastes, to please the end user. Nothing else matters to that one persons preferences.
  • Beauty is in the eye of the beer holder
  • tonyb wrote: »
    But Tony.......................what about expectation bias??? If you buy an expensive bottle of wine IT HAS TO TASTE GREAT, I mean.............you're expecting it to. Even if it tastes like vinegar your "human factor" is going to trick you into liking it because it cost so much, RIGHT!!!
    LMAO at the whole expectation bias.
    If anything, for me, I am even more critical of something I have high expectations for. So that theory just doesn't hold water in and of itself, atleast for me personally. For the many things I am well versed in or have dialed in particular preferences, expectation bias is a non-starter.
    By nature I am analytical and skeptical to the point of annoyance to those around me when it comes to choosing anything, albeit audio, wine, steaks, craft beer, etc. And I am a cheap skate in the fact that I like things that are a good value.
    Anyone can go pick out a great $100 bottle of wine, but I prefer to find that $30-40 bottle of wine that tastes very similar if not almost exactly as good as the $100 bottle of wine, as an analogy.
    10-4.
    (Imagine my surprise to find a photo of our wine cellar on the internet...)
  • Looks like the start of a great day! Lol
  • What, No strawberry Hill?
    Hafler DH220 Power amp Recapped
    Hafler DH110 Preamp Recapped
    Hafler Digital FM Tuner
    Virtue Audio M1 Piano CD Player
    Technics SL-1210-MK5 with an Ortofon Black LVB250 Cartridge
    Polk SDA1c's(Rebuilt XO's by Ben) RDO194 Tweeters
    edited January 2019
    gdphoto wrote: »
    Country Kwencher...
    (but that's a vin blanc -- like that bottle of Thunderbird that snuck into the photo above)
    I've told all y'all my Boones' Farm story, right? :)
  • heiney9 wrote: »
    Then comes the baaad night.
    RAAALLLPHHHH!
  • Consider those wine choices the equivalent to Home Depot copper speaker wire!
    RAAALLLLPHHHH.......
    edited January 2019
    Ed Zachary!
    Unfortunately, there seem to be many incapable of obtaining that skill level as it relates to audio and life in general.
    edited January 2019
    heiney9 wrote: »
    SPEAKER wire.... my bad, I thought this was about SPEARKER cables, and everybody knows those all sound the same.
  • mhardy6647 wrote: »
    gdphoto wrote: »
    I've got a few college stories about Boones Farm also.
  • Jstas wrote: »
    I would have to disagree here. Just like a river. Atoms, molecules and electrons can and will move ever so slightly to create the path of least resistance.
  • F1nut wrote: »
    Ed Zachary!
    Yep, I'm more critical of nicer more expensive things also. Everyone has a certain expectation bias, but one must deal in reality also.
    Sometimes I have a higher than normal expectation, and a piece may exceed it., or fall flat on it's face. Sometimes I have a low expectation, and am pleasantly surprised. I just call them as I hear them, no matter if it's my money or someone elses.
  • audioluvr wrote: »
    Jstas wrote: »
    I agree with this, and I certainly feel it produces an audible result.
  • DarqueKnight
    edited January 2019
    Jstas wrote: »
    You are correct that wire insulation that has dielectric properties strong enough to create signal abnormalities that manifest in audible manners is undesirable insulation.
    The problem with the best dielectric materials is that they are impractical or prohibitively expensive for mass production. This is why telecommunications companies have spent so much time (decades) and money (billions) researching cable insulation materials that have a good trade-off among cost, ease of manufacturing, ease of installation, and ease of maintenance.
    The best dielectric is vacuum (dielectric constant of 1). Second best is air (dielectric constant of 1.00059). Then we get into the better polymer dielectrics like Teflon (dielectric constant of 2.1, cost $3-$10 per pound). Dielectric performance diminishes after after vacuum, air, and Teflon, although polyethylene is close to Teflon with a dielectric constant of 2.25 (cost ~ $1.30 per pound).
    Vacuum and air are essentially "free", but maintaining a vacuum enclosure and an air enclosure costs some time, effort, and $$$$.
    My AudioQuest Sky Gen 2 interconnects use large Teflon tubes filled with air to insulate the silver wire conductors. My AudioQuest Everest speaker cables use carbon-loaded polyethylene insulation around the silver wire conductors. In addition to the low dielectric constant wire insulation, the insulation has a Dielectric Bias system to keep a static electric charge on it to further reduce energy absorption and dispersion.
    audioluvr wrote: »
    Jstas wrote: »
    Electrons take the path of least resistance already present in a conductor. They do not create a path of least resistance. Molecular motion and random electron motion actually impede current flow.
    Unless the current is high enough to heat up the wire, the conductive crystal metallic structure of a wire is not going to change over time due to a current flowing through it. Electrons do not "chip away" at metallic obstructions in a conductor the way that water "chips away" the sides of a river bank.
    The way a wire is drawn, milled, polished, twisted, and formulated can affect the sound. A wire can have better conductivity in one direction than the other. But again, these things do not change with time and amount of use.
