Best speaker wire
1246717
  • K_M
    K_M Posts: 1,632
    edited December 2018
  • PSOVLSK
    PSOVLSK Posts: 5,381
    I've tended to look at spending ~10% of the price of my gear on associated cables.
    Meaning if my entire HT is about 10k of equipment, I should have about 1k TOTAL in cables connecting everything.
    In general that gets me to the mid-fi level of my stuff. Then looking for used results in good deals on cables that are for what I have now as "end-game" as my wallet can afford.
    I've spend years acquiring cables of all sorts as they went on sale and my wallet didnt take nearly the hit it could.
    Some examples:
    Powercables: Stock -> Pangea AC-9 & AC-14 -> PS Audio AC-3's
    Interconnects: Stock ->Signal Cable Analog 2 -> MIT EXp2 -> Kimber Kable Hero
    Speaker Cable: Monoprice 12 gauge -> MIT EXp2 -> Kimber Kable 8VS -> Kimber Kable 8TC (front L/R/C only)
    HDMI: Stock -> Monoprice -> Audioquest Cinnamon
    In general I've found as I moved up each provided a benefit, however moving higher up than I am now has a higher cost to benefit ratio than I AM comfortable with. Everyones wallet is diff, so someone else may go for it and thats cool, or someone else may not want to spend what I have either, which is ALSO ok.
    In general it doesn't cost a LOT to get into better cables. You just have to be super patient for deals and slowly upgrade over time. The upgrades noted above have all been works in progress since I became a member hear over YEARS.
    My fav brands for most to start with are:
    Signal Cable*
    Douglas Connection*
    Blue Jeans Cable
    Zu Audio (ebay only)
    Moving up to the next mid-fi tier IMGO gets you to:
    Wireworld (purchase from @Dskip)
    Kimber Kable
    PS Audio
    MIT
    *members here get 10% off with each vendor
    Good stuff Dan. I particularly like the part I've bolded. That should be all that needs to be said to end a cable debate.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Faustin wrote: »
    Any thoughts out there on Mogami W3103 bulk wire? Parts Express has it for $3.88 a foot.
    I picked up 20 ft. to make a split SDA cable (Neutrik Connections from Dreadnaught to Speakers) so I can't comment on how good it is driving a set of speakers.
    I will say it "looks" like a good quality, small strand OFC Copper, fairly pliable and easy to work with.
    Works very well for what I use it for.
    I use MIT S1 Shotgun Wires on my speakers, which I think is pretty hard to beat. Should be some on the Used Market that would be a good buy/choice.
    pitdogg2 Posts: 27,045
    halo wrote: »
    A question about these Audioquest speaker cables:
    What is the hierarchy between these two models:
    Type 8
    Rocket 33
    It seems, to me, that the Rocket 33 & Type 8 are very similar to one another as both feature long grain copper and perfect surface copper combinations. You have to step up to the Rocket 44 for a straight perfect surface copper cable.
    The Type 8 & the Rocket 33 are similarly priced at Audio Advisor for a no frills bi-wire cable (actually, the Type 8 is just a little more expensive than the Rocket 33). @mantis ?
    Rocket 33 is a double star quad cable. meaning it has 4 conductors in a spiral side by side.
    https://www.audioquest.com/cables/bulk-spool-cables/rocket-series-bulk-spool/rocket-33
    Type 8 will have one run of 4 conductors in a spiral configuration.
    I couldn't find a raw picture but look at the link from audioquest and just one side of that cable.
  • marvda1
    marvda1 Posts: 4,945
    hey, are you calling me cheap B)
    Puritan PSM156
    EndersShadow Posts: 17,704
    marvda1 wrote: »
    Are you not?
    marvda1 wrote: »
    I've heard stories..... :#:#
  • marvda1
    don't believe a word skip and ron say :)
    Puritan PSM156
    marvda1 wrote: »
    So no one else would ever say that about you huh? I think the entire lone star crowd might disagree :smile:
  • mdaudioguy
    mdaudioguy Posts: 5,165
    DSkip wrote: »
    For $300 you could get into a pair of Wireworld Mini Eclipse 8 ft bi-wire cables. Ed bought them but is returning them to get the longer set of single wires. This is OCC copper and a really solid cable. I'm not sure you'll get much cheaper quality OCC out there.
    They're fantastic! I could even ship them direct. :)
  • halo
    halo Posts: 5,616
    So, the Rocket 33 is the "better" cable of the two?
    Type 8:
    Rocket 33:
    halo wrote: »
    Type 8:
    Rocket 33:
    Flip a coin
    I was wrong. I wrongly assumed it had half the conductors when in fact according to your pictures they both had 8 conductors and according to your pictures it says nothing about LGC conductors.
  • halo
    halo Posts: 5,616
    Flip a coin
    Both feature a combination of LGC & PSC.
    heiney9 Posts: 25,432
    K_M wrote: »
    Still does not change the fact that with short runs of wire, audio is very easily sent with very little degradation.
    There is very little room for improvement.
    Sure would be nice if you actually spoke from experience rather than parroting something you read and making a blanket judgment.
    People are sharing their own experiences rather than making a blanket judgment. You should try it some time.
    Cables matter, everything matters.
    Monster is pretty much junk.
    Those that don't know, don't know that they don't know.
    audioluvr Posts: 5,915
    heiney9 wrote: »
    Ok. Now you rotten, enabling bastiges got me thinking about upgrading! I guess when I get home I'm going to have to measure for required length. Probably going to be 3 meters though. Ugh.
  • K_M
    K_M Posts: 1,632
    heiney9 wrote: »
    K_M wrote: »
    I look forward to more of your astute and caring wisdom.
    DSkip wrote: »
    Not to thread jack but can you use the bi-wire as single by just stacking the terminals?
  • mdaudioguy
    audioluvr wrote: »
    DSkip wrote: »
    The biwire end has spades and bananas. My speakers only have a single set of posts, so each post holds a spade and a nanner. Wireworld uses screw-on ends, so they're easily interchangeable.
  • mdaudioguy
    K_M wrote: »
    heiney9 wrote: »
    K_M wrote: »
    I had drafted a response to you after you rebutted my previous post, but deleted before posting. I'm just not really interested in debating the matter. You have your opinion, and I have mine, and I'm happy to leave it that way.
  • mrloren
    mrloren Posts: 2,474
    A few years ago I was reading on another forum. some quack was saying cables don't matter. Said he had over $25k in gear and only spent $200 on cables. What a waste of gear.
    I am happy with my AQ type 4 as with my HDMI and interconnect cables.
  • lightman1
    lightman1 Posts: 10,796
    mrloren wrote: »
    That was me......
    Sorry......my bad
    lightman1 wrote: »
    mrloren wrote: »
    That was me......
    Sorry......my bad
    $25k in gear spread out over 17 states...
    F1nut Posts: 51,764
    K_M wrote: »
    heiney9 wrote: »
    K_M wrote: »
    And your experience with cables is what again?
  • verb
    verb Posts: 10,176
    Interesting video on MIT's patented multi-pole technology.
    https://www.youtube.com/watch?v=WfksBBugqzY
  • K_M
    K_M Posts: 1,632
    K_M wrote: »
    heiney9 wrote: »
    K_M wrote: »
    Actually we went into this a few years ago.
    After I went on a very lengthy description of a blind comparison we did at my house at our own expense to even have others stay over, none were able to prove any of the claims they had made.
    That caused a lot of anxiety among members here, and when I said we would do it again, at our expense, on this forum, no one stepped up or even was interested.
    I think the ball is in your court.
  • ken brydson
    ken brydson Posts: 9,002
    K_M wrote: »
    K_M wrote: »
    heiney9 wrote: »
    K_M wrote: »
    And your experience identifying cables when you are unaware of brand?
  • mrloren
    lightman1 wrote: »
    mrloren wrote: »
    That was me......
    Sorry......my bad
    Doubt it, I found the thread on one of my random google searches. I think it might have been on AVS forum but this guy was bashing everything and saying any HDMI cable over $5 is a waste of money at least he was using Monoprice 16AWG for speaker wire.
    To each there own I guess.
    F1nut Posts: 51,764
    K_M wrote: »
    K_M wrote: »
    heiney9 wrote: »
    K_M wrote: »
    The ball isn't in my court, I already won the game.
  • gdphoto
    gdphoto Posts: 182
    I want to thank everyone that responded to my original question about speaker cables. I certainly learned a lot. I am first going to build a pair of cables to replace my old Monsters using Furez FZ124AS 12 AWG 4 Conductor. A 10 ft. pair will only cost around $40. I am hoping to hear some improvement. Then I'll take all of this knowledge I gained and keep my eyes and ears open for a deal on a good used pair cables by one of the big names. Like someone stated earlier...baby steps.
    Hafler DH220 Power amp Recapped
    Hafler DH110 Preamp Recapped
    Hafler Digital FM Tuner
    Virtue Audio M1 Piano CD Player
    Technics SL-1210-MK5 with an Ortofon Black LVB250 Cartridge
    Polk SDA1c's(Rebuilt XO's by Ben) RDO194 Tweeters
    F1nut Posts: 51,764
    gdphoto wrote: »
    Keeping an open mind is all most of us suggest.
